Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 11-22-2004, 07:48 PM   #1
Altimat's Avatar
Altimat is on a distinguished road
How-To: Recessed Screen and DVD Drive
This screen is being installed in place of the original head unit, and will include a notebook tray-load DVD drive below.
Trial fit of the recessed housing constructed with 5-Ply Birch Model Aircraft Plywood 3/16" thick. It glues up quickly with medium CA.
The top is tacked with big, easily removed blobs of hot melt glue, and the bottom is secured with a couple of those nice little extra screws you have from removing the metal bracket on the back of your Lilliput. :
The curved filler pieces on the sides are to fill two bulges in the plastic panel which matched the OEM head unit which had curved sides. They would look out-of-place with the rectangular screen. The recess above will be filled also.
This picture shows the sanding done on the backside before apllying epoxy for adhesion. Sand everywhere you will apply anything that you want to stick:
Masked all of the seams on the front to keep the epoxy from bleeeding through. Epoxy sticks best, so I use a Kevlar reinforced type liberally on the backside to glue everything together and to reinforce all the wood seams previously glued with CA:
Backside after gluing. I heat the epoxy with a heat gun which lowers its viscosity and makes it flow nicely and soak into the wood well. It also cures faster:
View showing two little cavities I filled up all the way. You can't have too much strength and weight is not an issue here:
Front view after filler work with the drive and screen bezel installed:
OK here's the finished install:
2002 Nissan Altima 3.5 5 Speed Bose FM/6CD ED E12A P4 2.26 512 Ram Ti4600 CDRW DVD Lilliput 200mW 802.11b Trackman AutoTap GPS Opus 150 Carnetix 1260
2005 Nissan Titan SE Dell GX-150 P3 1.0 512 Ram 20G GF4 MX4000 USB 2.0 DVD/RW Xenarc GPS Trackman
Altimat is offline   Reply With Quote
Old 11-23-2004, 12:33 PM   #2
oekundar is on a distinguished road
that looks sweet!...I wish I had skills like that...time to get my game up!
oekundar is offline   Reply With Quote
Old 11-23-2004, 12:40 PM   #3
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
Man i need to get you workin on my 01 alty! Seeing ur threads makes me wish i had power tools. Oh yea.. and aptitude.
Old 11-23-2004, 12:53 PM   #4
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
nice work, am planning on something like that but with a thin bezelt hat fits over the original one so i dont have to tamper with my screen. Keep us updated.
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 12-10-2004, 09:21 AM   #5
John M's Avatar
John M is on a distinguished road
What kind of epoxy is that - brand, etc?
2005 Subaru Legacy GT
Status: 40% - starting install
• AMD Sempron 3100, Biostar K8NHA PRO mobo, 512 meg DDR, WD 200 gig SATA, Opus 150, Xenarc
• JBL GTi 6.5 fr, JBL 5.25 rr, (3) JBL 75x2 & 1 1200x1 amps, PA MOFO 12 sub
John M is offline   Reply With Quote
Old 12-10-2004, 09:54 AM   #6
joelw23 is on a distinguished road
Poxy Weld....got mine at Menards $12
joelw23 is offline   Reply With Quote
Old 12-10-2004, 03:52 PM   #7
Raw Wave
kickercivic1's Avatar
kickercivic1 is on a distinguished road
WHAT DID you use to fill all that?
kickercivic1 is offline   Reply With Quote
Old 12-10-2004, 04:09 PM   #8
Stank Cheese
n8scstm's Avatar
n8scstm is on a distinguished road
I must say this is the cleanest monitor install i have seen on this forum. Looks factory. Nice job.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
8" Lilliput touch screen
IGuidance
dual optimas
battery isolator
15" screen
My Truck
n8scstm is offline   Reply With Quote
Old 12-10-2004, 04:50 PM   #9
CJ8501's Avatar
CJ8501 is on a distinguished road
This is the screen Altimat built for me The work is great!
CJ8501 is offline   Reply With Quote
Old 12-10-2004, 05:00 PM   #10
I've got no answer!
Question's Avatar
Question is on a distinguished road
Did you just cut the boards sticking out with a saw? Or did you sand them down? I'm confused how you got from the 3rd pic to the 6th pic. Awesome job, btw...the best I've seen on a recessed screen.
Question is offline   Reply With Quote
Old 12-10-2004, 05:50 PM   #11
Altimat's Avatar
Just the Evercoat Metal-Glaze. Its missing some curvature so its low in the middle, but fairly flush all the way around otherwise. I think the filler is probably 1/4" thick in the middle.
Old 12-10-2004, 05:55 PM   #12
Altimat's Avatar
I ground and sanded it down to flush after the epoxy cured.
I should have put one more pic in there though. You do need to thoroughly sand around and taper into all of the seams before applying filler so nothing shows through later, and the seams are buried well.
Old 12-10-2004, 06:17 PM   #13
Stank Cheese
n8scstm's Avatar
So no fiber glass on this? Cool, Ive got the 3-gallon container of evercoat sitting in my garage. Now I will have something to do with it other than body work.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
Old 12-10-2004, 06:48 PM   #14
Altimat's Avatar
Just remember that you can't use regular filler as an adhesive. You need a good strong structural bond between the parts before any surface filling is done or the filler will crack sooner or later.
Old 12-10-2004, 07:10 PM   #15
I've got no answer!
Question's Avatar
The finish on it is also amazing...how'd you paint it?
any feedback info. on Dynamix 7" VGA Touch Screen TFT ??? xtreamvette LCD/Display 29 04-22-2007 04:19 PM
How to wire in External DVD drive and Screen legend5761 Power Supplies 4 11-01-2004 11:04 PM
Deal alert: Mobile DVD Player w/5.6-inch Detachable Screen $99+5 shipping mykolJay General Hardware Discussion 4 09-27-2004 01:59 PM
Make DVD fill screen under media engine Mikesz Media Engine 3 09-24-2004 05:57 PM
Laptop/LCD screen hookup... UrbanTacticz LCD/Display 1 11-28-2001 06:49 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
