Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 09-20-2009, 03:46 PM   #1
ShatteredK is an unknown quantity at this point
Fiberglass Enclosure Body filler with resin?
Alright, I just want to know if it's a good idea to mix some fiberglass resin with a body filler and the put it on the subwoofer enclosure after all the fiberglassing process. Or should I just stick with plain body filler? (The subs are s15l7 so I need a lot of strength to the box).
ShatteredK is offline   Reply With Quote
Old 10-22-2009, 05:52 PM   #2
djvillar's Avatar
djvillar is an unknown quantity at this point
Body filler and resin, aka sludge, will make the shaping process easier but won't give the box any further structural integrity. All the strength is in the glass. Not even the resin,.. the resin is just the bonding agent.
If you want the smoothing process to be super easy, try to stretch the clothe over the frame in one piece, soak with resin, let it harden then add all layers of fiberglass on the inside. Keep adding layers till theres no flex at all when you push against a single point with your thumb. At most you might need a super light skim coat on top of the top layer to smooth it all out.
djvillar is offline   Reply With Quote
Old 10-27-2009, 05:55 PM   #3
thekl0wn's Avatar
thekl0wn is on a distinguished road
djvillar covered most of the topics (and correctly too!)... Though I've heard the filler/resin mix called sludge, I most often hear it called a milkshake.
Planning [----X-----] 40%
Programming [-X-------] 20%
Parts [-----X----] 50%
Install [X--------] 5%
See Me In A Pink Skirt
thekl0wn is offline   Reply With Quote
filler for fiberglass pjoseph Fabrication 0 07-23-2009 12:46 AM
Fiberglass Sub Enclosure project shillier Fabrication 26 02-06-2009 04:30 PM
Fiberglass and MDF sub enclosure walkthrough monkeyracer Fabrication 28 05-19-2008 03:55 PM
fiberglass enclosure musthavsound Fabrication 2 04-04-2008 10:05 AM
03-05 Honda Accord Fiberglass False Floor...WIP 98EXL Fabrication 19 03-20-2006 09:11 PM
