Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 06-23-2009, 08:24 PM   #1
Josiah is an unknown quantity at this point
CarPC Needs to Survive Severe Offroading
I don't want the hard drive's read/write head to scratch the hard disk and I don't want the fiberglass work to endure cracks. I'm thinking a SSD for a hard drive is the only way to go, but what else do I have to worry about in a CarPC build? Is there any suggestions as to products or extra reinforcement techniques you guys can give me? I just imagine a heavy LCD hanging onto my fiberglass work and flexing it until it cracks.
Is there anyone out there that has had any issues offroading with their setup?
And for the curious:
www.youtube.com/getstuk
http://i68.photobucket.com/albums/i4...turepismo2.jpg
http://www.youtube.com/GetStuk
Many custom lighting mods, custom fabrication, etc.
Josiah is offline   Reply With Quote
Old 06-23-2009, 08:43 PM   #2
North of the land of Hey Huns
malcom2073's Avatar
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
I would be careful if you have any PCI cards or even risers, they can vibrate loose so using some non-conducting epoxy or even a hot glue gun can help to prevent that. same with SATA connectors and some power cables. To be honest, if you get a shock resistant 2.5" drive, you probably won't have any issues. At my work we have some off-road vehicles which withstand severe hits, harder than any on-road vehicle could and we run 2.5" drives in them without issue. That being said, a SSD is never a bad idea for a situation like that, but you may be fine using a 2.5 hdd if money is an issue.
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
malcom2073 is offline   Reply With Quote
Old 06-23-2009, 11:37 PM   #3
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
use lots of silicone
and definitely use a SSD
blk02si is offline   Reply With Quote
Old 06-24-2009, 12:07 AM   #4
nalav's Avatar
nalav is on a distinguished road
Seagate makes a hard drive that might be to your liking.
http://www.seagate.com/www/en-us/pro...s/ee25_series/
nalav is offline   Reply With Quote
Old 06-24-2009, 06:56 AM   #5
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Those are still subject to skips and potential damage form extreme shocks.
They are better than most other drives, sure.
+1 for an SSD.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 06-24-2009, 10:02 AM   #6
Sheepdog
rdholtz's Avatar
rdholtz is on a distinguished road
I've attached my laptop drive with Velcro strips to provide a mounting system with more cushion. If I were mounting it for off-road use, I'd consider mounting the Velcro to a foam rubber pad -- like a mousepad -- and mounting the pad on Velcro. That would provide three layers of jounce protection to an already toughened drive; that should be pretty good.
I've watched some of your videos on YouTube, and you give that F-150 a pretty good bashing, but I don't see anything the hard drive couldn't handle if it had all that padding. Whatever you use, it should be motion-damping, so it doesn't allow the drive to just bounce around all the time.
And I agree with the others who say an SSD is pretty hard to beat, especially as a boot drive.
If just enough is really good, then too much ought to be perfect.
2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
rdholtz is offline   Reply With Quote
Old 06-24-2009, 10:22 AM   #7
thekl0wn's Avatar
thekl0wn is on a distinguished road
Severe off-roading? You drove through a mud puddle and had to bump an idiot out of his own holes...
Anyway, an SSD is gonna be in-order. And as far as the CPU mounting, you may want to look at some form of foam-mounting, just to dampen the vibrations that will be incurred. Placement is also a consideration if you take it through deep water, since there's always the risk of a pesky hole swallowing a side of the truck and having water in the floor.
As for your F/G work cracking, if you don't already have the work done, I'd look at having it done in more of a modular fashion, rather than one big solid piece which will flex and break... Having two pieces flex against each other is better than one solid piece flex. Using fender washers, increasing thickness, and metal mounting plates will help distribute the forces from the LCD mounting.
Planning [----X-----] 40%
Programming [-X-------] 20%
Parts [-----X----] 50%
Install [X--------] 5%
See Me In A Pink Skirt
thekl0wn is online now   Reply With Quote
Old 06-24-2009, 01:24 PM   #8
It's also going to make the HDD bounce more, increasing the chances of damage to the drive, skips, etc.
BAD IDEA!
Old 06-24-2009, 02:36 PM   #9
Sheepdog
rdholtz's Avatar
BAD IDEA!
That depends on the material. Velcro is resilient, but it doesn't bounce like a rubber band. Mousepad foam -- at least the ones I've seen -- are motion damping, not bouncy. Both materials allow motion, but damp the motion as well.
If the drive were hung on rubber bands, it would bounce all over, creating repetitive accelerations and decelerations. Yep, that's bad. But if a material cushions shocks and damps the motion, not allowing bounce, that's the material we want to use.
Damped motion is far better than impact.
Old 06-24-2009, 03:16 PM   #10
thekl0wn's Avatar
I'd have to side with rdholtz on this one... It's much like a vehicle's suspension. With no shocks, and only springs, hitting a bump will bounce your brains off the roof. However, combine the spring with the shock, and you've got a nice smooth ride. Basically, that's what the foamlike mounting would do: Provide enough rigidity to keep the needed placement, but have enough "give" when jarred to absorb much of the jolt.
Old 06-24-2009, 03:35 PM   #11
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
Just to throw this out there... my durabook uses a gel around the hdd to dampen movement. Hdd jello shock absorption anyone?
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Old 06-24-2009, 06:22 PM   #12
rodweb is an unknown quantity at this point
Have a look at this thread and scan it for posts from Thwack to get some feedback from somebody who drives offroad for a living. He joins in on Post #26.
I'd be looking for a fully self contained motherboard so you don't have to add any PCI cards, a SSD and take head of his advice.
Oh and maybe look at my Worklog to see how to connect USB devices.
Cheers
RodW
2007 Toyota Hilux with a CarPC..
Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
rodweb is offline   Reply With Quote
Old 06-24-2009, 07:23 PM   #13
corvettecrazy's Avatar
corvettecrazy is an unknown quantity at this point
I think a regular HDD would be fine in some foam, but if the budget is big enough for a SSD then by all means go for it.
corvettecrazy is offline   Reply With Quote
Old 06-24-2009, 08:36 PM   #14
I am glad I asked. I would have never thought about dislodged PCI cards or USB cables. A self contained mobo is going to be a priority, and looks like a must as well.
Does anyone have any idea what material cracks least? I am afraid I may have to go straight plastic welding and primer like the mastermind TurboCad did.
To be fair I'm gearing this towards offroading in Pismo which is another stomping ground it frequents. I can't describe the motion as "vibration" when a 6,500 lb truck jumps a few feet in the air. Also, according to what some people are saying, some of the videos on that youtube account of mine are enough to give a hard disk some physical trailscars of it's own.
Old 06-24-2009, 11:18 PM   #15
Flog me and kick me, it helps if I actually paste in the link I was talking about! Sorry about that!
Try this:
http://www.mp3car.com/vbulletin/gene...carputers.html
RodW
Hyundai Elantra GT CarPC cobase Worklogs 12 06-26-2008 04:13 PM
CarPC Front End Looks on Mass Production Radios lfilomeno General MP3Car Discussion 2 06-03-2007 10:25 AM
Should I CarPC or not? BobbyCreekwater Newbie 12 04-05-2007 11:00 PM
MP3Car CarPC State of the Union 2006 SwapMeet General MP3Car Discussion 30 10-18-2006 09:32 PM
Will I lose sound quality going to a Carpc with my Quality System? ddotderek Car Audio 34 09-01-2005 05:14 PM
