I'm not going to write a long article about perfect paint jobs... there's lots of them out there... google is your friend
But for short.
1. Sand down plastic for the primer to stick
2. apply PLASTIC primer. let dry for atleast 30-45 minutes.
3. use a mild grid paper and lightly sand it down.
Now... you will probably remove alot of the primer in this process, and that is OK!
4. apply plastic primer again, and let it dry for 45-60 minutes.
5. use even milder grid paper, and sand it down even lighter
PS: OK this is the hard part. Repeat 4-5 untill everything is nice and smooth.
6. apply plastic primer again.... let dry for about 30-45 minutes.
7. WET SAND it down with VERY high grid paper... 2000 or so is nice for starters.
8. apply a very thin coat of primer
9. wet sand it lightly with lots of water, and "as high as possible" grid paper.
10. Let dry, and wait a day or two.
For the color....
Basically the same thing... apply color, sand down, and repeat.. use finer and finer grid paper.
One should apply color about 3-4 times (thin layers).
Now... you should be ready for the clear coat, and a glossy finish. In fact, it should be as glossy that you could mirror yourselves in it
NB: I do NOT recomend this as a guid if you are going to paint something. Only as a referance... There is as said... Loads of "HowTOs" on google
