Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 10-08-2004, 10:07 AM   #1
tbird2340's Avatar
How can I make my install look better?
Here is my screen job... I'd like to make it look more factory but don't know where to begin or how much work it would be...
If someone could just throw out a few tips I'd greatly appreciate it..
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
Old 10-08-2004, 10:19 AM   #2
dexy's Avatar
I would suggest getting some bondo (from autozone/home depot), and flush fill the sides of the lilliput to stream together with the dash. The bottom where it meets your AC controls, I'm not sure(you gatta do some artwork there), You can use bondo to make them look joint together.
Also realize that when you do this the front of the lilliput is fixed to the panel. So you would have to take the front cover off the screen, and remove the panel itself to do this work. When you are done, join in the other half of the lilliput from the back of the panel. The sticky in the fabrication thread shows how to do this. You do not need the foam(in his example).
dexy is offline   Reply With Quote
Old 10-08-2004, 10:24 AM   #3
ya bondo. fiberglass... lots of sandpaper... and time
When in doubt, moo at things.
jimmythecow is offline   Reply With Quote
Old 10-08-2004, 11:05 AM   #4
snmnetwork's Avatar
Cut the bottom of the lilli off! The whole button panel must go. Relocate the button panel behind the lilli and relocate the ir receiver. Unsolder the IR receiver from the panel and use wire to connect it back to the panel. That way you can put the IR receiver any where you like. Mold it in the dash or simply put it behind the vents. Kitty hair/bondo the bottonm to mold it in, and bondo the sides.
Status: [|||||||||-] 90% finished
My 2000 Chevy Monte Carlo SS Install
snmnetwork is offline   Reply With Quote
Old 10-08-2004, 11:13 AM   #5
snmnetwork's Avatar
Old 10-08-2004, 11:30 AM   #6
snmnetwork's Avatar
forgive me i'm bored
forgive me i'm bored...lol
Old 10-08-2004, 11:46 AM   #7
that photoshop gives you a good idea of what to shoot for, but I liked your install anyways...just needs some finishing touches
oekundar is offline   Reply With Quote
Old 10-08-2004, 12:04 PM   #8
I have the same problem with the future insall of a lilliput into my Yellow Ranger Edge. I was thinking that maybe i would cut some of the bezel under the AC vents and move it up a little bit. The biggest problem is how to access the lilliput after bondo. The bezel is 3 ish inches deep. Guess you could really murder the thing and disect it. Most of us Ranger people have a few of the bezels laying around.
RiZeN is offline   Reply With Quote
Old 10-08-2004, 12:17 PM   #9
If you haven't already, you could probably remove the screw holes behind the lilliput buttons. I think the bezel should hold in there on its own. this would allow you to bond the whole bottom in. I myself am trying to decide on whether to put the computer in the dash where the 2 din cd player goes, or to do what you did and install it in an explorer console. If i can find one of those at the junk yard.
Old 10-08-2004, 12:57 PM   #10
tbird2340's Avatar
Thanks for all the ideas everyone... Snmnetwork.. Thanks for the pictures.. That definately helps for a visual. I'm a little hesitant with taking apart my Lilli. All the threads of people having problems and mine works 100%. I would be afraid to jack it all up..
How touchy is it? That photoshop looks sweet w/ your makeshift bondo
Old 10-09-2004, 11:29 AM   #11
tbird2340's Avatar
So if I did this I would have to use the remote to turn on the Lilli everytime? The way it is now is I have to hit the power button everytime.
Old 10-09-2004, 11:35 AM   #12
Clover
Grayscale's Avatar
no leave it on and let it stay in standby, it won't drain your battery unless you leave it in "standby" (where you don't actually turn it off, it just turns itself off kind of) for like 3 or 4 days
CarPC install is starting to come along again...
Grayscale is offline   Reply With Quote
Old 10-09-2004, 11:37 AM   #13
tbird2340's Avatar
I have it running off my PSU in my PC which is powered from my ITPS so power gets totally cut from it...
Old 10-09-2004, 11:47 AM   #14
Clover
Grayscale's Avatar
oh, didn't think about that, i don't use an ITPS. wellll in that case... just solder up a little momentary switch to the two solder points where the button is on the little board that holds your buttons and lights. i don' t know if you've opened up your screen and seen that but its very easy to solder onto. thats what i just did for a friends truckpc last night.
Old 10-09-2004, 04:20 PM   #15
tbird2340's Avatar
Ok.. I just picked up some Bondo Home Solutions All-Purpose Fiberglass Resin and some Fiberglass Cloths from home depot.
I really want to do this.. In regards to the Lilli. How fragile is it taking it apart.. I'm just VERY nervous about it getting jacked up (for obvious reasons with it being the most expensive part of the install).
Also, could someone give me a detailed step by step of what you would do if you were me?
Thanks so much!
How to make the Garmin GPS 35 Work with Copilot 2003 fluffy2097 GPS 16 09-05-2007 04:19 PM
My Install in A Lexus IS200 UK Spec Brettster Show off your project 22 04-30-2007 08:20 AM
How should i install this? jnusaira General MP3Car Discussion 8 08-13-2004 03:03 PM
Lilliput 619GL-70NP Touchkit XP Home Install Windchsr LCD/Display 2 04-25-2004 07:23 AM
Those running Linux from CF, how to make bootable? eugenen Software & Software Development 1 11-10-2003 12:18 AM
