Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 08-15-2009, 07:58 PM   #1
addnon is an unknown quantity at this point
Redoing vinyl on door panels (E36)
So I'm looking to redo my dove grey door panels in black pleather, but I'm not sure what material to use or how to wrap it really. I think the panels will be easy, but I'm interested in learning how to large pieces with curves (dash, center console). Do I need to use a heat gun? I was wondering if there was a guide on this anywhere...just like general tips.
My door panel looks like this except, gray:
Any pointers would be appreciated. Thanks.
addnon is offline   Reply With Quote
Old 08-16-2009, 10:53 PM   #2
Sheepdog
rdholtz's Avatar
rdholtz is on a distinguished road
Try and look for "vinyl upholstery tutorial" or "vinyl upholstery instructions".
One thing you might consider is spray coloring for vinyl. Instead of re-wrapping it, how about "painting" it?
If just enough is really good, then too much ought to be perfect.
2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
rdholtz is online now   Reply With Quote
Old 08-17-2009, 11:15 AM   #3
thekl0wn's Avatar
thekl0wn is on a distinguished road
I've seen good and bad results from the vinyl dye. As with everything else, it's all in the prep work.
Planning [----X-----] 40%
Programming [-X-------] 20%
Parts [-----X----] 50%
Install [X--------] 5%
See Me In A Pink Skirt
thekl0wn is offline   Reply With Quote
Old 08-17-2009, 12:42 PM   #4
I've looked into SEM and VHT, and I think I'll pass on those due to the durability issues.
Also, I want to cover my dash which is a hard plastic, and apparently neither of those two products leave a permanent finish.
Do they sell the vinyl at a place like Joann?
Old 08-18-2009, 10:38 AM   #5
Sheepdog
rdholtz's Avatar
Yes, I've gotten vinyl there, and they had several thicknesses of the foam padding you'll want to use.
Old 08-18-2009, 11:49 AM   #6
Maheriano will become famous soon enoughMaheriano will become famous soon enough
Try this as a pseudo guide.
http://www.civicforums.com/forums/7-...els-suede.html
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
Maheriano is offline   Reply With Quote
Vinyl trimming mk1fan Fabrication 1 10-20-2006 07:09 PM
Fiberglassing over a vinyl dash tml240 Fabrication 14 08-30-2006 01:19 AM
Vinyl information brentm Fabrication 1 04-15-2006 03:43 AM
99 Honda Prelude Carputer wrapped in Vinyl! SuperDave01 Show off your project 9 10-10-2004 03:19 AM
