Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 07-17-2008, 12:37 AM   #1
Best way to hold the screen in place?
Okay my stock double din radio had a removable faceplate which I cut up and integrated the monitor into it. There isn't enough room to put the back of the monitor back on it to keep it all together. So I'm wondering how I should go about keeping the screen in place along with the guts of the monitor? I was thinking hi-temp hot glue but in Florida it gets to be 100+ and I'm worried about it melting. What is another option that is safe to use on circuit boards but will hold it in place?
04silvertib is offline   Reply With Quote
Old 07-17-2008, 12:53 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
Maybe the whole back wont fit, but with some strategic cutting, you should be able to get some screw holes to stay in place and enough of them to secure it in pretty well. Then to finalize it, use some hot glue or something. Screws come out easily, and hold it mostly. But if you ever need to get in there, you just need to scrape the hot glue away from the non-screwed areas.
Old 07-17-2008, 01:22 AM   #3
Well in order to mount the screen in I had to break off the housing screws so screwing the back in is no longer an option. I guess I could go with hot glue and just see where it gets me.
Old 07-17-2008, 01:28 AM   #4
2k1Toaster's Avatar
hot glue alone will not hold a screen.
If you busted it somehow, you can buy another casing. There is no substitute really.
are the little cylinders the screws go into broken, or just the backplate with the holes?
Maybe get some nuts from the hardware store, epoxy them in place, and then use a few bolts through some mounting piece making your own screw holes.
Old 07-17-2008, 07:45 AM   #5
hailrazer's Avatar
Take a look at this thread :
http://www.mp3car.com/vbulletin/fabr...-monitors.html
I posted an idea on it.
My 2007 Yukon XL setup. http://www.mp3car.com/vbulletin/show...64-5000-a.html
hailrazer is offline   Reply With Quote
Old 07-17-2008, 09:54 AM   #6
The back piece of the screen though adds a good inch an a half and I have less then half an inch clearance. It's not possible to put the back on no matter how I wing it. I will get you a pic so you can see what I'm talking about
That's a good idea but I already have the frame and everything molded into the faceplate. I will take a trip up to homedepot and see what I can come up with. You have a good idea though.
Old 07-17-2008, 02:07 PM   #7
pics please when you get a chance
"The text that you have entered is too long (12638 characters). Please shorten it to 10000 characters long."
Dam it!
"The text that you have entered is too long (10418 characters). Please shorten it to 10000 characters long."
ViViper1 is offline   Reply With Quote
Old 07-17-2008, 06:41 PM   #8
Never mind the fit between the faceplate and the screen was a perfect fit. When I popped the faceplate on it holds the screen in place perfectly. Almost as if the screen was made for the faceplate.
FAQ: Touchscreens explained RedGTiVR6 The FAQ Emporium 1 07-21-2008 10:10 AM
First impressions, bugs and features of Infill G4 & Street Deck 1.1.0.0 DAE51D StreetDeck 34 11-06-2007 02:42 PM
Blue Devil Skin RELEASED JohnWPB RR Skins 1005 01-05-2007 07:54 PM
Cheapest place for a 7" VGA touch screen? HACKTHS Input Devices 3 02-21-2004 10:05 PM
Looking for Goose Neck that will hold 10" screen Squeeky LCD/Display 0 04-24-2002 02:33 PM
