paint on a dash piece will never hold up as well as the OEM stuff...but how long are you wanting it to hold up? for 10 years? your OEM dash won't even last that long if it's left out in the sun...
how often do you park out in the sun? that's something to consider...
one thing about bondo work and the sun is that you run the chances of having your break lines show up....though it could be very small, it will pop up eventually....no matter how well you blend it....it's just a difference in material....
I don't see a problem in doing what you have mentioned with the clear coat, etc. just remember what you want to do with this....is it going to have to be flexable like the OEM piece is so that when you go to put it in it wont crack? just some things to consider...
