Ford bezel rubber coating is not good
in my truck, the bezel has this rubberized coating on it from factory... and over the years it started to peel off on the edges. so when i hacked it up and formed it for a slide-out lcd, i didnt have much choice to remove the rubber coating.
and its been hell. i wasnt successful in simply sanding the rubber off with paper, so i used a dremel with soft wheel... most of the rubber was removed, but i left gouges all over the bezel... and only when i shot a coat of primer on i noticed the whole thing has little strips here and there of rubber still attatched. i basically ruined the bezel by creating the rocky mountains all over it.
ive been scraping each rubber peice off with my fingernail, and filling in every gouge for the last 5 days. i think part of my problem is im using bondo and enamel primer. the bondo brand bondo has a lot of downfalls to it... and the primer is hard to sand, but at least its adhering ok to the plastic. so if anyone is going to work on a ford bezel that has that rubber coating on it, dont do what i am.
