Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 12-10-2004, 07:16 PM   #16
JoezDog4 is on a distinguished road
I love it Altimat... will be doing this to a new Altima console... my sis wants a tv in her car but she doesn't trust me to do it to her stock console... LOL
JoezDog4 is offline   Reply With Quote
Old 12-10-2004, 07:35 PM   #17
Altimat's Avatar
Altimat is on a distinguished road
I used to feel that way too, but you're just buying another one right? Its the same as the original. So why tie up the money in the new part and have an extra laying around? Hack up the one in her car and save a few bucks. If you ever want to go back to stock buy the panel then.
Unless of course you can't bear to drive around with that gaping hole in the middle of your dash like I do. I think I have put more miles on my car without the center dash panel than with it!
2002 Nissan Altima 3.5 5 Speed Bose FM/6CD ED E12A P4 2.26 512 Ram Ti4600 CDRW DVD Lilliput 200mW 802.11b Trackman AutoTap GPS Opus 150 Carnetix 1260
2005 Nissan Titan SE Dell GX-150 P3 1.0 512 Ram 20G GF4 MX4000 USB 2.0 DVD/RW Xenarc GPS Trackman
Altimat is offline   Reply With Quote
Old 12-10-2004, 07:44 PM   #18
Altimat's Avatar
Quote: Originally Posted by fcc
The finish on it is also amazing...how'd you paint it?
I have a compressor and complete set of body shop tools in the garage but I still use spray cans for the little stuff.
PlastiKote Trim Black and PlastiKote Sandable Primer in black are my favorites. They smell especially bad though.
After I get coverage a spray light mist coats to get the fine texture. Hides fingerprints and smudges better then too.
Old 12-10-2004, 08:06 PM   #19
Tainted Love
Cris's Avatar
Cris is on a distinguished road
Altimat, your car must be amazing... I've seen you've made your own leather interiour. Maybe you'll make a how to, on that as well... Very nice work... We should make a standard after you work... the Altimat standard.
Cris is offline   Reply With Quote
Old 12-10-2004, 09:07 PM   #20
Bowel movement
jjh221's Avatar
jjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud of
WOW!!!
I GIVE FREE HUGS!
Buy Sell or Trade
If my pm box is full, please feel free to call me any time. 440-328-3382
Thank you
Forex
Rate Mp3car @ FXroot.com
jjh221 is offline   Reply With Quote
Old 12-23-2004, 01:00 AM   #21
integramodder is on a distinguished road
Quote: Originally Posted by CJ8501
This is the screen Altimat built for me The work is great!
where are the pics of it installed in the car?
integramodder is offline   Reply With Quote
Old 01-12-2005, 01:30 AM   #22
(6)
(6)'s Avatar
(6) is on a distinguished road
DVD Rom
Where is your PC mounted? It must be close to your monitor for you to have the optical drive so close?
(6) is offline   Reply With Quote
Old 01-12-2005, 11:38 PM   #23
Altimat's Avatar
No the optical drive is on USB.
Old 01-19-2005, 02:15 PM   #24
dasbell's Avatar
dasbell is on a distinguished road
Awesome
THis is a really excellent job. Nice work!
dasbell is offline   Reply With Quote
Old 01-19-2005, 02:44 PM   #25
Jesus Freak
antimatter's Avatar
antimatter is on a distinguished road
Do you do anything to the paint afterwards like use any polishing compounds or anything. Can you tell me how you did you coats (i.e. 1 layer of primer and then 3 layers of black waiting 30 minutes between)
I really think you did a great job especially with the paint. You can do some killer fabrication work and ruin it with a crappy tacky paint job.
antimatter is offline   Reply With Quote
Old 01-19-2005, 02:52 PM   #26
Altimat's Avatar
Update: The edges between the plywood and the plastic became barely visible as a thin recessed line after a few weeks time and I had to redo it. You can see the area where the filler is thin in the second-to-last pic on either side of the DVD slot. All I did to repair it was to grind the material down about 1/8" and refill over it. So be sure all of your seams are buried with at least an 1/8" of filler in the flat areas to prevent this from happening.
I also switched to using epoxy exclusively for filling also - not just gluing. Its a little more work to sand even with microballoons added, but the result is a much harder and more stable end product.
I switched to all SEM finishing products. They make a nice flexible primer surfacer, texture spray, and trim black. These all work very well. The primer sands easily (but its white), and the end result with the trim black over the texture is very close to an OEM textured plastic. The only drawback is that they stink pretty bad. Use good ventilation and a mask.
Old 01-25-2005, 03:35 PM   #27
minghi's Avatar
minghi is on a distinguished road
leather sears: how to?
hi altimat
we would all like to know how to change the leather on the seats. can you post some information online/
thanks
minghi
minghi is offline   Reply With Quote
Old 01-26-2005, 09:26 AM   #28
Altimat's Avatar
Quote: Originally Posted by minghi
hi altimat
thanks
minghi
Here's a link to the original write-up. It will give you an idea of what needs to be done, and its not technically difficult - just laborious and time-consuming.
http://www.nissanclub.com/forums/showthread.php?t=65946
Old 01-26-2005, 09:42 AM   #29
Altimat's Avatar
Noooo no no no. Think of primer as a last coat of filler only its sprayed on. I usually spray one light coat, then three wet coats allowing a good 20-30 minutes between coats. Let this primer application dry overnight.
Then fill any remaining visible pinholes with a razor blade and spot putty. Apply a very list mist "guide coat" of a contrasting color primer. Let that dry a few hours.
Now begin your sanding with 400 taking care not to sand through on edges etc. Sand until the guide coat is almost gone and no surface imperfections remain. Finish with a light sanding with 500-600 totally removing the last remaining traces of guide coat. Now you have a flawless finish ready for paint.
As with the primer, the first coat of paint is always a light one. If you are using SEM spray texture, spray that on light and even exactly as if it was a guide coat, but you can consider it your first coat of paint. Again, I wait a good 15-20 minutes between coats this time of year. Now I'll spray the next 2-3 fairly wet to get good coverage without runs. Again make sure to allow plenty of time between coats. If you are not using a texture spray underneath, your last few coats will be mist coats sprayed from a distance. Continue until you achieve the desired effect, and make sure you initiate the spray off the part because the can will discharge a few big blobs at first and these will mess with your mist-textured effect.
Thats it its done. Don't ever polish it, wax it, or Armorall it. Just clean it with a damp soapy rag once in a while.
Old 03-24-2005, 09:37 PM   #30
messypoopypants's Avatar
messypoopypants is on a distinguished road
nice job, very clean looking work. I'm going to do something very similar in my A4. I just have to remember where I left my power tools....
I'm going to cut your balls off so you don't infect the rest of the world!!!
messypoopypants is offline   Reply With Quote
any feedback info. on Dynamix 7" VGA Touch Screen TFT ??? xtreamvette LCD/Display 29 04-22-2007 04:19 PM
How to wire in External DVD drive and Screen legend5761 Power Supplies 4 11-01-2004 11:04 PM
Deal alert: Mobile DVD Player w/5.6-inch Detachable Screen $99+5 shipping mykolJay General Hardware Discussion 4 09-27-2004 01:59 PM
Make DVD fill screen under media engine Mikesz Media Engine 3 09-24-2004 05:57 PM
Laptop/LCD screen hookup... UrbanTacticz LCD/Display 1 11-28-2001 06:49 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
