Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 01-04-2005, 10:58 AM   #1
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
Project: Toyota Matrix indash LCD process (56K no go).
Many of you guys inspire me to "indash" my Matrix setup. I have everything up and running with the Lilliput attached infront of the radio. Now it time to make it look GOODDDD.
Original dash look.
The Lilliput in infront of the radio
This is where a Single DIN Alpine CDA-9830 HU going to be install. The Aux/cig power outlet will be remove. The 115V switch and plug will be relocate to somewhere I havn't figure out get.
Closeup for the Lilliput
Flip down the Lilliput. The radio has been modded for aux audio input by spliting the CD audio.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 01-04-2005, 11:10 AM   #2
MySQL Error
MatrixPC's Avatar
Radio bezel removed
I bought a use radio bezel from another matrix owner for 20 buck with some scratch. That doesn't matter cuz I will sand and bondo over it.
This is the back of the bezel. There are some switches (AC, Hazard, Recir, ..) attached to those holes.
Lilliput case I bought from Armen a while a go for 15 bucks. The Lilliput is a little taller than the double DIN opening of the bezel but narrower.
This saw did the job of cutting the bottom part of the bezel out.
Wet sand the silver paint out.
Now I need to glue the 2 togethers. The bezel is made of ABS plastic. What type of adhensive should I use? I know I have to do some searching and reading on this forum to see what you guys use to glue the 2 together.
I currently have Bondo and Bondo Glass, Can I use it that or it will crack on me? This set up have to be perfect that is why I ask. I saw others using the more flexible stuff for bumber repair. I may look into that material.
Old 01-04-2005, 11:35 AM   #3
hd54321's Avatar
hd54321 is on a distinguished road
Where did you get that clip for the lilliput? I need something EXACTLY like that for my Xenarc install.
Can you give me more details about the hinge, the hardware, is it sturdy enough to survive bumps in the road, etc. Thanks!
-HD
hd54321 is offline   Reply With Quote
Old 01-04-2005, 12:13 PM   #4
MySQL Error
MatrixPC's Avatar
-HD
You can get all from HomeDepot. The hinge is a 3" or 2.5" door hinge. The "clip" is a piece of metal (wood join???) from HomeDepot and I just bent it to the curve of the Lilliput. Velco to the top of the radio. I have no problem goign over speed bumps and pothole.
Old 01-04-2005, 12:25 PM   #5
hd54321's Avatar
Brilliant!!! I've gotta check this out now...I need something EXACTLY like this. Thanks.
-HD
Old 01-04-2005, 06:37 PM   #6
MySQL Error
MatrixPC's Avatar
What type of plastic is this Lilliput case? I can't find any stamp/reading on the case.
Will this adhensive SUPER GLUE ARALDITE 90 Second Super Instant Epoxy by Pacer Technology
bond the Lilliput case and my bezel (PC+ABS) plastic together??
Old 01-04-2005, 06:47 PM   #7
VanMan69's Avatar
VanMan69 is on a distinguished road
I think that stuff will bond an elephant to an airborne 747 (even an elephant laminated with ABS). You should be okay.
95 Chevy G20 Vroom Boom Room
...with a whole bunch of nifty ****... go check it out: VanDomain Page
VanMan69 is offline   Reply With Quote
Old 01-06-2005, 11:41 AM   #8
MySQL Error
MatrixPC's Avatar
Well, I did a little bit of work yesterday.... Sand the bezel and the Lilliput case a little bit and glue/epoxy them together. The bezel is a little wider than the Lilliput case so I have to use some balsa wood to fill the gap.
Back with epxy fill in
Front.
Waiting for the thing to cure. Any comment and suggestion is welcome.
BTW, I will be using SEM: Bumper Repair #68422
to fill and sand instead of bondo/bondo glass. Maybe bondoglass in the back to add some strength.
Old 01-07-2005, 10:06 AM   #9
MySQL Error
MatrixPC's Avatar
Test fit: Now you guys can see where my Earthmate GPS is. That little yellow thing deep inside the dash.
SEM bumper repair apply and wait for sanding.
Old 01-07-2005, 10:38 AM   #10
residentalien is on a distinguished road
for future reference check out duramix, they make a range of ABS plastic fillers and putties, its a bit more expensive that the epoxy's but it sticks to anything, sands really whell and looks amazing, its like liquid plastic and it sets in 15 minutes.
Cheers,
Grant
'03 Corvette Z06 - car pc soon
'99 Eclipse GSX
'03 Ducati Monster
residentalien is offline   Reply With Quote
Old 01-07-2005, 10:58 AM   #11
MySQL Error
MatrixPC's Avatar
Thanks for the tip. I search around and people also recommended duramix stuff. On the other side people also recommended SEM as duramix subtitude. I am not sure how good this one when I do wetsand, but it doesn't hold well if the part is not sand before apply.
Old 01-11-2005, 09:54 AM   #12
MySQL Error
MatrixPC's Avatar
Angry
After couple coat of SEM Bumper Repair and sanding, and sanding, and sanding. Prime with Plastikote Sandable Primer. This is what I came up with.
But the lower left corner is ***** up a little. Dam. I must of have to wait more for the stuff to dry and pre-sand a little better.
After cutting out the "bad" part and sand. This is the close up after clean up.
This is the closeup of the repair of the "damage" lower left. All smooth now. I just have to wait for it to completely dry and prime again then .... more sanding.
Old 01-11-2005, 09:59 AM   #13
MySQL Error
MatrixPC's Avatar
Bye bye, Cig/aux power outlet, 110V switch and outlet
Say hello to the new Alpine CDA 9830. Now I just have to secure the new HU in its place.
Old 01-11-2005, 10:23 AM   #14
gizak's Avatar
gizak is on a distinguished road
Coming along nicely! I've always liked the Matrix. I assume you already tested the GPS mounted inside there? Seems like most are putting it as close as they can to a dash area to get better signal. Anyways, keep up the good work!
-GiZak-
Carputer Project: 98% Complete!! *tweakin'*
Xenarc 7TSV | Opus 150 | Biostar M7NCG400 | Athlon Mobile2200 | Seagate 160Gb | Kingston 2x256mb | BT Holux GR-231 GPS | LiteOn CD-R/DVD| Keyhole Rev. Cam | Zippy Mini-glow Keyboard
gizak is offline   Reply With Quote
Old 01-11-2005, 03:20 PM   #15
slangnasty's Avatar
slangnasty is on a distinguished road
looking good matrixPC.
Still haven't performed my in-dash yet. I'm watchin this thread to and taking notes .
also about the GPS, are there any vents located directly above the GPS?? or just solid dash. Does it work well in all conditions?
Asking because I am getting ready to replace my current GPS with a new one and I am considering mounting mine "in-dash" also.
great job so far!
- CarPC install complete.
- CarPC software: CENTRAFUSE
- Planning/working on in-dash for lilliput monitor
slangnasty is offline   Reply With Quote
1999 Honda Prelude Indash (56k Beware) SuperDave01 Fabrication 15 12-04-2007 12:59 AM
Toyota Celica 2000-> GT/GTS and LCD Goose LCD/Display 90 12-24-2005 11:34 AM
WTB: Indash Project Housing (7" LCD) Ninja Monkey Classified Archive 0 12-21-2004 08:49 PM
LCD / VCD Character Displays: Matrix Orbital VK202-25 & Seetron BPP-420VY hevnsnt Classified Archive 5 06-14-2004 10:26 PM
