Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Notices
Old 07-06-2004, 03:40 PM   #1
djXternal's Avatar
carbon fiber
Ok I was reading on this site: http://web.njit.edu/~cas1383/proj/FAQ/index.htm
And He Said Laying Carbon Fiber And Fiberglass was the exact same...
Has anyone had experience with laying carbon fiber? I was gonna make my sub enclosures out of fiberglass with a layer of carbon fiber over it to make it look nice, and was wondering how hard or easy this would be
djXternal is offline   Reply With Quote
Old 07-06-2004, 04:20 PM   #2
my dad has done it and he said its the exact same...
why would you layer CF over fiber? why not just make it CF? i cant imagine it would take much more CF to make it strong enough.
jrich523 is offline   Reply With Quote
Old 07-06-2004, 04:59 PM   #3
dodgetimes2's Avatar
Because fiberglass is much cheaper, this would be similar to putting veneer over MDF instead of using sold hardwood, much more economical.
1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
dodgetimes2 is offline   Reply With Quote
Old 07-06-2004, 05:00 PM   #4
djXternal's Avatar
exactly
Old 07-07-2004, 03:15 AM   #5
first thing, make sure you use epoxy resin, not polyester. the epoxy is less thixotropic, and can wet teh fibers much better than polyester. the medium cure side B should dry the clearest, fast and slow cure will yellow slightly.
I reccommend leaving a texture, rather than finishing glass smooth. itll lose the 3d nature of the carbon, but it will look totally awesome and be unique from liek a carbon hood or something.
when you cut it, cut it WAY big, the fibers will jsut call out on teh edges. furthermore, dont even lay anything on the carbon. when I was cutting carbon, I laid the scissors right on the cloth, and hte hinge screw on teh scissors tore the carbon and put a permanent dimple in it.
go out and get yourself a squeegee, itll make your job 10x easier. the carbon is a weave, so it will conform to compound corners. once dry laid, you can pour your epoxy on and spready it with the squeegee. always always always make sure its uniform, never ever do a thick layer of resin. you are jsut asking to get nonuniformities, and once you ahve to sand, you ruin the finish without boatloads of work.
good call using it as a veneer, make sure your glass under is vinyl smooth, carpet smooth isnt good enough.
and good luck!
WhiteRabbit is offline   Reply With Quote
Old 07-07-2004, 03:25 AM   #6
SAScooby's Avatar
where does one buy the raw carbon fibre from ? and from my understanding of the process involved, the carbon fibre made the way fibreglass is made wont be as strong as carbon fibre made the way the professionals do it, in an autoclave
Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
FS = MTSVO motorised in dash screen pm me for details
SAScooby is offline   Reply With Quote
Old 07-07-2004, 03:36 AM   #7
You can buy basically everything you need here http://www.icancomposites.com/
and you can also check this forum for very helpful tips/tutorials http://www.carbon-werks.com/forum/
Lexus SC400
ACleanSC4 is offline   Reply With Quote
Old 07-07-2004, 04:31 PM   #8
i like a local brick and mortar store www.tapplastics.com
Old 07-07-2004, 05:30 PM   #9
Raw Wave
Spaghetti's Avatar
Location: Spagcave, in da UK Today's phrase: J'aime Alizee
That carbon-werks site is amazing! I never knew you could do stuff like that at home!
Spaghetti is offline   Reply With Quote
Old 07-07-2004, 05:43 PM   #10
bathbiggles's Avatar
where do autoclaves come in then? i thought these were essential in cf work?
bathbiggles is offline   Reply With Quote
Old 07-07-2004, 05:50 PM   #11
EBFoxbat's Avatar
Real carbon fiber is cooked. It's also very expensive (especially when layered) However it is RIDICULOUSLY strong... hence all the military applications.
'04 Canyon 4x4 pickup
[---PC on hold----working on external fiberglass "tool" box---]
EBFoxbat is offline   Reply With Quote
Old 07-07-2004, 06:55 PM   #12
its cooked because its prepreg. we can get the same results without furnace curing by using a catalyst
Skin Presentation Thread frodobaggins FrodoPlayer 298 10-27-2004 08:44 AM
carbon fibre skin chris-uk MediaCar 0 05-25-2004 05:41 AM
What material to make bezel with? wysocki Fabrication 9 05-14-2004 12:57 PM
carbon skin liquid_smoke ME Archive 7 01-13-2004 04:22 AM
Buying fiberglassing and carbon fiber products.. TintedChrome General MP3Car Discussion 5 01-15-2003 03:56 AM
