Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 12-27-2004, 11:11 AM   #1
mlazzaro@excite's Avatar
mlazzaro@excite
Project lexus ES300 with 300 or so pics
I want to post my project for everyone to check out
PROJECT ES300 WEBPAGE
now I need some good navigation software to use with my gps. I need something that will talk and is easy to use with a touch screen. also is there any way to reduce the glare on the lilyput screen/
mlazzaro@excite is offline   Reply With Quote
Old 12-27-2004, 11:38 AM   #2
ST34LTH is on a distinguished road
These questions have been answered quite a few times. Good project car.
PROJECT ST34LTH : A 100% integrated car computer with fulltime wireless internet and audiophile-grade sound and exquisite video in a Black on Black Mercedes-Benz S500
ST34LTH is offline   Reply With Quote
Old 12-27-2004, 11:57 AM   #3
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
looks like it took a lot of work....quite risky to do your dash with it still in the car though!
glad to see it all done! thanks for posting the pics!
same as ST34LTH said....there are specific forums dedicated to both of the questions that you asked.....a GPS forum and a LCD forum....do a bit of searching....
welcome BTW!
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 12-28-2004, 02:30 PM   #4
mxl4729's Avatar
mxl4729 is on a distinguished road
welcome BTW!
yea but it is so much easer to ask then to but anyway the reason i did it in the car was becuase i needed dash as the mold i did not use any of the dash peaces around the screen over again
mxl4729 is offline   Reply With Quote
Old 12-28-2004, 02:33 PM   #5
_
so I'm guessing you are mlazzaro@excite too?
*confused*
Jan Bennett
Old 12-28-2004, 09:29 PM   #6
dingofarmer's Avatar
dingofarmer is on a distinguished road
looks great
dingofarmer is offline   Reply With Quote
Old 12-30-2004, 12:57 AM   #7
hd54321's Avatar
hd54321 is on a distinguished road
SCREW YOU!!!!!! I have a 98 ES300 and I thought I would be the first to have a carputer in our model year on this board!!!
All I can say is GREAT JOB! I've only installed the head unit, amp, infinity basslink, distro block and speakers so far. I purchased one of those dash fit kits that finally came out for our cars and currently using that as a temporary solution for my aftermarket HU.
The metal bracket for the stock radio and HVAC controls looks like it could hold 2 DIN units, so I am planning on installing my Xenarc into an in-dash unit. When that is done, I have to fabricate some sort of dash piece to accomodate the aftermarket HU and the in-dash monitor. I have a mid-tower ATX case waiting to be installed in the trunk.
I really like what you did with the MDF pieces in the trunk. I've currently mounted my amp, inverter, power strip and distro block to a piece of carpeted plywood and when the carputer is in, I plan on mounting it against the rear seatback. The ATX case will go on one side of the trunk while the infinity basslink is on the other. To make it look real stealth, I may do what you did with your sub.
I've run my power/audio cables the exact same way you did (power on driver's side and audio on passenger's side). One question though, were you able to fit all the cables under the plastic cover on the passenger's side of the car? We're talking about 3 AV interconnects, 4 sets of speaker wires, 1 vga cable, 1 audio cable from carputer to HU and a USB cable....??? Did all those fit under the plastic covers???
One last thing, I was stupid and accidentally left my work light on the passenger's side plastic cover for about 5 minutes - it melted the plastic. It cost me $56 to get a new one from a stealership - so, just be cautious with any other work.
Anyhow, congrats on your ride....I'm going to be hitting you up with a few more questions later on.
-HD
hd54321 is offline   Reply With Quote
Old 01-02-2005, 08:53 PM   #8
BigfootsMonk is on a distinguished road
Where do most people keep their carputers? In the dash or in the trunk? Or somewhere else? :-P
BigfootsMonk is offline   Reply With Quote
Old 01-02-2005, 09:19 PM   #9
fantomas's Avatar
fantomas is on a distinguished road
some in the trunk...some under the driver's seat...others in the dash. wherever you have room for it
rebuilding carpc... kinda..
fantomas is offline   Reply With Quote
Old 01-02-2005, 09:45 PM   #10
MySQL Error
jcdillin's Avatar
jcdillin is on a distinguished road
great install! mounting the screen that far back help alot with glare?
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 01-02-2005, 09:48 PM   #11
_
I'm going to go out on a imb and say the trunk as that's where it's easiest for people to just put a case and be done with it....
Jan Bennett
Lexus IS300 install pics. Fargo Show off your project 20 01-01-2008 11:47 PM
Lexus ES300 Carputer amrit50 Show off your project 25 10-30-2005 09:05 PM
finally my project pics osirisdon Show off your project 28 07-03-2005 03:38 PM
Pics of my screen-in-dash Accord project mykolJay Fabrication 2 07-02-2004 11:22 AM
Hello!! CarPC project pics inside. bobbykokinos Newbie 11 03-29-2004 12:44 PM
