Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Notices
Old 06-10-2004, 09:08 AM   #1
freestyler's Avatar
custom Jeep TJ dash
Well seen as my opus decided to die I decided to finally get ambitious and do some glass/bondo work. It turned out alright, however, I still need to resand a couple of spots to smoothen it out....
all of the images can be found here
1997 Jeep Wrangler Rugged Waves
Ebay Stuff For Sale
freestyler is offline   Reply With Quote
Old 06-10-2004, 09:12 AM   #2
b_nom's Avatar
What are you going to do about the a/c vents? are you just going to block'em? I have a 00TJ, and I will probably put a carputer in it (after I recoup from the last one ), so I'm thinking of methods of installing it.
'96 Chevy Cavalier - EPIA M10000, Win2K,MediaCar, Deluo GPS Mouse with Routis, 60GB external HD, 7" widescreen monitor from DigitalWW.
'00 Jeep Wrangler - planning stage
What can BROWN do for you?
b_nom is offline   Reply With Quote
Old 06-10-2004, 09:13 AM   #3
freestyler's Avatar
undecided....hehe...i was thinking about going to the junkyard and finding some rectangle vents, but in all honesty ya don't need them? for me I have used my A/C maybe 3 times in the 3 years I've had it? And in the winter time the heat is a little too intense at times so I dont think I'll miss them, we'll see though!
Ebay Stuff For Sale
Old 06-10-2004, 10:08 AM   #4
Fender2Martin's Avatar
I am thinking about doing something similiar.... getting rid of my center AC vents.. sadly i use mine ALL the time.. but if i get rid of them i have a TON of room now behind the dash where i can plae the entire carputer.... my problem comes in... if i leave my vents open there (dont block them off with ABS or something) then when i have the AC on... it will help in keeping my carputer cool which is good.. HOWEVER when its winter i will ahve the heat on.. and that will heat my puter.. and thats no good.... anyone have any suggestions?
I may go to a junk yard and see if i can pick up some vents from a differennt style and work them in....
Fender2Martin is offline   Reply With Quote
Old 06-13-2004, 10:59 AM   #5
WOW Blake that looks awesome. I was following your install for some time now and it looks really cool. Here in FL though I NEED those vents, so I was thinking about doing one of a few options, replace the headunit entirely, Mount it in the same location you did, but replace the vents with two round ones from a mitsubishi, or go above the vents with a custom enclosure.
How is this with glare, any issues? I also noticed you have it sitting flat in the dash rather than angled towards you slightly, has that caused any issues?
Based on your computer specs, it sounds like you went with a desktop HD rather than a laptop HD. How is that working out?
Man I can't wait to get started on mine now!!
-lurking getting ideas for my jeep tj computer
http://www.suncoastflatlanders.com
CarlB is offline   Reply With Quote
Old 06-13-2004, 04:59 PM   #6
freestyler's Avatar
Well.....funny story, I got the dash done and the Jeep dies on me! Well sort of, I keep blowing the automatic shutoff fuse on crank, so it's at the stealership now and I didn't get to test it at all.
However, the two side vents blow pretty damn well now with the two middles being plugged, I dont think it's going to be that big of a deal. I would say move the vents to the sides of the screen instead of messing with the HU, you will have to move the vents anyways doing it that way.
As for glare, I think there will be the same amount as my old location with the top down, but with the top up I think it will look fine. Hopefully I'll have my Jeep back midweek and then I'll have my opus back too and can finally try it out!
I'll post some glare pics once I get it back.
Ebay Stuff For Sale
'93 Opel Vectra A - Custom Dash & Custom Case zvi Show off your project 14 10-18-2005 08:36 AM
Does this Custom Dash Pass the the MP3Car test? antimatter Fabrication 20 12-22-2004 02:34 PM
2003 G35 Sedan Custom Dash And Computer Izik Show off your project 57 08-22-2004 01:45 AM
1997 Jeep Cherokee - Custom In Dash SeeBQ Show off your project 26 11-13-2003 04:11 PM
custom dash making.... ifnh573 General MP3Car Discussion 1 10-13-2001 01:39 AM
