Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 07-09-2009, 08:38 PM   #1
528i_tourer is on a distinguished road
Protect my computer against a collision? Impact - car crash
Well guys i am searching a material that could satisfy my needs for what i am doing with my carpc now...will build a plexiglass (acrylic one) case to put my motherboard in there.....just put the pc on my car and then i need to have some kind of material that would protect my pc case against a possible car accident!
I am not worried about my computer!
I am worried about my car and pc electricity!!
So to avoid a broken pc touching my car (i mean electrical problems from that crash....) and having any kind of fire, i plan to build a case and put surrounding that case some kind of foam (??) to protect against collision! I guess an impact absorption material that would protect the case/pc from getting smashed....
Have you got any idead of any kind of material that could satisfy these need?
528i_tourer is offline   Reply With Quote
Old 07-09-2009, 08:54 PM   #2
csfile's Avatar
csfile is on a distinguished road
Where do you plan on putting the PC? If you mount it in an area where it wouldn't get damaged unless you're in a major collision, then you don't have to worry about making some kind of foam.
If everything is fused properly, wouldn't that prevent the electrical shorts from causing fires?
csfile is offline   Reply With Quote
Old 07-09-2009, 10:28 PM   #3
colin's Avatar
colin will become famous soon enoughcolin will become famous soon enough
If you get in an accident, chances are your wires will be trashed, your PC will snap in two, and your fuses will protect from fires. Make sure you fuse it right like csfile said and you'll be fine.
2001 Mustang Convertible Worklog
Indigo Custom Frontend (Flash/Delphi)
Blog
Code:
Currently: - Working on my new product! Wiring: |■■■■■■■■■■■■■■■■■■--| Trunk: |■■■-----------------| Sound: |■■■■■■--------------| Screen: |■■■■■■--------------|
colin is offline   Reply With Quote
Old 07-10-2009, 01:07 AM   #4
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
No worries if you fuse it properly. Any electrical short will blow the fuse and cut the power.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 07-10-2009, 01:14 AM   #5
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
I have 'crash' tested three installs... the PC was fine, much better than I did. Two of those totaled the truck... both with bent frames....
Worry about yourself, think no more on protecting the PC or the car from the PC. No need.
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 07-10-2009, 08:53 AM   #6
trader007 is infamous around these parts
i agree.. worrying about a computer at times when your life would be in danger sounds pretty ridiculous. just take some pictures of your install and send them to your insurance company if anything happens...
trader007 is offline   Reply With Quote
Old 07-10-2009, 09:36 AM   #7
joshuo is an unknown quantity at this point
Fuses... very SRS business.
But seriously, If the impact is anywhere close to the PC, it's gonna be trashed no matter how much tempur-pedic you cushion it with. Just fuse everything properly like mentioned before and you won't have any electrical fire issues.
joshuo is offline   Reply With Quote
Old 07-10-2009, 05:35 PM   #8
Ok guys!
I guess you didnt notice: i dont care about my pc...just care about myself of course....but that also depends on my car too..cause if there is a fire on my car...i may also be injured...
I have my pc on the rear, near the tailights...this is a wagon so i put in here
will go in here where is the multi cd player...so i guess in case of a rear colision or lateral one could have some problems or not...i just wanna prevent the pc parts from touching the frame....i guess its my major concern with electricity...so i would like to surround my case with some kind of impact absorption material if its worth the money and the effort of course.
in fact i also have all protected with fuses like the ones you can see in here:
Maybe i am overoverover worried with this but i like to prevent and dont take it easy on this....
PC is protected by a 30 A fuse...the green one!!!
Is this too much...my PSU can go 250 W on consumption....
Thanks!!
Old 07-10-2009, 08:54 PM   #9
TruckinMP3's Avatar
Nice an tidy on the wiring. I think you will be fine with the fused power.
In the unlikely event of a wreck that results in a short the fuse should do it's part.
Additionally, it is not like shorting the battery terminals, various parts of the PC will fail before the risk of shock and fire. This is also true of desk top installs.
Cheers
TruckinMP3
Read the FAQ!
Old 07-10-2009, 09:09 PM   #10
TheGuv is an unknown quantity at this point
I think your worries are pretty unfounded.. Your PC is running off of 12volts and pretty low amps... 30a fuse? My cig lighter runs on that and I don't worry myself about that! Plus the majority of materials I can see in your photos wouldn't catch fire in any event other than being soaked in petrol! And your tank is UNDER the car, so that's pretty unlikely too!
Seriously, nothings gonna happen lol.
TheGuv is offline   Reply With Quote
Old 07-11-2009, 01:19 AM   #11
PaulF's Avatar
PaulF is on a distinguished road
Thanks!!
Yes, you are overworried, yes the fuse is too big. Take a multimeter and check the amp draw on the computer during 100% cpu usage and maximum devices you will used connected. Find a fuse for either exactly or slightly more than that number. That way you're 100% sure that if something flukey is happening, the fuse blows. This is good for not just crashes but other things like faulty devices and whatnot.
30 amp fuse for cig lighter? Unless you've changed something the cig lighter circuit is designed for up to 10 amps. I've drawn 40 out of mine with a 40 amp fuse and DID actually have an electrical fire. Theres a reason why the car has the fuses it already has. Obviously, if you've rewired it and done your own thing it should be fine.
My Car (Just the audio install as of now)
http://paulfurtado.com/car/
Worklog:
http://www.mp3car.com/vbulletin/work...-work-log.html
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
PaulF is offline   Reply With Quote
Old 07-11-2009, 01:26 AM   #12
csfile's Avatar
Very important. Make sure you select the proper wire gauge to handle the amperage that you are fusing. If the wire burns up before the fuse is broken... For example, 30A fuse on 20 gauge wire is a bad idea.
Old 07-12-2009, 05:33 AM   #13
Came out of Ford like it... Got a socket in the dash, one in the glovebox and one in the boot... If what you're suggesting is right then for my car to have a 30a fuse is justified by the 3 sockets.
Old 07-12-2009, 11:31 AM   #14
PaulF's Avatar
That's weird but nice. On most cars they'll give a 10 amp fuse for all the sockets combined, which is highly annoying because each socket can actually handle 10 amps, but they just don't wire it correctly.
Worklog:
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
2000 Mitsubishi Verada Car PC Install MitchellO Show off your project 17 03-25-2009 01:40 AM
My experiences with Sideways AutoSalon of Austin Texas drakino Off Topic 5 03-02-2008 06:23 PM
Car computer vs regular head unit dlewis187 General MP3Car Discussion 6 12-11-2005 01:31 AM
Answer to all your car's needs : never loose your car again! Romeo Input Devices 19 10-27-2005 12:53 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
