Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 08-27-2009, 11:21 PM   #1
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
Bondo Glazing & Spot Putty. What can I do with it.
I had to repair a hole in a arm rest panel I made. I didnt know what to buy, so I bought Bondo Glazing Putty and I filled in the hole, and the paint to match the arm rest. I think I did a very good job, it was easy to use and hardens very strong. I was wondering if I can use this for large applications, like filling a long hole. Also can I use this to make a shape? Anyways, give me feed back on what to do. Here is a pic, its my first time, so be nice.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 08-28-2009, 12:00 AM   #2
bratnetwork's Avatar
bratnetwork is an unknown quantity at this point
glazing putty is basically just really thick paint. it is not meant for filling, shaping or such things. its purpose is really just to fill in sanding scratches and leave a smooth surface to paint over. I don't think it has the strength to hold up over time as a filler or shape.
bratnetwork is offline   Reply With Quote
Old 08-28-2009, 01:34 AM   #3
trader007 can only hope to improve
dynatron 660, as mentioned here a lot, is by far the most amazing epoxy i have ever used. you can literally make plastic parts out of the stuff, and they will be stronger then any of the plastic in your car. its also some of the strongest adhesive ive used. i would bet dynatron could even repair broken side mirrors... where the plastic mounts just snap off.
trader007 is offline   Reply With Quote
Old 08-28-2009, 02:05 AM   #4
HiJackZX1's Avatar
But do you have to mix it like bondo? What I like about this tube is that its already made, just squeeze out the tube.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Epoxy Putty: Guidance to Easy Fabrication for Carputers/Bezels *56k Warning* Nexson Fabrication 28 09-04-2007 11:10 PM
What is Bondo.. ryan-neil Fabrication 24 04-07-2006 06:22 AM
Bondo Applicatin Question jmciver Fabrication 3 02-16-2006 07:58 AM
used too little hardener for the bondo fullgrown Fabrication 10 08-01-2005 03:37 PM
Very Unique Bondo Problem! Paint Screwing it up? Grayscale Fabrication 24 01-09-2005 12:34 PM
