Quote: Originally Posted by boomboom
can you bondo on top of tin foil??
It might stick, but I don't think it's going to come out the way you want... There are materials better suited to making molds... And by the way, the cost of the bondo to make a replica of your faceplate is likely more $$$ than just buying the faceplate, as well is being inferior and likely very brittle. And a lot more work.
It's a good idea in theory, but if I were you, I'd look for other options.
EDIT: And by the way, I might have a totally wrong idea about what exactly you're trying to do with Bondo... Could you post a picture of the spot?
