02-12-2005, 02:13 AM
#1
Vehicle: 2004 Mazda 3
best way to cut plastic?
Hi guys-
well- i'm getting closer to my install and now I'm starting to think about some fabrication stuff and I was wondering what's the best way to cut plastic? I'm going to need clean edges and no cracks? Is there a way I can melt it to cut it or do I need to purchase a dremel and some special tips? Thanx in advance.
Peace
Michael
Mazda 3, meet Mac Mini. Mac Mini, meet Mazda 3.
Mac Mini in-car coming soon.
Progress: [||||||||||||||||||--] (90% Complete,Initial install is complete, now adding on and fine tuning.)
Progress Blog: http://mikemazda3.blogspot.com/
02-12-2005, 02:29 AM
#2
Vehicle: Civic EP03 2004
I've been workin with plastic for years and I'm using old kitchen knives! Mark your cutting lines with aliminum tapes and heat the knives above open flame before slowly using them to cut. Finally a sand paper or a sharp cutting tool may help you to remove any residues...
(please work out on a spare part of plastic first because needs some practice)
Hope this helps...
Upgraded to a Civic lately and just started construction...
02-12-2005, 03:00 AM
#3
MySQL Error
Vehicle: Pug 306 & BMW 325i
water jet cutter - but i doubt you have one of those.
as volcano says, use knives but i would use a hard edge against the blade protecting the part you don't want to slip into. And be very careful.
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
02-12-2005, 03:11 AM
#4
Vehicle: 2002 Nissan Altima
is there a dremmel bit that is recommend? or do you stay away from the dremmel al together?
02-12-2005, 03:21 AM
#5
Vehicle: 1999 Isuzu Vehicross
I used a file and filed away the excess plastic... drilled a hole and then made it bigger to fit, came out ok
[------|-] 95% computer... is it ever really done?
www.vehicross.info for all you VXer's
02-12-2005, 03:33 AM
#6
Vehicle: 01 MB SLK
I saw a special toothy cutting wheel for dremmel that cuts wood and plastics. I think i saw it on ebay or on this forum.
No need to reach for them though, as standard cutting wheels work really good. They melt a plastic a little even in l,owest 5000 rpm- no biggy, worked for me nice, specially on epoxy.
02-12-2005, 04:22 AM
#7
Vehicle: 1999 Volvo S40 SE
with normal cutting wheels on a dremel, only cut in stages, giving the wheel itself a chance to cool for a few seconds (i.e. 1sec pressing on plastic, 1 second away from plastic)
Otherwise you risk shattering the disc with possibly painful consequences.
02-12-2005, 04:51 AM
#8
Wow-
thanx for all the great replies so quickly. You guys kick ***.
Michael
02-12-2005, 04:57 AM
#9
Vehicle: 1995 FTO
When I did my dremel cutting I used the toothed steel saw wheel (like a tiny circular saw blade). I didn't think it would work well at first, but if you keep the revs very high i had some very good results, though this was for plastic removal where finish wasn't critical.
If you want to cut very straight and neat edges though, I would recommend volcano_c's knife technique above (which I wish i'd thought of when I was doing mine  ) or a junior hacksaw with the work clamped against a steel plate as per scouses comment. (it's so easy to slip once and wreck the finish on the surface you want to keep).
02-12-2005, 08:09 AM
#10
_
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
I was going to suggest a dremel as well since that's what I've used. We just use the regular cutting wheel that comes with it to get a general cut, then just sand it down to get rid of all the burrs and clean it up.
Pretty easy....just be sure to wear a set of goggles and a mask for your mouth.....that plastic stuff can release some nasty fumes that will make you gag, not to mention it will throw crap everywhere.....=]
have fun!
02-12-2005, 07:43 PM
#11
Vehicle: 2002 Altima 3.5 SE
This is the best:
http://www.ares-server.com/Ares/Ares...oduct&ID=82088
Just hook it up to 12V. No smell, no molten residue, no exploding discs, just a nice clean cut even around corners.
2002 Nissan Altima 3.5 5 Speed Bose FM/6CD ED E12A P4 2.26 512 Ram Ti4600 CDRW DVD Lilliput 200mW 802.11b Trackman AutoTap GPS Opus 150 Carnetix 1260
2005 Nissan Titan SE Dell GX-150 P3 1.0 512 Ram 20G GF4 MX4000 USB 2.0 DVD/RW Xenarc GPS Trackman
02-12-2005, 08:17 PM
#12
Vehicle: 2001 Paper Airplane Standard Edition
I would probably stick with the normal cutting wheels over a serrated one. I'd think the teeth will tear the plastic up. The normal cut wheels do a good job of melting the plastic away and flinging it on your arm and face. Just cut on the surface and slowly work your way through, and keep applying and removing the wheel from the surface or else you will melt away a big clot. If you don't have a dremel yet, I would recommend purchasing one anyways. You'd be amazed at all the things it will help you make, repair, and clean. Especially when you get into the specialty bits.
| Thread Tools |
| Display Modes |
Linear Mode
