Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 07-30-2009, 08:32 PM   #1
meep's Avatar
meep is an unknown quantity at this point
About to cut my dash - advice required
Hi Knowledgable People
I'm installing an 8" lilliput in my HiLux (see blog) and need to cut a section out from my center console fascia, (the crossbar in the picture below).
I've no idea what the material is (certainly not wood!!) and I want to make the cleanest cut possible. Any advice on tools or techniques? Should heat be involved?
Thanks in advance
Peter
meep is offline   Reply With Quote
Old 08-04-2009, 03:03 PM   #2
kraimer21 is an unknown quantity at this point
if its not pvc plastic then some composite. You won't be able cut the excess piece and have a clean looking part without doing some molding/shaping/sanding/painting. If you do just want to cut it off, the cleanest cut you can probably get with a dremel and a steady hand.
good luck!
kraimer21 is offline   Reply With Quote
Old 08-04-2009, 03:36 PM   #3
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
had the same stuff in my altima years back. You can use a dremel with a cutoff wheel... but be very careful to cut right at the thinnest part of the joint to avoid having to sand too much away and ruining the angles.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 08-09-2009, 04:54 PM   #4
VENDOR - Nexations Creations
Nexson's Avatar
Nexson is on a distinguished road
I hate to be non-optimistic here, but I just see no way of cutting that woodgrain bezel and making it look clean after it is cut. Even I can't cut a 100% straight line. I have a really good steady hand with my dremel, but even after a cut, you will have little jagged ends that need to be sanded down. Anyways even if you don't sand them down, the inner cut edge will be white and not wood grain.
This is a tough one. I suggest molding it in and ditching the wood grain. Or paying some decent $, and mold it in and get it re-wood grained.
It is your choiuce, it depends on how anal you are.
Brian @Nexations Creations
Specialist in Custom Interior Fiberglass OEM Replication Work.
AIM: Exus28
E-Mail: Exus28@aol.com
Nexson is offline   Reply With Quote
Old 08-10-2009, 08:59 AM   #5
MindDrive's Avatar
MindDrive will become famous soon enough
^^^^^^^ if Nexson says "dont do it" then i really would listen to what he says.... look at his portfolio... its sick the way he makes oem projects look well... oem LOL
Props to ya Nexson for lookin out for this guy
MindDrive is offline   Reply With Quote
Old 08-10-2009, 12:24 PM   #6
Nexson's Avatar
Thank you!! I really value your kind words!!! I figure it is the least I can do to help out
AIM: Exus28
Old 08-11-2009, 09:15 AM   #7
meep's Avatar
Many thanks for the feedback everyone. I'm not too concerned about it being 100% oem, I'm happy to live with some rough edges - it's a work vehicle after all.
Old 08-11-2009, 09:21 AM   #8
strikeback03 is an unknown quantity at this point
I doubt that crossbar is solid, so you might have holes where the ends were once you cut it out.
strikeback03 is offline   Reply With Quote
Old 08-11-2009, 09:26 AM   #9
meep's Avatar
Oh, I know I will.
Here's a pic from a guy who's done something similar in the same type of vehicle:
I'm going to have to think about how I deal with that.
Peter
Old 08-11-2009, 04:55 PM   #10
Sheepdog
rdholtz's Avatar
rdholtz is on a distinguished road
Quote: Originally Posted by meep View Post
Oh, I know I will.
Peter
If you're willing to give up all of the woodgrain, you'd have the same issues he did. But there may be a way around that.
If you'd be willing to give up some of the woodgrain, you could make your modifications to get the parts smooth, keeping your work in a narrow area. Then choose a comfortable line around that area, and paint the edges you worked on. For instance, you might leave the face woodgrain, but bring the inner area to the dash color. You might even be able to scribe a narrow line between the two; if you could put a very dark gray or flat black paint (or ink, or tape) into that line, it would be a good visual demarcation.
Nexson can guide you on that. His version of OEM is often better than OEM.
If just enough is really good, then too much ought to be perfect.
2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
rdholtz is offline   Reply With Quote
Help me fab my dash, Nexson come plz TexasAggie Fabrication 22 07-23-2009 03:19 AM
Looking for advice on mini install in 1997 neon heres what ive done so far crzunch MacCar 3 03-16-2007 12:49 AM
Fs: Custom Escalade Dash & Carputer!! EsKALad Classified Archive 0 11-09-2006 11:24 PM
Fiberglassing over a vinyl dash tml240 Fabrication 14 08-30-2006 01:19 AM
2002 Silverado Custom Dash Bezel AZ_Silverado Fabrication 7 08-09-2006 02:46 PM
