Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 11-26-2004, 12:19 AM   #1
Wolfman's Avatar
Wolfman is on a distinguished road
What is the best finish for custom dash?
I am at the stage to finish my custom molded screen and was wondering what everyone else has had the best luck with. I have a very fine textured spray paint (looks like about 150 grit sandpaper when applied) but from testing it looks like it will be too glossy.
Wolfman is offline   Reply With Quote
Old 11-26-2004, 06:06 PM   #2
Cryogen97 is on a distinguished road
I'll get back to you in a couple hours. I'm trying plasticote flat black bumper and trim spray paint.
AutoPC: M10k, WinXP, gps, wifi, 80GB HD, dvd-RW. SB mp3+
MediaEngine front end, map monkey, netstumbler.
gps mouse is on the fritz.....stupid technology
Cryogen97 is offline   Reply With Quote
Old 11-26-2004, 06:43 PM   #3
Chairboy's Avatar
Chairboy is on a distinguished road
In order of preference:
1. The tanned skin of my enemies
2. Vinyl from fabric store
Chrysler 300 - Fabricating
http://hallert.net/
Chairboy is offline   Reply With Quote
Old 11-26-2004, 08:52 PM   #4
flat black plasti-kote bumper and trim looks very OEM. at least for my honda, it's almost spot on in shine and texture.
Old 11-26-2004, 09:49 PM   #5
BassBinDevil's Avatar
BassBinDevil is on a distinguished road
Polished, carved hardwood. Engine-turned billet aluminum or stainless steel. Plastics? Bah.
BassBinDevil is offline   Reply With Quote
Old 06-29-2008, 04:30 PM   #6
Chairboy's Avatar
It's been almost four years, I stumbled across this while researching which paint to use for my fabbed dash piece.
Has anyone done anything with undercoating? I'm thinking it would be nice if I could have the sort of rubber-ish coat that the OEM piece had. Unless that's what the Plasti-Kote bumper/trim stuff above gives....
http://hallert.net/
Old 06-30-2008, 07:37 PM   #7
One Sharp Cheddar
ThunderStick's Avatar
ThunderStick is on a distinguished road
just finished my dash using rubberized undercoating.
The trick is to use multiple coats but thin coats or you will get runs. Also patience in between coats. Being in the last phase of my install I was a little over anxious and as a result I got a run down the flat side of the front finish. But it works great if you have a dash you used a lot of bondo on and have a few uneven surfaces. As I did, it was my first attempt at fiberglass and bondo so there were a lot of imperfections that the undercoating covered up for me.
ThunderStick is offline   Reply With Quote
Old 06-30-2008, 10:09 PM   #8
Chairboy's Avatar
Thanks! I'll try that next if the next experiment doesn't work. I picked up some spray on tool protector.
http://hallert.net/
Old 06-30-2008, 10:29 PM   #9
VENDOR - Nexations Creations
Nexson's Avatar
Nexson is on a distinguished road
Sem Texture/Satin Black Paint
Brian @Nexations Creations
Specialist in Custom Interior Fiberglass OEM Replication Work.
AIM: Exus28
E-Mail: Exus28@aol.com
Nexson is offline   Reply With Quote
Old 06-08-2009, 04:10 PM   #10
joshuo is an unknown quantity at this point
How about exterior color paint? hnoes:
You could get some spray can touch up paint, some nice clearcoat, and make the custom dash really stand out...
EDIT:
Whoops, i just realized I replied to a year old thread... O_o
*grabs flamesuit*
joshuo is offline   Reply With Quote
Old 06-11-2009, 03:06 PM   #11
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
EDIT:
*grabs flamesuit*
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
dash cover/ door idea cyberpotato Fabrication 39 01-15-2007 06:47 AM
Help on custom dash for Caddy STS Slaughterhouse Fabrication 34 12-14-2006 07:47 PM
FS: Custom dash for G35 sedan/coupe Izik Classified Archive 2 07-24-2004 12:39 PM
temps in trunk vs dash Saurk General Hardware Discussion 1 03-14-2004 11:27 AM
Indash monitor housing help... 7" in dash VGA conversion vwaddict LCD/Display 14 10-14-2003 09:25 PM
