Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 04-23-2009, 10:48 PM   #1
ThePistonDoctor is an unknown quantity at this point
Simple budget 350Z screen bezel
So my goal for this project was to be able to mount my 7" Xenarc in my dash, and have it look factory and be able to be completely hidden, WITHOUT taking the screen apart and voiding the warranty. I looked to Nissan for the factory navigation system cubby hole, but turns out it was $145 and would require me to take the screen apart anyway.
Enter the cheap man's fabrication!
First, I needed a way to mount the screen behind the dash so that the factory trim with my fabbed bezel would press flush up against it. Turns out the Xenarc fits perfectly in the spot where the factory cd holder/cubby hole is if you remove it. It just comes off the back of the dash trim with a few screws:
Now, if you have ever been in or worked on a 350Z you will know that it's a very compact car. There is very minimal room to do ANYTHING behind the dash after you remove the cubby. So, I had to come up with a solid but compact way to mount the screen where it needs to sit. I marked the edges of the dash and then fabbed up this little bracket with the help of some dremeling, aluminum strips from home depot, and a couple pop rivets (cost: $4):
Next, I needed to fill the voids around the sides/top of the screen. I also needed a "slot" at the top for the stock door to slide into to make it stealthy. I started with some cardboard mockups (cost: free):
Obviously, cardboard won't work. I needed something more sturdy. I thought about using liquid plastic, fiberglass, etc. Nothing seemed as simple as wood. My weapon of choice: 1/8" 5 ply birch plywood (cost: $9.99 per 8x12" sheet at a local wood shop) After some creative cutting, drilling, and sanding with a Dremel tool, I was left with this:
Some liquid nails ($3 at Home Depot), plastic epoxy ($3 at Home Depot) and eyeglass screws (free from Lenscrafters at the mall) brings it all together:
Next, a test fit...uh oh! I knew something didn't look right in that last pic.
Looks like I've got some more dremeling to do:
A couple more little wedge pieces cut from my 1/8" plywood, some wood filler ($3 at Home Depot), and some time and I have this:
Finally, the last piece across the top, and a layer of fiberglass RESIN (note, NOT cloth or mat, just the RESIN to seal any weak spots and solidify the whole assembly) and it's starting to look pretty solid. Some old left over resin will do the job, I only needed about an ounce and a few drops of hardener (call it $2 worth):
And the finishing step (which I haven't completed yet): I'll rough up the wood and paint it with some black acrylic adhesive paint, then flock it. Flocking, for those that don't know, is basically spraying on fabric. It's that fine felt-like finish you will find inside jewelry boxes. I got the applicator (sprayer), flocking fibers, and adhesive paint for under $15 shipped.
So, total cost:
$4 for the bracket
$10 for the wood
$9 worth of liquid nails, epoxy and wood filler
$2 worth of fiberglass resin
$15 for the flocked finish
$40 for a 100% functional bezel that will look factory, be stealthy and be a little bit unique/something to be proud of, while MAINTAINING THE WARRANTY ON YOUR XENARC. I'll post final pics once I get the flocking finished which hopefully will be in the next few days. I am waiting on the fiber to get here before I can do it!
As always, feel free to comment/critique!
ThePistonDoctor is offline   Reply With Quote
Old 04-28-2009, 06:53 PM   #2
Updated pics of the finished product! I gotta do something about the bracket that's holding the screen cause it's a little flimsy and doesn't push the screen snug up against the bezel, but overall it looks pretty sweet!
Old 04-28-2009, 07:24 PM   #3
dMand's Avatar
dMand is an unknown quantity at this point
Fantastic, It looks great!
You can glue sponge or similar material at the top back portion of the LCD, to give it a little pressure against the dash bezel that you fabricated, to keep it firm.
Good job!
dMand is offline   Reply With Quote
Old 04-30-2009, 01:04 PM   #4
Thanks! I'm really happy with the way it turned out. I'm going to head out and get some thin foamy type weather stripping to protect the edges of the screen where the wood presses up against it, and stiffen up the bracket with something like what you mentioned. Overall it came out great and was really cheap and not too hard!
Old 04-30-2009, 06:41 PM   #5
black_mamba is on a distinguished road
Wow! That looks pretty good, and simple. I'm thinking of doing something similar for my car. I also don't want to disassemble my Xenarc for my car since it's a company leased vehicle. The end of the lease is coming up and they'll be giving me another vehicle but I don't know what it'll be yet. I had started planning how to fab a baffle and mount the screen to it, but your idea with the bar is great in case my next car does not accomodate a baffle design.
black_mamba is offline   Reply With Quote
2007 Mazda 3 Dash Screen looks OEM Splash-X Show off your project 54 05-04-2009 06:29 PM
7" Touch screen in 2-din bezel for SALE gthing Classifieds 0 01-07-2009 11:50 PM
FS (Europe): CarPC parts - Subaru Custom Navi Bezel + Screen, TPMS Kit, accessories DeltaBi Classifieds 1 12-24-2008 08:21 AM
mAv1c - Ver. 1.06 Release 07/19/08 - less than 3.5MB total treetop777 RR Skins 116 08-07-2008 11:23 AM
WTB: BMW e46 Bezel for 7" LCD screen (xenarc etc) chiark Classified Archive 0 03-12-2007 04:54 PM
