The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Thread Tools Search this Thread Display Modes
Old 09-23-2004, 08:40 PM   #1
My Photos: (0)
How to mount laptop in trunk?
How do you guys mount the laptop in the trunk in a way that it doesn't slide in sharp turns or jumps in case of a pot-hole or two?
I was thinking about mounting my laptop on-top of my sub-box (MDF), but I'm not sure what materials to use and how to keep it in place.
Any ideas?
TIA
phatrabbitzz is offline   Reply With Quote
Sponsored Links
Old 09-23-2004, 09:50 PM   #2
I see dead kittens
Quattro's Avatar
Vehicle: 1998 Audi A4
My Photos: (0)
Do you think mounting you laptop on the sub box will be a good idea. I may be wrong, but that constant vibration from the subs will be nothing but trouble. I know laptop hard drives are designed to take a beating, but will it be able to survive this amount of abuse.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Old 09-23-2004, 10:04 PM   #3
MoFo's Avatar
Vehicle: Mercedes CLK430
My Photos: (0)
My laptop is ontop of a fanpad that I drilled onto a piece of masonite board. Under the masonite board is industrial strength velcro material. The Laptop is secured to the fanpad with a strip of nylon that velcro's from the bottom of the fanpad to the top of the laptop. I can take sharp turns at high speeds and the laptop doesnt budge
MoFo is offline   Reply With Quote
Old 09-23-2004, 10:17 PM   #4
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Yes, but those are entirely different forces than the constant vibration of a subwoofer enclosure...
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 09-23-2004, 10:31 PM   #5
My Photos: (0)
Quote: Originally Posted by Quattro-A4
Do you think mounting you laptop on the sub box will be a good idea...
No, I don't. I guess I could make a enclosure that would mount from the rear deck, (see last pic, not my car) that the laptop would sit in, but would that make a big difference? Since the rear deck of the car also gets vibration once the subs hit.
Here are pics of what my trunk looks like before I had subs.
Pic of a friends car:
Old 09-23-2004, 10:41 PM   #6
ppgt94's Avatar
Vehicle: MKIV VW Jetta
My Photos: (0)
Is that a Jetta I see? My Carputer is held down with Velcro. It STAYS PUT. That **** is strong as hell on the factory carpeting. Just use he "grab" (coarse) side.
ppgt94 is offline   Reply With Quote
Old 09-23-2004, 11:25 PM   #7
My Photos: (0)
Close, it's a Passat. Do you mean I should tape the bottom of my laptop the "grab" side? If so, I wouldn't want to do that since I'd never be able to take it off the laptop. Or did you mean that I should put the laptop ontop of the carpet, and take several stripes of the "grab" side and place them on-top of the laptop from side to side?
Also, would making an enclosure, like the third pic, cause significantly less vibration to the laptop then putting the laptop right on-top of the sub-box?
Old 09-23-2004, 11:28 PM   #8
gutterslide's Avatar
My Photos: (0)
you strap it to a board that is mounted to the sub box with some shock absorbing feet like these. i'd use the largest ones.
or you could make a similar setup by mounting a board to the box with two sections of large rubber hose (radiator hose) separating the board from the box. then strap the laptop to the board, so it's alittle more isolated from the vibration and bumps, from the road and the subs.
kinda like this...
======= <-- laptop
--------- <-- board
.O.......O. <-- hoses/quietfeet
[(o) (o)] <-- sub box
although, you might want to mount the laptop so that the hard drive is vertical to avoid damage from a hard bump.
gutterslide is offline   Reply With Quote
Old 09-23-2004, 11:55 PM   #9
My Photos: (0)
I like the idea of the "shock absorbers" and maybe I could also add a thick sheet of foam between the laptop and board. Will mounting the laptop vertical and leaving it like that for a long period of time not damage the laptop?
Old 09-24-2004, 12:00 AM   #10
ppgt94's Avatar
My Photos: (0)
OK, scratch my idea. I just realized that if you set your notebook on the carpet it would probably sufficate its air flow. Check and see if there's a fan on the bottom of your notebook.
Check out my favorite of all setups:
http://pathintosh.usersites.com/Pictures010.html
Destin's Pathintosh. He uses a Apple Powerbook.
Might give you some ideas.
Sponsored Links
Old 09-24-2004, 12:20 AM   #11
My Photos: (0)
I also have this Targus Chill Mat to help cooling:
Old 09-24-2004, 12:33 AM   #12
My Photos: (0)
you can put something to act as spacers between the laptop and the mounting board. you can find simple stick-on rubber feet anywhere.
i have too much free time...
Old 09-24-2004, 02:16 AM   #13
My Photos: (0)
How and what would you use to make tha laptop stay in place on-top of the board?
Also, how would you connect the quietfeet to the sub-box and the board to the quietfeet to stay in place during sharp turns?
Btw, thanks for the visual image!
Old 09-24-2004, 04:46 AM   #14
blicky_1's Avatar
Vehicle: 2002 Mercedes E200k Kompressor Avantgarde & 2004 Ford SportKa
My Photos: (0)
Thumbs up
I use the same, works for me!
blicky_1 is offline   Reply With Quote
Old 09-24-2004, 04:48 AM   #15
My Photos: (0)
a couple of cheap adjustable nylon belts, crossed, would hold it firmly in place.
as far as attaching the feet securely enough for the road, that's a tough one. you can put screw in from the inside of the box, and from the top of the board, into the feet. a couple into each foot. you just can't put them too deep because the screws will transmit the vibration and i'm sure it would cancel some of the dampening.
if you really wanna go crazy, you can use some RC car shocks.
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Laptop remote on/off issue -- SOLVED: s2000 carputer skybolt General Hardware Discussion 17 09-20-2004 10:52 PM
would a omni ceiling mount antenna work in my trunk? aoLhaTer Wireless Communications 0 07-14-2004 02:33 AM
laptop mount for car trd604 General Hardware Discussion 5 03-02-2004 12:48 PM
Signal Degradation with trunk mount PC? S4Per LCD/Display 5 01-20-2004 10:04 PM
Where to buy a auto laptop mount? GK Off Topic 2 11-21-2003 01:12 PM
Sponsored Links
Ad Management by RedTyger
