07-30-2004, 08:04 AM
#1
Vehicle: 94 BMW 320i
CARBON FIBRE TUTORIAL someone?
 Does anyone have a step by step tutorial on finishing an interior part with Carbon Fibre? Not with decals, but stripping off the plastic skin and then re-covering it with Carbon Fibre? There are a couple of threads here about CF but nothing specific.
o/______\o
(oo_OO_oo)
[]o-----------o[]
'94 320i
07-30-2004, 01:41 PM
#2
Vehicle: Nissan primera gt
You liked the nissan panel i made that looks like carbon.....its not carbon,it just looks carbon,i used a carbon film with a hairdryer to shrink it over the panel after fabrication.
Just incase you ask...i bought it in halfords.
07-30-2004, 03:14 PM
#3
You have to invest quite a bit of money to be able to do it. We do it at a friends shop. You will need the vaccuum pump, bags, rolls of fiber, resin, etc. If you don't already know how to do it, it's easier to pay someone, since it's expensive to learn to do it.
07-30-2004, 03:24 PM
#4
Vehicle: 2005 PT Cruiser
and if you dont have connections be prepared to lay down some $$ for having this done. its not cheep either way.
That sticker is a decent idea but does it look like it is a sticker placed on the dash or does it actually look like someone took the time to do the actual work to it?
07-30-2004, 03:54 PM
#5
Vehicle: Mazda 6
Really depends on how well the sticker is applied as well. I've seen some work that is horrible and later some that I couldnt even tell the difference at all.
VIA Epia II
256MB 266DDR Ram
90GB Wester Digital
Bluetooth/Deluo GPS
Lilliput 7" Touchscreen
Mazda 6 Carputter > Click Me!
08-02-2004, 05:04 PM
#6
Vehicle: '04 Mazda3s '78 Pinto Wagon
http://www.mashie.org/guides/cfbalsa01.html
It will be a little different for your application but this is how it's done
If you're recovering another peice... sand it or body fill it smooth, then make an exact opposite contour. So you can mate the two peices... Then follow his design. I would suggest practicing a little before getting right to it. Try a flat peice, then something more complex. Wraping weave around something sometimes it doesn't wrap evenly... and makes some ugly imperfections.
I was thinking about different options when I was looking at redoing my Pinto and thought about making all new CF molding where the old green plastic used to be.
08-02-2004, 05:13 PM
#7
Jesus Freak
Vehicle: 2006 Mazda Mazdaspeed 6 GT
Great post. It gives the basics on how to work with carbon fibre.
I would like to know how you work with a peice that has curves and angles and circular cutouts.
08-02-2004, 05:18 PM
#8
I edited it to help.
As for different shapes/cutouts... you'd actually want to 'glass over it and then cut it out with a dremel tool or somehow stretch the fabric as you lay it on. I would suggest placing it at that point then moving outwards. So only that spot is pulled the rest should be even.
08-03-2004, 02:49 AM
#9
GuyS!!! Take a look here..
http://www.icancomposites.com/forum/...3c08c83da2f400
It's a rather new forum. The guy describes how you can strip The "skin" off of a eg. Console, soak a piece of CF in resin/hardener, then lay it on top of the piece. Of course it's not that simple but, take a look here. If you go through the threads, it looks feasible - not molding a piece but covering a piece..
That mashie site describes a really similar method... It's possible guys!!
Who will get the first steps documented here ????
o/______\o
(oo_OO_oo)
[]o-----------o[]
'94 320i
08-03-2004, 04:00 AM
#10
Vehicle: 2001 Dodge Durango RT
wow, those are great sites, LowMileLude double thanks, I like the servo contol off of your link too
[color=Navy][size=1][font=Comic Sans MS] Tektility
08-03-2004, 12:28 PM
#11
I got that off another forum I lurk. Pretty good info so I bookmarked it.
The link and procedure I listed should give you a glossy smooth finish. It's really easy with flat surfaces because the table was the other 1/2 of the mold... OR he can do a rough finish of that Mashie did on the other side by wiping the excess off.
Laying it over... I dunno. It might give the glossy surface or it might just goop and look awful. Gonna have to try each way and determine which is best for you.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
