Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 01-03-2005, 03:34 PM   #1
Peugeot 306 7.5in Widescreen install
I originally had my Monitor, a 7.5" centurion widescreen mounted on top of the dash but i couldn't stand it there. I had a bit or fibreglassing experience so i wanted to make my own dash install. The original dash looks like this.. so you can see my problem.
I had to rip out the top vents and the din-slot to get the dash anywhere near capable of holding the screen.
After i'd done this i cut the shape out of some ply-wood and began fibreglassing the wood. I put about 3 layers of matt on just so it wouldnt snap when i prised it off, and it didn't. I cut the general shape and sanded the edges etc and cut a hole (square) in the middle for the screen.
Then i measured some cardboard out for the back of the screen and made a box for the screen to sit in (sorry if this doesn't make sense it's hard to explain!) i fibreglassed the box to the back of the shape (behind the square) i had created for the dash and tested for a fit.
The rest was filling, sanding and painting.
I've noticed there are a few people with 306s on this forum, i'd really like to know how you did your screen
alanp is offline   Reply With Quote
Old 01-03-2005, 03:51 PM   #2
Caitlin's Avatar
Yeh, I got my 306 fascia half off tonight and realised that the heater controls arn't attached to it at all I think i'm going to have to go the same way as you have.... what have you done with the heater outlets? did you move them someplace, or are they happily keeping the back of the lcd hot?
I'm going down to a breakers to look at complete fascias, it seems that the xlt or glx (can't remember off the top of my head) version has a 2 din size hole... but i'm not sure if you can switch them out easily :/
Why the demise of the temp and clock controls?
It's looking good, how do you find the angle of the screen in use?
Getting my screen on weds... can't wait to furtle!
Nice job though, well done.
Cat
Woot, or something.
Epia M10000 (less rubbish than the 800) :: LCD touchscreen
GPS :: 80G drive :: Not enough ram... Never enough..
Website in progress(only started writing it recently (for the pedants))
Caitlin is offline   Reply With Quote
Old 01-03-2005, 04:03 PM   #3
MySQL Error
jcdillin's Avatar
sheesh you moved your steering wheel to the other side of the car just to mount a screen?
looks great!
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 01-03-2005, 04:12 PM   #4
Caitlin -- I didn't originly have temp and a clock, the pic above is from google.
everything's the same minus the heating vents and the DIN.
The angle is great! it doesn't reflect nasty light and glare in the day.
Good luck with your project, let me know how it goes!
jcdillin - i *knew* someone would say that haha
Old 01-03-2005, 04:54 PM   #5
Caitlin's Avatar
's ok, I nipped round and fixed it with some mdf and sticky back plastic.
looks great now....
..had to do the old time travelling crap to fix the *before* of course
Where's the head unit now though? or is it going straight to amps?
Cat
Woot, or something.
Old 01-03-2005, 06:05 PM   #6
SpacemanSpiff's Avatar
If you want to keep the headunit, I mounted the screen down where the ashtray is, not ideal, but I've taken it all out as I'm getting a Golf Mark V, probably going to be even harder to get everything in.....
alanp - Am interested as to what exactly did you do with the heating vents? Did you vow never to use the heater again incase it superheats the screen!!
SpacemanSpiff is offline   Reply With Quote
Old 01-03-2005, 07:04 PM   #7
Nice Caitlin
Na I dont use a headunit anymore. I was going to but i soldered it and.. well.. err u can guess the rest
I fibreglassed up the heating duct so all heat coming from the engine is diverted to the two side vents or the windscreen or whatever. It's better because i can melt windscreen ice quicker as more air is directed to the windscreen. it's just like having the two old center vents off.
Mounting it below the ashtray sounds like a gd idea. Got any pics? What's the angle like to view?
Old 01-04-2005, 02:32 AM   #8
Raw Wave
Hey guys,
In the process of fitting my 7" TFT in my Pug 306. Goign the same route - ripping the vents and headunit out but will be using the existing fascia unit as want to integrate the screen into the dash itself. Will post pics once done - went to the scrapyards the other day to rip a dash apart on a Pug 306 so I knew exactly what I was doing before I messed with mine!!!
Gobby is offline   Reply With Quote
Old 02-01-2005, 05:14 PM   #9
MySQL Error
Scouse Monkey's Avatar
Hi alan, jsut chating to you over on the other thread. I am planning on keeping my vents which is gonna be a mission and i planning on keeping a HU in the dash and fitting a slot DVd so its gonna be tight!
edit: oh and i have AC so i have an extra couple of buttons under the heater controls! very tight indeed!
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 02-01-2005, 05:21 PM   #10
Yeah definitly tight! are you sure there's room for all of that! i looked at moving the heating controls down a bit but i think there's only 1 other thread that discusses this and it's not even peugeot specific, let alone 306 specific!
I would have liked to keep my headunit too but to be honest, i just wanted it all in quickly and the epia soundcard does the job.
Nice to see another 306 owner with plans for an install
306 CarPC
  • Fibreglassed lcd installed into dash
  • Griffin PowerMate
  • epia 800 512mb sdram
  • MediaEngine
  • MapMonkey
Old 02-01-2005, 05:29 PM   #11
MySQL Error
i've been planning for ages. slowly getting parts. I was gonna get an Alpine amp and go headless but i am worried about getting decent radio reception and sometimes you dont want to mess with the PC or if it is being an *** you have no music.
If you search some of my threads/posts you will see my original ideas with some buttons next to the screen and also i put the data about the steering wheel controls up as i was gonna use them to control the PC. Int he end i went out and got a sony HU (bit of a spur of the moment thing) and now have a sony joystick remote instead and i am gonna use the HU to control the PC - need to make my own skins with no volume control as i am using the HU control.
As for the heater dials - i have plans! i ahve spare controls and centre facia and switches off ebay and took the controls apart and plan to mount the circuit board inside the dash with the dials (and resistors) mounted lower down. The cables vent control will be hooked up somehow - either flexible linkage or gears.
I was gonna leave the controls and make some lim vents and put the HU face where the clock goes but i didnt fancy making vents as i think they will look crap so am gonna do some major work lower down i think. only problem i have is I have run out of room for the 2 fog light switches after moving everyting. Damn!
Screen will hopefully be here soon so i can get on with it! Keep an eye out!
Old 02-01-2005, 05:43 PM   #12
yeah that was my thought, i tried to solder the faceplate to the HU with Cat5 cable like someone did here - NOT a good idea unless you can work with that stuff. It really aint made for intricate soldering and is not flexible at all. Hence no headunit anymore
[quote]
[!/QUOTE]
Yeah i saw that, i tried that too but settled for a griffin powermate to controll all the bits.. I had a keypad immobiliser that was made redundant after i install a clifford remote start, so i mounted it there (under ashtray).. looks pretty factory (well, about as factory as a big volume knob can)
[quote]
[!/QUOTE]
dont you need a controller board interface for that? i read about someone that made one once.. looked far too complicated for my tainted soldering skills hah
I like your heater idea.. sounds like its gonna be a great install! keep me posted
306 CarPC
  • Griffin PowerMate
  • MediaEngine
  • MapMonkey
Old 02-01-2005, 05:44 PM   #13
ok, i cant quote like that
306 CarPC
  • Griffin PowerMate
  • MediaEngine
  • MapMonkey
Old 02-01-2005, 05:48 PM   #14
MySQL Error
the stering wheel controls are easy - just either hook them up to a joystick port, a serial board or even easier hack a usb gamepad. i miss those controls - the simple lever is much nicer than the sony joystick. But the sony has lots of functions and is voice activated when you press a button on the joystick - so i willhave a voice activeted PC without the trouble of running voice software on the PC!
Old 02-01-2005, 05:53 PM   #15
Nice!
306 CarPC
  • Griffin PowerMate
  • MediaEngine
  • MapMonkey
cloudy's 406 install Jamez_Warner Show off your project 48 11-18-2005 12:53 PM
Peugeot 605 TD Carputer install 8"TSK/GPS/DVD... sixofive Show off your project 18 02-02-2005 01:40 PM
Peugeot 206 2.0 HDI Install. (56K watch out) cbyriel Show off your project 21 11-11-2004 07:21 AM
Peugeot 205 install with a portrait LCD (finally) MikeHunt79 Show off your project 6 04-29-2004 07:02 PM
Peugeot 306 TD-OBD? sygad Engine Management, OBD-II, Engine Diagnostics, etc. 0 12-22-2003 07:06 AM
