The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Thread Tools Display Modes
Old 01-16-2005, 01:15 PM   #61
My Photos: (14)
Taping up the box for the resin pour..
I cut down the box I was using to fit the depth of the mold rubber, covered it up with a posterboard blank cut to fit, and taped up the edges to keep it together.
The tape is important, as it helps to compress the rubber just enough to make a good seal between the two halves of the mold, but not enough to distort the shape of the mold itself.
I taped around all four sides of the box, including the "top", where the pouring and venting holes are.
I cut openings so that I could access the pouring/venting channels, but still get compression around all sides.
The resin's about $36 for 4 pounds, and I probably won't need more than 1-2 pounds of resin.
And now, we wait... for my resin to arrive, probably by next weekend.
Giuliano is offline   Reply With Quote
Sponsored Links
Old 01-16-2005, 09:55 PM   #62
Grey's CarPC Specs
Vehicle: '94 Thunderbird
My Photos: (0)
hate to be the 6 year old school girl at an Nsync concert here, but this is really neat. how much do you estimate the project has cost all the way through the completion of the first bezel duplicate? and how much do you estimate each sequential bezel will cost (not including the mold creation cost)?
Grey is offline   Reply With Quote
Old 01-16-2005, 10:44 PM   #63
My Photos: (14)
Hey, my first fan!
Oh, and I noticed you joined the forums on my birthday, 8/26. Cool.
Well, the mold rubber cost me $86 for a 9-pound bucket, and I pretty much used all of it for this mold pour.
The $86 was a special deal, since it was my first order from Polytek, normally the cost is more, and includes shipping. I got free shipping for being a new customer.
Normally the cost is about $110-120 for a 9-pound bucket, depending on the cost of shipping.
I may have to order some more rubber, as later on I'll need to extend the mold in sections, and I'll need to re-pour some.
The resin that I ordered, Poly 1510, currently costs $36 for a 4-pound bucket, $102 for a 16-pound, and $420 for 80 pounds.
I ordered a 4-pound bucket, which should be enough for a few duplicates to start.
Once I pour the first duplicate, I can weigh it to get a good idea of how much resin I used.
I can't imagine using more than $10-15 worth of resin, especially if I order it in 16-pound buckets.
Old 01-18-2005, 03:33 PM   #64
My Photos: (14)
This just in - the 4-pound bucket I ordered cost me $25, not $36.
Why?
Because for every item that you purchase from Polytek, the first one of each that you order comes at a reduced price (free shipping).
I really should have splurged for a 16-pound bucket.. probably would have only cost me $75 (vs $102), and I'm sure I could have used the extra resin.
The stuff has a definite shelf life, but it would have lasted ~6 months or so at the least.
Old 01-18-2005, 06:02 PM   #65
Laptop, Tablets, UMPC Moderator
turbocad6's CarPC Specs
turbocad6's Avatar
Vehicle: 2002 pontiac montana
My Photos: (71)
are you going to chop & modify the newly moulded part, & then make a mould of that to produce a final finished product?
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is offline   Reply With Quote
Old 01-18-2005, 06:29 PM   #66
My Photos: (14)
Yes, and sort of.
Yes, I'm going to chop and modify the newly molded part.
No, I'm not going to make a new mold of the finished product.
I'm going to extend the original mold to fit the new modified part, by cutting out sections of the original rubber, and re-pouring small sections of rubber into the original mold to fit the new piece.
I'll mock up a drawing of what I mean in a few minutes...
Old 01-18-2005, 06:55 PM   #67
My Photos: (14)
Extended Mold..
Something like this.
The diagram on the top shows what the current mold looks like in a general sense - thicker mold on the bottom (front of the bezel), thinner on the top (back of the bezel).
The diagram on the bottom shows what the extended mold will look like.
The original mold will be cut out underneath the modified section of the bezel (in green), and new rubber will be poured in place underneath the modified bezel (gray).
After the green section of the rubber cures, any overflow or excess rubber would be trimmed, and then a new back for the mold would be poured on top (red).
So I'll most likely have to re-pour a section of the bottom part of the mold (which is thick), and a new top (which is thin), so I'd have to use some more rubber, but not as much as I would need to pour a completely new mold.
Old 01-20-2005, 05:07 PM   #68
My Photos: (0)
Come on UPS....deliver faster...
integramodder is offline   Reply With Quote
Old 01-20-2005, 05:25 PM   #69
My Photos: (14)
Patience.. it will arrive in good time.
Now, if I had received a tracking number.. then I could have hunted the UPS driver down..
Chances are the box will be sitting on my doorstep by the time I get home..
Which will be a few hours from now, I gotta work late..
Old 01-20-2005, 07:13 PM   #70
Graywolf's Avatar
Vehicle: 2003 Honda Civic Si
My Photos: (0)
You sir, are my new hero.
EPhatcher
Graywolf is offline   Reply With Quote
Sponsored Links
Old 01-20-2005, 07:30 PM   #71
My Photos: (14)
Awesome..
And I was right.. the resin arrived today.
But I'm not going to show you the resin... so there!
Just kidding.
The 4-pounds of resin arrived in 2 1-quart bottles, and is mixed in equal parts of each in a 1:1 ratio by either weight or volume.
I estimate that I've probably got enough for at least 2-3 pours.
Old 01-20-2005, 08:30 PM   #72
My Photos: (14)
Pressure-loading the mold.
The two halves of the mold weren't sticking together as tightly as I would have liked, so I took some pieces of plywood and some rubber bands and strapped some reinforcement across the front.
The horizontal pieces of plywood are loaded across each end with some rubber bands tied together, which go around the back of the box.
The vertical piece of plywood is the only piece touching the posterboard underneath, and is the piece that's actually applying pressure to the box.
If I had more pieces of plywood, I would have used three pieces vertically to spread the load better.
This ensures that the two halves of the rubber mold press against each other with enough force to make a good seal.
Next, I'll measure out the resin, mix it up, and make the pour.
Old 01-20-2005, 08:33 PM   #73
Vehicle: 2001 Honda Civic
My Photos: (0)
cant wait to see the result!
dannn is offline   Reply With Quote
Old 01-20-2005, 09:15 PM   #74
My Photos: (14)
Unfortunately, I can already see the result of this first pour - I got a messy puddle of uncured resin surrounding the box.
I must have not sealed the edges well enough, because of what I poured, most seemed to come out the bottom.
I'm going to have to wait about an hour or two for the remaining resin to cure, and then take it apart, clean out the cured resin, seal the edges of the mold with tape, and then re-assemble the box..
Gah, what a mess.
Old 01-20-2005, 09:54 PM   #75
My Photos: (14)
Failure #1...
Ok, I peeled apart the mold, and I can see where the resin escaped, and probably why.
The weight of the rubber probably caused the bottom edge to spread open, causing the resin to flow out and cause a mess.
After I let the remaining resin cure enough so I can peel it off, I'm going to take the mold out, and make something new to keep it together.
What I should have done was to cut two large posterboard pieces that fit the front and back shape of the mold, and then taped those two pieces together, kind of like a posterboard-rubber sandwich.
The two pieces of posterboard on the outsides would have taken the load of the weight off of the rubber, and the tape would have evenly applied pressure around all sides.
That, and taped the edges of the rubber to prevent leaks..
Sponsored Links
vB code is On
Trackbacks are Off
Class 2 Data Bus owenjh Engine Management, OBD-II, Engine Diagnostics, etc. 34 07-14-2007 02:13 PM
My Camaro Radio Bezel Fabrication Picture Diary (56k warning) meissenation Fabrication 35 01-12-2005 01:10 PM
Custom Secondary input using old radio bezel? anaxagoras Input Devices 2 11-03-2004 09:54 PM
Fm Radio vicky_obee Media Engine 9 07-01-2004 10:52 PM
How do i make Radio working in MediaCar? zvi MediaCar 0 05-16-2004 02:38 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
