Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 03-15-2009, 09:59 PM   #1
customaudioman's Avatar
customaudioman is on a distinguished road
my new chrysler 300c xenarc monitor fab and cpu case
I sold my Honda accord two months ago, and step up to the big body 300c. Here is a link to my old car, the accord http://www.mp3car.com/vbulletin/fabr...-fab-pics.html
So with the 300c I wanted the monitor to be at eye level. I'm not a fan of monitors that are installed in lower radio locations. Due to the fact I have to look away from the road to see whats on the monitor. So the ac/ vents had to go. I relocated the clock and the esp/haz button to the middle of the bezel were the radio used to be.
This is the oem bezel in a stock 300c
Here it is mock up to be molded into the bezel.
here is the bezel filled in with abs plastic and a layer of bondo and spot fill putty sanded to 150 grit. I also molded two usb ports under the clock to charge phone, thumb drive transfers, 3g usb internet card or any other usb base device.
now shots of the bezel before primer/sealer and painted.
Now here is the finished bezel, painted to match the oem bezel color and the other trim parts inside of the car.(oem silver)
This is my new bezel for the 300c. It came out great. I put a good 4-5 hrs work time in this, cause I changed the positions of the buttons and esp buttons a few time. It should Have taken 2.5 hrs to get to the primer and paint stage. I will be installing it in the car in the next few days after I get all the streetdeck 2 software and other apps setup before install. Im working on the sub box and amp racks for the arcaudio amps. Here is a few shots of the equipment and cpu case, all arc audio
my custom cpu case
customaudioman is offline   Reply With Quote
Old 03-15-2009, 10:08 PM   #2
PaulF's Avatar
PaulF is on a distinguished road
That case fabrication is pretty sick. Nice work.
My Car (Just the audio install as of now)
http://paulfurtado.com/car/
Worklog:
http://www.mp3car.com/vbulletin/work...-work-log.html
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
PaulF is offline   Reply With Quote
Old 03-15-2009, 11:23 PM   #3
VENDOR - Nexations Creations
Nexson's Avatar
Nexson is on a distinguished road
Great Job on the bezel fab job. Is the paint bc/cc? or SEM
Brian @Nexations Creations
Specialist in Custom Interior Fiberglass OEM Replication Work.
AIM: Exus28
E-Mail: Exus28@aol.com
Nexson is offline   Reply With Quote
Old 03-15-2009, 11:35 PM   #4
The paint is base coat and clear coat. It was primed and then sanded. Then had a coat of sealer. Then the base coat and then the clear coat.
Old 03-16-2009, 03:57 PM   #5
VmtSquad's Avatar
VmtSquad is an unknown quantity at this point
Good job man!!! Nice OEM LOOK and shiny finish!!
Dont forget to post some installed pictures!!!
VmtSquad - I sold my soul to Honda!
Final Install
CarPC progress: 95%
VmtSquad is offline   Reply With Quote
Old 03-16-2009, 04:08 PM   #6
Ringfinger69 is an unknown quantity at this point
I DIGG IT !!!
Tight work.
Ringfinger69 is offline   Reply With Quote
Old 03-16-2009, 04:09 PM   #7
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Just Perfect!
How do you fill those big gaps on either side of the clock and the monitor?
treetop777 is offline   Reply With Quote
Old 03-16-2009, 07:02 PM   #8
PaulF's Avatar
I actually have some input for you...
I think you might have some issues with putting the fan that close to the PSU. The PSU's wires are going to stick out of there and unless they're tied pretty tightly in the other direction, they're probably going to get brushed by the fan a bit. Also, they might cause some airflow issues...
Maybe you should turn the PSU or move it over a little bit?
Worklog:
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
Old 03-16-2009, 10:35 PM   #9
This carputer is the same setup I've had for 3 years and counting. I just took it out of my accord when I traded for the 300c. I have the wires the same as I did then. I never had an issue with it being to close to the power supply. it there to keep it cool. I have this hooked up the last three summers in hot heat 95+ and never over heated once. I did replace the opus 150 psu for a new opus 180psu. I had to put a slim line 80mmx15mm fan to replace the old 80mmx25mm one. Need more room to mount the power supply.
Old 03-16-2009, 10:47 PM   #10
Quote: Originally Posted by treetop777 View Post
Just Perfect!
On the sides of the clock, I cut abs plastic to the size of the big gap and quick zap glue them in. The smaller gaps around the vga monitor bezel, I taped the front of the bezel with 3m green masking tape. I filled it in from the backside of the bezel with mar-glass filler ( short fiberglass hair putty/bondo). Then just peal the tape off after 20 minutes. The gaps are gone. Then I covered the bezel with light weight bondo. then sanded(blocked sand), filled any little imperfections after that.
Old 03-17-2009, 01:43 AM   #11
Sheepdog
rdholtz's Avatar
rdholtz is on a distinguished road
That's a very nice "custom cpu case" there. Could you give us more information on that, please?
If just enough is really good, then too much ought to be perfect.
2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
rdholtz is offline   Reply With Quote
Old 03-17-2009, 02:34 AM   #12
I have a company that builds them for me. They are made to fit micro-atx boards. The mounting hardware inside the case is design to hold a 3.5 hdd with Hard drive shock-reducing suspension , opus 150 or the new 180psu. Custom slim clear-anodized aluminum Micro-ATX enclosure, designed for maximum cooling and air-flow.
Dimensions: 12.0x11.2" footprint, 11.2x11.2x3.7" box. I sell these case for $149.99
Old 03-17-2009, 01:55 PM   #13
here of some more pics of bezel and monitor hooked up to the carputer in my house
I use streetdeck 2 as my frontend. It works better then the sd1.
Old 03-23-2009, 08:49 PM   #14
rgarjr's Avatar
rgarjr is an unknown quantity at this point
Very nice fabwork on the bezel man, looks hella tight. Where did you get that abs plastic to fill up those gaps? I'm digging the 2 usb ports on there.
My carpc worklog
rgarjr is offline   Reply With Quote
Old 03-24-2009, 10:12 AM   #15
I had some laying around from a old honda headunit kit. I used to get it in sheets of 12"x12"x 1/4", 1/8" for around $5- $10 depends on the thickness. I got mine from bestkits.com (aamp, stinger) I used to have a car audio shop, I would get all my kits and plastic from them.
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
Experiences with the Intel D945GCLF2 Motherboard and VoomPC2 case for Carputer/ CarPC analographi General MP3Car Discussion 11 07-04-2009 04:35 PM
cpu cooler touching case Touran General Hardware Discussion 4 03-07-2007 04:35 PM
cpu and case temps need more cooling? michaelrj9 General MP3Car Discussion 3 06-08-2005 09:31 PM
CPU & Case Temperature Sway General MP3Car Discussion 10 02-03-2004 03:25 PM
