Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 05-06-2009, 09:36 PM   #1
ibigpapa is an unknown quantity at this point
part locations
I'm looking for the connector to this light. I would like to buy just the connector or make it if need be. I have not had any luck in locating a vendor for it. Here is a picture of the connector i'm looking for.
Any help will be awesome
ibigpapa is offline   Reply With Quote
Old 05-07-2009, 10:15 AM   #2
Sheepdog
rdholtz's Avatar
rdholtz is on a distinguished road
This appears to be the kind of bullet-end bulb that you find in the overhead light fixture in your car. It takes a double-end mount, and I've seen two kinds; most prevalent is the sort that it just clips into -- the mount blades have indentations that hold the bulb in place and provide power. One end is hot, and the other grounds to the vehicle. You could also use a standard "fuse" type mount, but that doesn't provide fixed lateral positioning.
I suspect you could find these -- cheap -- in the auto graveyard, or possibly at an auto parts store by buying the whole overhead light fixture.
If just enough is really good, then too much ought to be perfect.
2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
rdholtz is offline   Reply With Quote
Old 05-07-2009, 08:57 PM   #3
Yes you are correct it is the bulb for a dome light or map light. to be specific this one is the 6418 I was hoping to find a supplier of just the ends instead of having to buy the replacements and then breaking them to get the part i wanted. I would even be willing to make them. have tried to contemplate doing so. Such as heating up pop cans so it would be malleable and then press a mold in it. don't know how well that would work but it's an idea.
Old 05-08-2009, 01:55 PM   #4
Sheepdog
rdholtz's Avatar
I misunderstood when you said you wanted the connector; I thought you meant the fixture that connects to it.
Unless you want a large quantity of them, you could still go through an automotive boneyard and get several bulbs. For a small quantity, it seems easiest to just bust the bulbs and take the ends.
How do you plan to use these?
Old 05-09-2009, 03:25 AM   #5
i'm planning on using them for leds with a control from a car pc in the end. special effects or just changing color for special reasons. you know like every geeks dream that making my car into a disco machine the girl in the passenger seat will mall me. the hard part getting her in there. i think a club will do just fine.
Old 05-09-2009, 08:16 AM   #6
qazaq9 is an unknown quantity at this point
why bother if they already available to buy, small led to fit in between those bulb sockets will cost u plus they will be a pain to work with since they are so tiny.
i don't want to promote anything but i bought my stuff here, some cheap leds for dash ect do not produce enough light so try looking for wide angle ones preferably with some kind of reflector
qazaq9 is offline   Reply With Quote
Old 05-09-2009, 08:16 AM   #7
http://www.superbrightleds.com/
M2-ATX PIC part number mpr90 Power Supplies 0 04-09-2008 01:23 AM
Looking for a Lilliput part blackcobra487 LCD/Display 4 03-06-2008 03:28 AM
The "I got laid off from Verizon" sale PART 2!!!! Defiler Classified Archive 9 10-20-2005 08:58 AM
Need Xenarc Part - please help! edrex LCD/Display 6 04-20-2005 03:59 PM
electronic part question~ help accord General MP3Car Discussion 4 06-06-2002 05:17 PM
