Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 07-21-2005, 10:22 PM   #16
Altimat's Avatar
Altimat is on a distinguished road
Yes, being a high performance make , Nissan headrest tubes are hollow. I had to cut the connectors off to get the wire through though.
2002 Nissan Altima 3.5 5 Speed Bose FM/6CD ED E12A P4 2.26 512 Ram Ti4600 CDRW DVD Lilliput 200mW 802.11b Trackman AutoTap GPS Opus 150 Carnetix 1260
2005 Nissan Titan SE Dell GX-150 P3 1.0 512 Ram 20G GF4 MX4000 USB 2.0 DVD/RW Xenarc GPS Trackman
Altimat is offline   Reply With Quote
Old 07-27-2005, 10:41 PM   #17
Raw Wave
tbird2340's Avatar
tbird2340 is on a distinguished road
How much would you charge to do something like this in a 04-05 Maxima?
Wife's Vehicle: 2007 Dodge Nitro
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
Old 11-02-2005, 02:01 AM   #18
2loud2old is on a distinguished road
bringin up an old post i think but i'd like abit of info..
if this is connected to a carputer how would u power the screens.. do they come with on/off button?.. how do u put the display from the carPC on 2+ the one front screen.. ive looked around but cant find anything ... help appreciated
yes ive and but no luck :P
2loud2old is offline   Reply With Quote
Old 11-02-2005, 12:04 PM   #19
albysure's Avatar
albysure
i have a video card that has vga and s-video out. run the lcd's off the s-video and just power them from the yellow and black wires on your power supply
98% complete. Couple of tweaks to the fabrication.
http://www.cardomain.com/ride/212327/14
albysure is offline   Reply With Quote
Old 08-31-2006, 09:01 AM   #20
Alexandre1977 is an unknown quantity at this point
Nosssa que coragem,,, estragar um encosto de cabeça....
Alexandre1977 is offline   Reply With Quote
Old 02-22-2007, 01:21 AM   #21
houdini is an unknown quantity at this point
Just as a quick reply Ive done 100+ head rests, oversized aside. If you just put the factory screen bezel under the upholstery, removing the foam for needed depth, and if wanted (I usually do)removing the usual 1/2 flare around the shroud, and if the upholstery has what is common a 1/8" plus of padding can be scrapped off up to the bezel line, so that all that is inserted in to the screen beze is the vinyl, no padding, usually works on even the tightest bezel/screens
another added trick to make sure it goes in good is to make sure the cuts at the corners are near the edges, you may want to keep them longer but it will cause problems of pulling the vinyl in to the bezel, also use silicone spray to lubricate the vinyl before insertion, it will dry and the monitor wont slip out.
This all leaves a more factory flush look, with no gaps on the corners as can be seen on these surface mounted screens. any question please ask.
been doing this for 12 years.
houdini is offline   Reply With Quote
Old 02-23-2007, 10:19 AM   #22
Altimat's Avatar
There are no gaps in the corners, but this was only my first headrest screen installation. I don't believe there is any way the upholstery could have fit between the bezel and the screen.
Old 02-23-2007, 01:16 PM   #23
what I meant was the far outer edges of the screen bezel, especially at the top is not touching the vinyl its hovering in the air(it looks like it in the picture anyway). Looks damn good for a first time, I havent had to many times where the material wouldnt fit into the bezel, but have scene it happen, If you want that really clean look what you do is use ABS or MDF to fabricate a new bezel that will allow for the vinyl/leather gap, takes another 1/2 of work but looks alot better, I dont even offer surface mount screens at the shop anymore. you just lay the screen on the MDF and put dbl stick tape on it to account for the thickness of the vinyl, then trace and cut, ABS is trickier you have to get 1 long piece and bend it where you want then weld the 1 seam.
Just trying to help.
2002 Montero Limited Install... Squid Show off your project 35 10-06-2009 04:41 PM
now you see it now you dont 97 yukon install FAmonmouth Show off your project 17 05-04-2005 10:43 PM
How should i install this? jnusaira General MP3Car Discussion 8 08-13-2004 04:03 PM
Headrest Monitors DIY [iG] Fabrication 4 06-27-2004 09:15 PM
suggestions on headrest monitors? kaotic504 LCD/Display 3 01-20-2004 02:03 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
