Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 10-22-2009, 10:46 AM   #1
keithbrown is an unknown quantity at this point
USB install
Looking to install a usb extension into the cup holder section of the center console...what is the proper way to cut a hole and install a female USB plug.
keithbrown is offline   Reply With Quote
Old 10-22-2009, 12:24 PM   #2
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
i like to start the hole with a one size smaller drill bit, and then make the hole square with a jigsaw blade. it is slow, but is more precise.
soundman98 is offline   Reply With Quote
Old 10-22-2009, 12:26 PM   #3
thank you...
because i haven't tried this yet...do i need to make a bracket for it (USB extension cable) or will it stay in on its own...im getting mixed information on this.
Thanks again!
Old 10-22-2009, 12:33 PM   #4
bratnetwork's Avatar
bratnetwork is an unknown quantity at this point
it depends on what type of usb ports your using. I bought a cheap usb wall plate from china off ebay. I popped the ports out of the place and cut the same size holes in the dash. The ports were held in with snap rings and then soldered the cable to the corresponding pins on the ports and it works great
bratnetwork is offline   Reply With Quote
Old 10-22-2009, 01:09 PM   #5
soundman98's Avatar
i use the usb ports off the front of old computer towers--there are literally a million different designs for holding the ports to the front-- i have ones that the port gets screwed to the front mounting plate, ones that the pc board for the ports gets screwed down, and ones that snap in. if you could post a pic of the ones your working with we might be able to help you a little more with how it should be mounted.
also, you said that you wanted to put it in a cup holder-- make sure that there is no easy way for liquids to get spilled, and fall into the port.
Old 10-24-2009, 06:59 PM   #6
smartass365's Avatar
smartass365 is an unknown quantity at this point
Needle files work great for finishing up the hole. I have a square file with two opposing surfaces ground smooth and flat that gets more use that any of my files and rasps. It works perfect in those corners.
2003 Chevy S10
Truckputer Progress:
Planning.......[----------X] 100%
Parts...........[---------X-] 99%
Fabrication...[---------X-] 99%
Upgrades.....[X----------] 1%
smartass365 is offline   Reply With Quote
Vista x64 USB driver install Ipes Mp3Car USB adapter for XM Direct 0 05-18-2008 12:49 PM
Lilliput 619 USB/Driver Problems? Let's research this... (unknown device) akula169 LCD/Display 10 11-20-2006 06:14 PM
USB TOuch Screen not working after install? belezeebub Input Devices 2 10-01-2006 03:14 PM
Delou Routis GPS USB install issues, please help... jedi7001 GPS 8 03-26-2005 11:29 AM
DLink USB Radio: Install Problem or Bug? millec ME Archive 7 06-01-2003 01:37 AM
