Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 05-18-2009, 04:20 PM   #1
MichaelPlace is on a distinguished road
How to cut a USB rectangle in a dashboard
I have a couple of these: http://www.datapro.net/products/usb-...e-a-cable.html
And i want to fit them to (cut a long story short) a dashboard piece thats plastic and screw into it so the only thing visible is the female USB socket and the two attaching screws.
If i invest in a dremmel router attachment will that cut the perfect rectangle?
It's going to be on show so I don't want the rectangle holes to look gash. Any other options?
I don't mind buying a different USB socket if it's going to be easier.
Cheers
MichaelPlace is offline   Reply With Quote
Old 05-18-2009, 04:56 PM   #2
Zogg's Avatar
Zogg is on a distinguished road
I made a metal plate for my dash that has 2 USB ports on it, using cables very much like in your picture, but taken from a PCI slot card faceplate.
I used the PCI faceplate as a template and drew the rectangle holes, then used a dremel tool to make the openings. The first one I did looked like crap but I learned how to slow down and move more carefully. The second one came out pretty good, although not perfect, but good enough for me. I used a flat file to square out the corners since they were rounded from the dremel metal cutting bit.
Good luck!
Carputer progress:
100% [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓]
Zotac N630I-D-E M/B w/ Nvidia 7100, Celeron 430 1.8 GHz, Xenarc 700IDT, M2-ATX, RR & DFX 4.0.
Zogg is offline   Reply With Quote
Old 05-18-2009, 05:23 PM   #3
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
I found these to be a lot more forgiving; you can make the hole undersized then file down untill the usb (female) end can wedge-in.
http://www.usbgear.com/USBG-AAE2C.html
treetop777 is offline   Reply With Quote
Old 05-18-2009, 10:13 PM   #4
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
It almost always looks better when you work from the back side. Well, you can mess up more.
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
Old 05-18-2009, 11:37 PM   #5
Sheepdog
rdholtz's Avatar
rdholtz is on a distinguished road
You have to be VERY careful with the Dremel, or you can overrun your lines. It's best to practice in some scrap similar to the dash.
Another approach that's less likely to produce a mistake (and the resulting expletives) is to simply drill two (or three) properly placed holes and file out the space between them. The drill diameter should be the the same as the width of the hole you want. Using a centerpunch on the dash to make dimples that mark the hole locations so the drill bit doesn't wander. You may have to hold a backer board in the area where you use the centerpunch.
If just enough is really good, then too much ought to be perfect.
2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
rdholtz is offline   Reply With Quote
Old 05-19-2009, 05:16 AM   #6
Crinos is an unknown quantity at this point
Be very carefull with doing this with a dremmel... You need skills and steady hands...
If you have not used a dremmel before... This is not the first thing to try it on... practice ALOT before you plan to do it on the actual panel.
Crinos is offline   Reply With Quote
Old 06-06-2009, 02:50 PM   #7
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
Cheers
OMFG, I'm glad I came across this post, I have been looking for something like this. My setup has 4 USB ports and 6 additional USB each for the independent systems. I have 6 extensions going to my center console but wasn't sure if they made the cable you pointed out. Now I can hide the 4-port hub also..... Thanx a bunch!
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 06-06-2009, 03:32 PM   #8
colin's Avatar
colin will become famous soon enoughcolin will become famous soon enough
For the record, HiJackZX1, there are much cheaper cables available at FrontX. Someone else posted the website a while back, and I ordered some USB extension cables from them for my dash. The look the exact same, are very good quality, and cheaper.
2001 Mustang Convertible Worklog
Indigo Custom Frontend (Flash/Delphi)
Blog
Code:
Currently: - Working on my new product! Wiring: |■■■■■■■■■■■■■■■■■■--| Trunk: |■■■-----------------| Sound: |■■■■■■--------------| Screen: |■■■■■■--------------|
colin is offline   Reply With Quote
Old 06-06-2009, 03:46 PM   #9
HiJackZX1's Avatar
Yea I saw that. FrontX has theirs for 7.00 a piece. What I needed was the name of this cable, which I didnt know till I found this post.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
USB hub problem always disconnecting / connecting fire General Hardware Discussion 10 09-25-2009 03:30 PM
Ultimate USB, Firewire, External Soundcard List durwood Car Audio FAQ 120 08-20-2009 01:09 PM
Install Windows XP on a USB Flash Drive kingofl337 WinNT Based 6 10-13-2008 04:14 PM
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 12:49 PM
False floor i3igmind Fabrication 29 02-04-2006 11:28 PM
