Quote: Originally Posted by
juzlookzfazt
So I want to fabricate a couple ideas I have tossing around inside my head. How does one use one of these to fold sheet metal? I'm looking to buy 26 gauge sheet metal and I want to custom fabricate a lip for my car and an enclosure for a future car-puter. Can this be used to form an enclosure for a basic mini-ITX carputer setup?
Actually, that's not a real brake. That's a sheet metal lip bender, and it's good at producing a lip on sheet metal. The one I've seen has 3/8-inch and 1-inch slots. You insert a sheet in it, press the flat sheet against a hard, smooth surface -- like a workbench -- and then twist the bender upward to make a lip or flange. While it's good for making a lip, it isn't the sort of thing to make an enclosure; it's just too rudimentary.
For about $35 plus a few bucks in shipping, you can get a more useful tool: a small -- 18-inch --
bending brake from
Harbor Freight:
It's similar to the one
Bugbyte referred you to. I think you'd be a lot happier with that. It's a tool you can use to make the box in the video demonstration, or you could use it to make your enclosure. If you go that route, you'll probably want to invest in some clamps to hold your work on the brake, plus a drill and a pop rivet tool, as well.
On the other hand, $35 is more than enough to buy a beautiful aluminum ready-made
project box and lid from
Mouser.com, and that would be ready to modify for your PC:
Here's the
data sheet on them.
For more information on metalworking tools, see posts 603 through 617 of my worklog.
