Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 09-15-2009, 08:01 PM   #1
Punky is on a distinguished road
How to cut little rectangles out of PC case
Looking to add a few more usb port onto the side of my carpc case. it's a metal and seems quite tough. Would the Dremmel be the right tool? Looking to make decently clean cuts.
Thanks!
Punky is offline   Reply With Quote
Old 09-15-2009, 08:16 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
A dremel and a steady hand.
Go slowly and let the cutting wheel do the work.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 09-15-2009, 08:19 PM   #3
The little metal wheel is what i'm looking for right?
Old 09-15-2009, 08:41 PM   #4
If you mean the metal-cutting wheel that is impregnated with fiberglass strands (I believe that's what they are!), then yes.
You can use the regular cutting wheels, too, but they will wear out faster.
Old 09-15-2009, 09:50 PM   #5
justchat_1 will become famous soon enough
Regular cutting wheels can also shatter so its probably better to go with a metal cutting wheel. The metal cut off wheels are either diamond (the good ones) or fiberglass and should be alot more durable.
openMobile - An open source C# Front End
- Currently Recruiting Developers -
Available for download on sourceforge
justchat_1 is online now   Reply With Quote
Old 09-15-2009, 10:08 PM   #6
hailrazer's Avatar
hailrazer is an unknown quantity at this point
Even with a dremel with cutting wheel, you will want to have a nice file set on hand. Cut the rectangle just a tad small and then file it to perfection.
My 2007 Yukon XL setup. http://www.mp3car.com/vbulletin/show...64-5000-a.html
hailrazer is offline   Reply With Quote
Old 09-15-2009, 10:28 PM   #7
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Personally I would use a drill bit the diameter of the width to drill out most of the slot and then use the files.
Maybe use the cutting tool mentioned above if you have left a lot of metal between the holes made by the drill.
Enforcer is offline   Reply With Quote
Old 09-15-2009, 11:39 PM   #8
Found them, mine is a little bit too big for a small hole.
yeah i have the fibraglass one.
yeah i'll use the dremmel's grinding blocks to file it.
I think i'm going with this one, i have a drill bit just the right size. and i'll finish with the grinding blocks.
Old 10-27-2009, 05:14 PM   #9
RonsRed88's Avatar
RonsRed88 is an unknown quantity at this point
I bought one of these yesterday from Harbor Freight Tools. It says use a 3/8 inch pilot hole which is a little too big for USB so I used 1/4 inch and squared it off with some needle files and then used the tool.
http://www.harborfreight.com/cpi/cta...emnumber=97636
I cut some perfect rectangles in light sheet metal. Should work great for plastic too if it isn't too thick.
Ron
RonsRed88 is offline   Reply With Quote
FS: OPUS Mini-ITX Vehicle PC Case w/ built in 120w power supply / DVD+RW Drive jlucio Classified Archive 0 02-02-2007 06:32 PM
