Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 04-11-2005, 07:38 PM   #136
cfcrafting is on a distinguished road
featherlight is a two part pourable plastic that forms much harder than abs and is easier to work with than melting legos with acetone. I wasn't trying to start a flamewar at all, sorry if I came across that way. I found this site smooth-on.com by answering some of my own questions. How is abs plastic made? How can they inject it into a mold. A. It must be pourable therefore it must be a liquid of some sort. A search for liquid plastic revealed this company.
cfcrafting is offline   Reply With Quote
Old 04-11-2005, 07:42 PM   #137
natebest2000 is on a distinguished road
10-4. I apologize for jumping the gun.
natebest2000 is offline   Reply With Quote
Old 04-11-2005, 07:45 PM   #138
Raw Wave
shotgunefx's Avatar
shotgunefx is on a distinguished road
Quote: Originally Posted by n8scstm
They do make abs pipe. As said, it is the black pipe (not the iron black pipe LOL) at home depot. The difference is that abs (PE or polyethylene) is a thermoplastic meaning it can be melted and therefore, welded to itself. PVC is a thermoset. It can not be melted and used for anything useful except a big stinking glob of melted, burnt dog **** and maybe to get high.
PVC has one good use. Potato guns.
shotgunefx is offline   Reply With Quote
Old 04-11-2005, 07:51 PM   #139
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
and bondage gear!
apparently!
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 04-11-2005, 09:34 PM   #140
DK888 is on a distinguished road
Ok.... I'm assuming that the ABS/acetone mixture is a bit on the thick side...or is it? And how thick is the mixture for Featherweight? I don't think i'm that advanced to start making molds but, I would like to mold my monitor to the dash as a beginning project. Hence, filling in the gaps that I already have. How much did the lego and acetone project cost? and how much does the Featherweight cost?
DK888 is offline   Reply With Quote
Old 04-11-2005, 09:41 PM   #141
Red Ranger is on a distinguished road
I got my acetone from Menards, It was like 4 or 5 bucks for a 32 ounce bottle. It was in the paint section. I have seen it at Auto zone also over by the touch up paint but that was like 7-8 bucks a bottle. Basically, any hardware store will have it. Check by the paint thinner (Acetone is an epoxy thinner)
As for the thickness, I have only used it with acryilic and it is pretty thin. kind of like a syrup. I put too much acrylic in my bottle and have a large lump of it in the bottom of it. I figure when i get low, i will just add some more acetone to the mix to thin it out and disolve the rest of it.
Brian
Red Ranger is offline   Reply With Quote
Old 04-11-2005, 09:45 PM   #142
Brian
How come you went with acrylic instead of the ABS?
Old 04-12-2005, 12:39 AM   #143
the featherlight trial kit makes 2 quarts is $20, that's a whole lot of lego's and acetone. It's as thick as water. I'd suggest filling in gaps with bondo or filler material. Before you start making molds you need a finished plug.
Old 04-12-2005, 12:44 AM   #144
The case i built is acrylic and i want to make the top and sides one peice to make it a cleaner looking install and all the sides meet together.
I actually doubt i will mount the screen in my dash.
I am going to mount the CD drive in my dash above my stereo though.
Brian
Old 04-12-2005, 02:23 AM   #145
Ok..thanks for the feed back you two. I'll experiment on some old pieces first before i mess up my dash.
Old 04-14-2005, 03:30 AM   #146
Subwoofer87's Avatar
Subwoofer87 is on a distinguished road
I just read this whole thread and this looks like a very good idea. I have never fabricated anything in my life and my screen and metra kit should come in the mail tomorrow. I think I am going to take this route even though I was going to have my friend who is experienced with fiberglassing help me.
My dad does construction/plumbing/tile setting/electrical work so I already have acetone and ABS pipes available to me and Longs/Wallgreens is right around the corner for the condiment bottles. We also have a router so shavings will be incredibly easy to get.
I will be sure to take and post pictures of my process if I do choose this method.
Subwoofer87 is offline   Reply With Quote
Old 04-14-2005, 06:41 PM   #147
Iatrogenic2 is on a distinguished road
The ABS Acetone mixture can be as thick or thin as you want...just vary your ratio. I used some thick stuff to get the general shape then used thinner stuff to fill in any air pockets I got from working too fast.
1997 VW Jetta GLX VR6
old HP MP
PIII 600 or so 256 MB
7" Xenarc
and some plywood holding it all together
My Project
Iatrogenic2 is offline   Reply With Quote
Old 04-15-2005, 01:28 AM   #148
That makes sense! I'll definitely give that a shot. Thanks!
Old 04-19-2005, 02:30 AM   #149
Cryogen97 is on a distinguished road
I think for just glueing bits together, that's a great idea. I can't believe I've never thought of doing that myself. I chose fiberglass to work with because I was actually creating new parts. Achieveing a nice curved panel where there used be all sorts of pocket 'n' junk is the true calling of fiberglass.
AutoPC: M10k, WinXP, gps, wifi, 80GB HD, dvd-RW. SB mp3+
MediaEngine front end, map monkey, netstumbler.
gps mouse is on the fritz.....stupid technology
Cryogen97 is offline   Reply With Quote
Old 04-20-2005, 11:23 AM   #150
I'm going to learn the art of fiberglassing soon. Can't wait to itch! But the results i'm sure look great.
Need help! Motorized in-dash LCD enclosure semester project. RPI Geek Fabrication 29 12-14-2006 10:19 AM
People with tuners who work with radiator NATIVELY. nappyjim General Hardware Discussion 4 02-18-2005 10:24 PM
stupid people ,aking me get a lawyer wizardPC Off Topic 3 02-09-2005 09:14 PM
Ok, people asked, i finally have pics of the "behind the scenes" install Urinemachine General Hardware Discussion 15 07-24-2004 12:20 AM
The bad news is PEOPLE ARE STUPID!! cproaudio General MP3Car Discussion 4 08-07-2003 01:25 AM
