09-27-2004, 01:08 AM
#1
2003 Custom In-Dash 7" Touchscreen Install
I can't even tell you how many hours of prep, molding, bondo, sanding, painting, etc it took - but I am pleased with the final results! What do you think?
This is the first time I have worked with plastic and bondo!
2003 Chevy Tahoe Z71
STOLEN - M10000, 512MB, 60GB 2.5" HDD, 7" Custom mounted Lilliput, Morex 3688 Case, 90W PSU w/ ITPS, GPS & CD-RW/DVD. New parts ordered for the next generation!
09-27-2004, 01:28 AM
#2
niiice work man.. do you have any other pics(angles)?
Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
S2000 Carputer
09-27-2004, 08:15 AM
#3
Looks great, planning on doing the same thing in my 2000 Silverado. Hope mine turns out as well.
09-27-2004, 08:33 AM
#4
looks really nice...but the screen looks crooked in that picture - is it just the angle of the picture/dash?
09-27-2004, 01:59 PM
#5
Hey All - thanks for all your input! the screen actually isn't crooked in the car - must be the angle of the photo. I have another bezel that I am probably going to install an 8" touchscreen in - but who knows! I'll work on getting the other photos scanned!
09-28-2004, 02:16 PM
#6
Where did you stuff your PC? I was thinking of putting mine in the console behind where you have your LCD. (haven't pulled my truck apart yet)
09-28-2004, 02:30 PM
#7
Jesus Freak
Post a better picture. Honestly from that picture i would say that it still needs some work although i am a perfectionist.
I actually really need to finish mine.
Good work overall, post a better picture so we can comment more
09-29-2004, 02:21 PM
#8
hey antimatter - it still needs work!  I am actually thinking about rebuilding it entirely since I have had the experience of building this one, I know what not to do!  The PC is in the back of the Tahoe. I have it mounted right behind the seats. All of my amps rest under the rear seats, so it is quick access to get it all hooked up. Ever since I sent the volume control through my head unit, there is a ton of new things I want/need to do. After I do my new rebuild, I'll post my photos.
09-30-2004, 06:01 PM
#9
You using the factory headunit? Also - hows the visibility to the screen in that location. I'm kinda worried about glare...
09-30-2004, 06:07 PM
#10
glare is a bit of an issue - but honestly - I really don't look at it. I use the screen to load a list and then listen. If I choose to click next, stop, whatever - The screen becomes like a second headunit - you memorize where to click. Most of my driving is done at night anyways.
Yes - I am using the head unit. It controls - radio, volume and 6 disk cd changer - as well carputer volume. That sends a signal to the main amp which powers the front and rear speakers and passes the low signal to the subs. I am in the works to build a new system which will include 2-12" JL Audio W6 subs, 2 500.1 sub amps and 1 300/4 amp. The speakers in the doors are mb quartz right now - but I'll probably change those too.
10-07-2004, 08:49 PM
#11
One more question, then I'll leave ya alone ('till I think of another one)...
Which product are you using to interface to the headunit? I've seen several out there that work with the factory in-dash changer...
Thanks for taking the time to answer my questions!
btw - I've been thinking of using the PXGM24, because I've seen other people have some success with it, but HU has XM as well. Don't know if that makes a diff.
04-06-2005, 05:33 PM
#12
looks good. take a look at mine. i actually originally put my screen below also but after some time using it decided it was a big pain in the a$$ trying to look down all the time. that and its really unsafe to have it that low.
http://www.threez33.com/Carputer/index.htm
2003 Tahoe
lilliput 7"
Logic C158 mini-ITX
90w m1-atx power
Epia MII 12000 1.2ghz
512MB PC2100
2.5" 60gb Samsung 5400rpm
Panasonic Slot CD-rw/DVD
iguidance navi
navivoice
mediaengine
| Thread Tools |
| Display Modes |
Linear Mode
