Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 07-24-2009, 08:04 AM   #1
NACvicSi is an unknown quantity at this point
Worth saving?
Well I picked up a "new" car recently (99 Honda Civic Si). The previous owner tried to mold a screen in, but obviously only failed. I plan on picking up a touch screen to install a carputer myself. Think this is salvageable?
NACvicSi is offline   Reply With Quote
Old 07-24-2009, 08:29 AM   #2
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
It's only the faceplate they have messed with.
You should be able to pick one up at a scrapyard (in fact I would recommend picking a couple up) and then work on it outside the car.
Have a look at some of the the tutorials and worklogs on here and you will see what can be done.
Even the one already in there can be salvaged.
Enforcer is offline   Reply With Quote
Old 07-24-2009, 08:36 AM   #3
Well they are impossible to find in a salvage yard around here. They are going for $130 on eBay which is just ignorant as that's the same price as a new one from Honda. I have looked through all the tutorials I can find on my car and looks like most mold them in anyways, so I am thinking it should be able to be saved, just wanted you guys view since you are the masters.
Old 07-25-2009, 12:47 AM   #4
VENDOR - Nexations Creations
Nexson's Avatar
Nexson is on a distinguished road
Of course that can be saved! Hell, that is what it looks like before the screen is molded in anyways!
Brian @Nexations Creations
Specialist in Custom Interior Fiberglass OEM Replication Work.
AIM: Exus28
E-Mail: Exus28@aol.com
Nexson is offline   Reply With Quote
Old 07-25-2009, 01:10 AM   #5
nobb will become famous soon enoughnobb will become famous soon enough
You can put a 7 inch screen in there perfectly. Take the bezel from your new screen, cut around it a bit to make it fit inside, add some epoxy/glue for structural strength, then fill it with bondo, sand flat, primer, paint, and voila you're good to go.
nobb is offline   Reply With Quote
Old 07-25-2009, 01:48 AM   #6
Hmm, I planned on using some epoxy as "filler" since I figured the expansion rates of bondo and plastic aren't the same and would just cause cracking.
Old 07-25-2009, 09:40 AM   #7
Vendor - C&C CUSTOMS
CabeSipes's Avatar
CabeSipes is on a distinguished road
Thats fine man. I could mold a screen in that in 2 hours flat. Take a DA and 120 grit sandpaper and sand the edges of the opening down to clean it up a bit. If your good with a router or drimmle use straight guides on the sides of the opening to straighten them up. Then your good to start your new plate with the screen opening.
CabeSipes is offline   Reply With Quote
Old 07-25-2009, 01:09 PM   #8
mdawg can only hope to improve
If not hit me up I got one for sell for $50 bucks. It has a tiny crack on the right side but other than that its fine.
mdawg is online now   Reply With Quote
Old 07-25-2009, 08:39 PM   #9
Nexson's Avatar
You should be fine with a little bit of bondo. In that particular area, there is not a whole lot of heat, like the top of the dash. Remember, don't use bondo as your "bonder". Use as little as possibly. Use your epoxy to get it strong and use the bondo to get a smooth surface for primer, and then paint.
Shoot me a PM if you need any help through the process, I can give you some great tips!
AIM: Exus28
Is CarPC worth the time + effort + $$$ ? coffeejolts Off Topic 27 06-17-2009 07:49 AM
Worth building a Carputer? jnymris Off Topic 7 04-20-2009 01:36 PM
Possible solution for saving files on EWF systems (without disabling EWF) SFiorito WinNT Based 12 03-16-2009 08:00 PM
Is name brand equipment worth it? ... NotYou Car Audio 2 04-11-2008 02:16 PM
Pure sine wave inverters. worth it? nzKAOSnz Power Supplies 3 10-27-2003 04:48 AM
