The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Thread Tools Display Modes
Old 02-13-2005, 01:23 PM   #106
Vehicle: 2002 Subaru Impreza WRX
My Photos: (0)
Wink
Quote: Originally Posted by RonsWRX
This is true about the size! I checked the depth of the install tonight. The face of my unit is slightly protruding which at the bottom of the opening might make it difficult to have a cover. If you have any ideas on how I could get a cover for this, or how to move the unit back about two centimeters, I would be interested in listening.
Obtain a picture of the stock radio and have it printed out life size. Then just squeeze it in there.
N'CTRL is offline   Reply With Quote
Sponsored Links
Old 02-13-2005, 02:06 PM   #107
My Photos: (14)
Thanks for the logo link, that should help immensely.
I got the LCD panel and the motherboard this past week, so I can finally start to get the bezel into shape.
The LCD will be mounted to standoffs, and the standoffs will be screwed to some mounting blocks that sit in the radio area.
The bezel will be secured in place with velcro, or something similar.
Giuliano is offline   Reply With Quote
Old 02-13-2005, 04:52 PM   #108
C4M
C4M's Avatar
Vehicle: 2003 Subaru Impreza
My Photos: (0)
Quote: Originally Posted by N'CTRL
Also, for your logo needs go here, http://logos.subaru.com/logos/logos.html. Straight from the source.
I found that one last night as well - fantastic resource!
C!
http://carpc.riposte.net
I reserve all rights in connection to each post I author, without exception.
C4M is offline   Reply With Quote
Old 02-24-2005, 11:44 PM   #109
My Photos: (0)
any update on finished product would like to see some pics
i was gonna install a lilliput screen in my civic, using bondo reinforced with fiberglass. i told my project to a guy in my CNC machining class and he mentioned about cracking over time and that i should use rtv to mold it and make a single piece. then i looked it up on here and found this guide. and i was wondering he mentioned something about using microballoons and milled fibers. is this a good idea?
Master Sadon is offline   Reply With Quote
Old 02-25-2005, 07:42 AM   #110
My Photos: (14)
I haven't worked on the bezel for a week or so, as I've been working on the wiring of my LCD.. which has turned out to be rather difficult, very small wires.
Molding it out of one piece of material is a good idea.
Microballoons is basically a powder-like material that you can add to resin as a filler, to take up space and make the piece lighter. Think of them as microscopic glass balls or balloons, filling up space with mostly-air.
Milled fibers are good too, for strength.. basically fiberglass strands mixed into the material.
Sponsored Links
Old 03-09-2005, 11:54 PM   #111
My Photos: (0)
wow, interesting stuff....can this be used in pretty much anything or only for molding?
integramodder is offline   Reply With Quote
Old 03-10-2005, 05:25 AM   #112
Saab9-5's Avatar
Vehicle: 2000 Saab 9-5 SE V6
My Photos: (0)
I was also thinking of how to secure it.. magnetics would work, but I wouldn't want to put any magnets that close to the LCD, just because.
What do you guys have against magnets? LCDs aren't affected by magentic fields the way CRTs are. And they wouldn't have to be that strong. Four small ones, one at each compass point, would hold a plastic cover perfectly in place. Not to mention the clean look since the magnets could be on the inside.
Saab9-5 is offline   Reply With Quote
Old 03-10-2005, 05:28 AM   #113
Saab9-5's Avatar
My Photos: (0)
BTW, great work on this writeup. Because of this, I've been able to mold smaller parts - replacement buttons mostly - but plan on doing bigger things. Thanks for sharing your work.
Old 03-11-2005, 02:00 AM   #114
My Photos: (0)
So you can say with certainty that exposing an LCD screen to a magnet in close proximity won't have any adverse effects on it?
I ask because I know a little bit of how CRTs work and why they are affected by a magnetic field disturbance, but I don't know how LCDs work.
At least for me, it's just not wanting to take the risk at all because the LCD screen cost me so much to begin with.
2002 Subaru WRX - Silver
-FP18G turbo
-Walbro fuel pump
-Modified OEM 840 CC Injectors
-TurboXS: UTEC, turboback, uppipe, intake
-Blitz FMIC
-STI cluster
-17"x7.5" SSR Competitions
-Tein Flex coilovers
-NOS 50 shot
-2004 rear conversion
imprezive one is offline   Reply With Quote
Old 03-29-2005, 05:27 AM   #115
Saab9-5's Avatar
My Photos: (0)
That is correct. Active-matrix LCDs depend on thin film transistors (TFT). Basically, TFTs are tiny switching transistors and capacitors. They are arranged in a matrix on a glass substrate. To address a particular pixel, the proper row is switched on, and then a charge is sent down the correct column. Since all of the other rows that the column intersects are turned off, only the capacitor at the designated pixel receives a charge. The capacitor is able to hold the charge until the next refresh cycle.
You know that a CRT uses magnetic fields to aim the electron beam but LCDs just don't work that way. To even make sure I was right, I placed a magnet on top of an LCD of an old laptop and ran it for two days straight. No problems. As for the magnetic faceplate idea, I was only thinking of small magnets, no bigger than 1/2" in diameter.
Old 03-29-2005, 02:33 PM   #116
nzKAOSnz's Avatar
Vehicle: 1992 Subaru Legacy VZ Wagon
My Photos: (0)
btw - old cdrom drives have excellent little magnets in them.... quite strong for their size
92 Subaru Legacy Wagon
Epia MII12000 :D
Morex 80W
120G External HDD
16x2 Charater Display
Creative IR Remote
VIA Sereniti 2000 Mini ITX Case
7.2Ah SLA Tank
PCMCIA 802.11b
256DDR Ram
Diamonds are for girls- wise men follow the stars
nzKAOSnz is offline   Reply With Quote
Old 03-30-2005, 12:23 AM   #117
My Photos: (0)
that info has given me a world of new ideas... sweeeet.
-FP18G turbo
-Walbro fuel pump
-Blitz FMIC
-STI cluster
-NOS 50 shot
Old 04-27-2005, 02:59 PM   #118
Vehicle: 1999 Dodge Durango
My Photos: (0)
Just take a look at the new cell phones. They have both magenets and LCD screens with no problems..
www.DurangoSUV.com
The Durango Kid is offline   Reply With Quote
Old 05-06-2005, 11:34 AM   #119
My Photos: (0)
Are you going to use the Polytek 1510 for your final bezel ?
I want to put my epia pc in a hidden compartment in the trunk of my 1'er.
It is a really weird shape and want to pour a custom enclosure in that shape.
Is the polytek stuff strong enough for such a build ?
BTW: How's the bezel going ?
Krewten is offline   Reply With Quote
Old 06-30-2005, 07:20 PM   #120
My Photos: (0)
hey wondering how the project is going and y u stopped posting hope u didnt run into any big problems would love to see your progress
Starting an install in a 02 s4 when I get time, which will probably about the time i am looking to sell the car. Got to love it
vipergda is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Class 2 Data Bus owenjh Engine Management, OBD-II, Engine Diagnostics, etc. 34 07-14-2007 02:13 PM
My Camaro Radio Bezel Fabrication Picture Diary (56k warning) meissenation Fabrication 35 01-12-2005 01:10 PM
Custom Secondary input using old radio bezel? anaxagoras Input Devices 2 11-03-2004 09:54 PM
Fm Radio vicky_obee Media Engine 9 07-01-2004 10:52 PM
How do i make Radio working in MediaCar? zvi MediaCar 0 05-16-2004 02:38 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
