Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 07-23-2009, 12:46 AM   #1
pjoseph is an unknown quantity at this point
filler for fiberglass
i have built a home sub for my room out of mdf. I just painted the box with fiberglass to seal and to avoid the mdf from soaking up the paint.
I plan on painting it a shiny black using krylon primer, black lacquer paint, and clear coat.
I need some kind of filler (not bondo something lighter then that) to fill small pin holes and scratches. I read that you should thin out the filler and hand rub the entire box with the filler.
I would say the filler is really the only thing I am unsure about here so some specific recomendations would be helpfull.
Also how do you thin it out filler?
pjoseph is offline   Reply With Quote
Filler Material bcw757 Fabrication 1 11-13-2007 06:58 PM
Body Filler For Kick Panels? AltimateX Fabrication 1 10-21-2007 10:31 AM
Best adhesive and filler for my application eric111e Fabrication 3 05-17-2007 12:55 PM
Best adhesive and filler eric111e Fabrication 0 05-16-2007 11:15 AM
What filler to use? Meelobee Fabrication 23 10-27-2005 01:53 AM
