Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 01-28-2006, 06:29 PM   #61
DaveB's Avatar
DaveB is on a distinguished road
Is it necessary to glaze over the inside the wooden frame before painting it? It seems like that would be hard to do. It would be tough to sand and get clean edges on the inside corner.
Do you leave the back on the Lilli or remove it for ventilation?
When you bond the Lilli into the frame, I assume you do it from the back. If the back cover is on the Lilli when you bond it, then how do you paint the Lilli after its in place given you can't disassemble the Lilli?
8" Lilli TS
MB896F Mini-ITX MB
2GHZ Dothan 533MHz FSB CPU
1GB SDRAM DDR2 533
Seagate 300GB SATA150 HD
ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
Pioneer Slot Load SLIM DVDRW
Bluetooth V2 USB 2 Dongle
3COM BKP Cam
DaveB is offline   Reply With Quote
Old 01-28-2006, 07:19 PM   #62
Tainted Love
Cris's Avatar
Cris is on a distinguished road
This operation requires you disassamble the screen, you can't really do it this way, otherwise.
It's up to you if you want to put the back of the screen on...depds on how much ventilation you have back in your dash. I for one, didn't put it on.
Looks carefully at the pics. You'll now the steps involved.
Cris is offline   Reply With Quote
Old 01-29-2006, 03:35 AM   #63
j03y is on a distinguished road
krylon fusion?
j03y is offline   Reply With Quote
Old 01-29-2006, 10:26 AM   #64
Altimat's Avatar
Altimat is on a distinguished road
You can disassemble the Lilli. Just remove everything from the back of the front bezel but do not mess with the LCD ribbons.
The bare woodgrain does need to be sealed either with a layer of filler or with a good, slow hobby epoxy so the woodgrain doesn't come back through the paint (Learned this the hard way).
2002 Nissan Altima 3.5 5 Speed Bose FM/6CD ED E12A P4 2.26 512 Ram Ti4600 CDRW DVD Lilliput 200mW 802.11b Trackman AutoTap GPS Opus 150 Carnetix 1260
2005 Nissan Titan SE Dell GX-150 P3 1.0 512 Ram 20G GF4 MX4000 USB 2.0 DVD/RW Xenarc GPS Trackman
Altimat is offline   Reply With Quote
Old 01-29-2006, 10:45 AM   #65
DaveB's Avatar
When you bond the front bezel of the Lilli in place how do you go about bonding it? In other words, where do you place the glue? If you put glue on the back outer edges of the bezel you would never be able to put the back cover on again, correct? I'm assuming that may be why most people leave the rear cover off.
8" Lilli TS
MB896F Mini-ITX MB
1GB SDRAM DDR2 533
3COM BKP Cam
Old 01-29-2006, 04:37 PM   #66
Tainted Love
Cris's Avatar
I put mine on the sides, and a little more on the back. The back can fit with the glue on. It won't look good, but then again, it doesn't have to.
Old 02-24-2006, 01:38 PM   #67
bmbr is on a distinguished road
hey guys, i'm looking at trying this out myself over the weekend, but I'm having a hellofatime finding Evercoat Metal Glaze. Are there any substitutes I can look for that you might recommend, or some place I should be trying to find this stuff? I've tried a few auto parts stores, ACE hardware, OSH all to no avail.
Also, when I am looking at paints, do I need anything specialty? (I continue to look for PlastiKote, but so far no luck) I assume that since I'll mostly be painting on the bondo/evercoat at the end that most any automotive paint will work ok. Am I mistaken?
Thanks so much for a great write up on this project, Altimat. I'm very excited!
bmbr is offline   Reply With Quote
Old 02-24-2006, 01:58 PM   #68
dfk70's Avatar
dfk70 is on a distinguished road
You'll probably have to go to a place that sells automotive paint and supplies to get Evercoat.
2003 F-150 Harley Davidson Edition
"The horse is here to stay, but the automobile is only a novelty - a fad." --- Marshall Ferdinand Foch, French military strategist, 1911
dfk70 is offline   Reply With Quote
Old 02-24-2006, 04:35 PM   #69
well i used local.google.com to look for auto body supplies and after about 5 calls I finally found one that carries evercoat! everything's coming up milhouse!
Old 02-25-2006, 12:07 AM   #70
Altimat's Avatar
Your best bet it to get your paint products wherever you found the Evercoat. The commercial paints like SEM are way better than the consumer paints at auo parts, hardware, and home stores.
Old 11-30-2006, 01:14 AM   #71
smartmlp is on a distinguished road
Can someone fix these pictures please?
smartmlp is offline   Reply With Quote
Old 11-30-2006, 01:24 AM   #72
I see dead kittens
Quattro's Avatar
Quattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant future
pictures are working fine for me.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Old 11-30-2006, 01:40 AM   #73
Nevermind, for some reason charter is in my site block list for ads.
Old 02-22-2007, 01:03 AM   #74
houdini is an unknown quantity at this point
hello Im new to this web site but I have 12 years of experience in car audio fabrication. building small parts like dash pieces with semi-rigid materials like body filler has a high rate of major or minor cracking and failing.
houdini is offline   Reply With Quote
Old 02-23-2007, 10:25 AM   #75
Altimat's Avatar
I restored cars for 20+ years quite a few of which were fiberglass, and not the least of which was the Oldsmobile XP-20 concept car that set a new Barrett-Jackson auction price record a couple years ago. Currently I manufacture aftermarket fiberglass grilles. Nonetheless I used a reinforced epoxy. The filler used here is only for smoothing and is not structural. Perhaps you'd like to share your experience with some pictorial how-tos that we could stickie here also?
any feedback info. on Dynamix 7" VGA Touch Screen TFT ??? xtreamvette LCD/Display 29 04-22-2007 04:19 PM
How to wire in External DVD drive and Screen legend5761 Power Supplies 4 11-01-2004 11:04 PM
Deal alert: Mobile DVD Player w/5.6-inch Detachable Screen $99+5 shipping mykolJay General Hardware Discussion 4 09-27-2004 01:59 PM
Make DVD fill screen under media engine Mikesz Media Engine 3 09-24-2004 05:57 PM
Laptop/LCD screen hookup... UrbanTacticz LCD/Display 1 11-28-2001 06:49 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
