The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Thread Tools Display Modes
Old 06-05-2004, 11:42 PM   #1
Vehicle: Mazda 6
My Photos: (0)
Spare wheel well project (In works)
Just thought I'd post some pics of what I'm doing, might be of interest to someone looking for a solution. (Thanks to Snootch for helping out with info!
Step 1: Sound deadening the trunk floor
BlueSkin - Found at local Lansing. Seems like great stuff so far, no smell at all, goes on easy. In the end I decided to buy a 9" roll, and glad i did. anything more would cause even more problems around all the curves in the wheel well.
2 Layers of BlueSkin later. A heat gun helped a lot to reveal all the air bubbles and to also just get it all laid out nicely. Just dont overheat the stuff, it burns right through the top blue layer and you have exposed hot tar -> Not good.
Step 2: Fiberglass Mold
Tools! That mask is a must, trust me.
Mask off the area with multiple overlays.. just to be safe.
Foil + more masking tape = a definite must and a life saver in getting the mold out.
Applying first layer... Resin the surface apply the fiberglass and than saturate it with more resin. Precut all the fiberglass before you mix the resin. (Also I didnt do precise measurements on my resin mixes, but as a rule of thumb i always put a bit too much hardener. It's better if it dries in your tray than having it not try at all with fiberglass in place.. Having said that, dont put too much. I made that mistake when i mixed 8oz of resin, managed to get about 3 sq ft done and than the stuff just became like a rock
While the glass was drying i decided to open up some packages i recieved this week from honk kong
LED Sills! Look even better than I anticipated! Will install once I do my speakers
After about 40 minutes i just pulled out the entire mold. As you see the foil helps a lot as there is nothing holding it behind. (Masking below is just for your own security). One tip.. Start by putting the foil around the edges and mask outside edges to the first layer. From there lay more foil and connect each piece to each other, without touching the first layer. That way.. All you have to do if you didnt have any leaks that is.. Is just tear off outside edge masking tape and effortlessly pull out the mold.
Mold after some cleanup, removed most of the tape and foil.
Test fit! Perfect
-- End of day 1. That was enough for one day. I'm going to apply the second coat tomorrow, i think 2 should be enough for my project.. And start MDF work to build up the structure.
VIA Epia II
256MB 266DDR Ram
90GB Wester Digital
Bluetooth/Deluo GPS
Lilliput 7" Touchscreen
Mazda 6 Carputter > Click Me!
[iG] is offline   Reply With Quote
Sponsored Links
Old 06-06-2004, 01:24 AM   #2
Top Ramen
lgbr's Avatar
Vehicle: 1991 Toyota MR2 Turbo
My Photos: (0)
Good job. Let me know how that sound deadener works for you.
Why are you fiberglassing that spare tire wheel well? What do you plan to put in there?
Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
Head units are for cheaters!
Quote:
sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
lgbr is offline   Reply With Quote
Old 06-06-2004, 10:47 AM   #3
Vehicle: Mazda 6
My Photos: (0)
My 2 JL Amps + carputter
VIA Epia II
256MB 266DDR Ram
90GB Wester Digital
Bluetooth/Deluo GPS
Old 06-06-2004, 10:52 AM   #4
Vehicle: BMW
My Photos: (0)
and if you get a flat tire ??? hehe ....
(a pump does not always help)......
I guess you'd call a towing or service place ...
Q_gamelogic is offline   Reply With Quote
Old 06-06-2004, 11:10 AM   #5
binary.h4x's Avatar
Vehicle: 2007 Honda Fit Sport
My Photos: (0)
binary.h4x is offline   Reply With Quote
Old 06-06-2004, 11:14 AM   #6
Vehicle: BMW
My Photos: (0)
Quote: Originally Posted by binary.h4x
have you actually used that ???? I wont let that touch my inner rim ....
of course ..... I maybe the few that dont like that thing (or maybe the only person .. heh .. then it'd be very sad)
Old 06-08-2004, 02:48 PM   #7
Snootch's Avatar
Vehicle: 2000 Pontiac Trans Am
My Photos: (0)
[iG]: Good job so far! I'm glad that the blue stuff worked out for you. Looks like youv'e got the hang of fiberglassing. Can't wait to see how it comes out. P.S.: how do you plan on finishing the inside? with matching carpet?
WORKLOG
VIA SN18000/1Gb GEIL PC3200/100Gb 2.5"HD/8" Phylon TS/BU-353 GPS/Powermate/M2-ATX PS
Webpage
Snootch is offline   Reply With Quote
Old 06-08-2004, 03:39 PM   #8
My Photos: (0)
MAN...i plan to do the same thing to my honda....
plan to put my amp and one 12 sub...hope i have enough room....haven't measure yet...cuz now i am molding my console putting my xenarc and headunit in...
u beat me to the beat.....
ehehehee...
good job....
icet
icet is offline   Reply With Quote
Old 06-08-2004, 04:55 PM   #9
srcstc's Avatar
Vehicle: 00 BMW 323Ci
My Photos: (0)
That BlueSkin looks like good stuff. What's it normally used for?
Rich
srcstc is offline   Reply With Quote
Old 06-10-2004, 09:54 AM   #10
Vehicle: Mazda 6
My Photos: (0)
Yep, so far so good with BlueSkin! Fiberglass came out alright, found quiete a few air bubbles i didnt notice at the time, but for this project it's not vital, i just need a mold so i can mount all the stuff, it's not that structurally important.
I -was- planning to do the glossy finish inside.. heh. I did a quick sketch in corel before is started this to check the area i have and it seemed alright. However now that i have the mold and after I did a quick mockup of what it's going to be.. It doesnt look like i have that much free area in there at all. Which means that if i do the gloss... You'll barely see it.. and for the amount of work that will go into it, it's not worth it. I dont think I'm going to carpet it, though thats not something I really considered (will look into). I think i may go out and buy some of that foam stuff and just lay it out around all my parts.. Hmm. Not sure yet! heh. Once i get all the mdf done and my parts laid out i'll decide!
ehehehee...
good job....
icet
Hmm, i dont think putting the amp in the same well as the 12" would be a good idea. First off there is not that much space in there, so you might need the full volume of that well. Depends on the sub i guess! Remember that you need to vent the well also if you're going to throw the amp in there.
srcstc:
http://www.bakor.com/residential_weatherbarrier.asp
Weather barrier
VIA Epia II
256MB 266DDR Ram
90GB Wester Digital
Bluetooth/Deluo GPS
Sponsored Links
Old 06-21-2004, 06:22 PM   #11
Vehicle: 1999 Honda Accord Cpe
My Photos: (0)
i wouldn't leave my house without a spare tire. Especially, when last memorial day i got a blowout in the middle of nowhere in upstate ny (25 mins from the canadian border). Being that nothing was open. I drove 400 miles on a donut (in the rain). Fix-a-flat wouldn't have done squat. I'm thinkingabout keeping a full-sized spare (17" rim!).
However, I respect the creativity. It's going to look cool.
mykolJay
99 Accord coupe
http://www.geocities.com/accordpc
My Project Thread on mp3car.com
mykolJay is offline   Reply With Quote
Old 06-22-2004, 11:00 AM   #12
Top Ramen
lgbr's Avatar
My Photos: (0)
Hondas have a lot more room under the trunk. right now I have a spare tire, my motherboard, power supply, hard drive, and and cdrom drive under there. I don't think it would be a problem to fit subs in there. I plan on taking the spare out and putting a second battery, both my amps, and my computer in the trunk.
Old 06-22-2004, 03:08 PM   #13
Vehicle: Mazda 6
My Photos: (0)
Wow, thats a lot of space!
I actually finished my project 2 weekends ago, but i didnt have the camera handy while was making it. Come to think of it, sec, i'll post a pic
VIA Epia II
256MB 266DDR Ram
90GB Wester Digital
Bluetooth/Deluo GPS
Old 06-22-2004, 03:18 PM   #14
Vehicle: Mazda 6
My Photos: (0)
Here:
I actually changed my plans while i was workin on the project. I decided to keep the box i have now for the carputter and at later date make a fiberglass enclosure on the side (same spot as the box now) for it. The spare wheel well is now reserved for 2 JL Amps/cap and the rest of wiring i need to hide.
You can actually see some structure in one of the pics.. You wont see it once the amps are in The window is just the right size to show both of them and nothing else.
VIA Epia II
256MB 266DDR Ram
90GB Wester Digital
Bluetooth/Deluo GPS
Old 06-22-2004, 06:56 PM   #15
Snootch's Avatar
My Photos: (0)
Looks good man, glad everything worked out alright! Post up a pic when you get the amps/subs installed!
P.S. you wouldn't happen to need some JL 12"s now would you? (Hint, Hint )
WORKLOG
Webpage
Sponsored Links
vB code is On
Trackbacks are Off
The Vectra CarPC / CarPuter Project v2 ccsnet Show off your project 28 08-29-2005 05:46 PM
Carputer as a comp sci final year project? MikeHunt79 General MP3Car Discussion 5 06-23-2004 09:19 AM
Hello!! CarPC project pics inside. bobbykokinos Newbie 11 03-29-2004 11:44 AM
RLion Project Webpage Reactor General MP3Car Discussion 0 02-18-2004 05:43 AM
Resumer Winamp plugin..works with MPC, too Tony S Software & Software Development 7 03-30-2002 05:10 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
