Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 03-16-2005, 10:57 PM   #31
woeful is on a distinguished road
can this liquid acrylic uses as glue to glue 2 pieces of acrylic together? btw, where do you get this at? I only saw acrylic glass at home depot
Quote: Originally Posted by dave2
I'll share a couple other ideas.
Liquid plexiglas is a liquid acrylic that you can pour and sets up clear, plus it doesn't need any strengthening material like the fiberglass mat. The reason we use fiberglass with epoxy is that the resin doesn't cure stable, it cracks very easy and only has strength in thick blocks.
Also, MEK methyl ethyl ketone is polyester resin hardener. You can find it at any marine supply shop, along with fiberglass stores and plastic depot, like TAP plastics.
They will also have acrylic sheets and acrylic bonding solvents at TAP, and most of the pourable plastics.
The main reason people use fiberglass and bondo is because they don't pour, they spread. It's very difficult to make a reverse mold that you can FILL with an acrylic or ABS formula where it will come out smooth. It's much easier to sand bondo. That said, you can come up with some cool results using the acrylics.
I've used all of these methods extensively, and if anyone needs help with them, please ask.
woeful is offline   Reply With Quote
Old 03-17-2005, 02:42 AM   #32
dave2 is on a distinguished road
It's right in the middle of what you quoted. TAP Plastics. And if you want a lot of the liquid acrylic, they sell it at select products.
dave2 is offline   Reply With Quote
Old 03-17-2005, 03:39 AM   #33
Squid's Avatar
Squid is on a distinguished road
So your using PVC pipe??? or do they make an ABS pipe? I guess it's the same? dunno..
That Oatey ABS cement looks slick.. you'll have to post your results with that too...
Do you think that you could accelerate the drying of the sludge by using heat?
And for creating shavings, you could use a rasp type file which u could shave the pipe with...
And for breathing protection, I get 3M throw-away respirators for $16 bucks that work awesome...
They are good for about 8~10 hours of organic fumes if not a little longer.. and then come in handy for dust after that.
CarPuter: Dell P3-500 Laptop; D-Link WiFi; Deluo GPS; D-Link Radio; iMac DVD w/ ide2usb
Audio: Audigy 2 NX; Kicker KX700.5 amp; 20w center amp; Kicker L7 10" Sub
Display: Lilliput 7" TouchScreen
CarPuter Install
Squid is offline   Reply With Quote
Old 03-17-2005, 07:26 AM   #34
coachreed's Avatar
coachreed is on a distinguished road
The white or gray pipe is PVC... ABS pipe is the black stuff... I guess they would both work but if I ever get a scratch in the paint finish of my dash, I'll have a black scratch not a white or gray one...
Coach... aka Randy! (I often forget who I really am!) ;)
***Too many pieces and parts to list... maybe someday I'll show'm to ya!***
coachreed is offline   Reply With Quote
Old 03-17-2005, 01:23 PM   #35
Jesus Freak
antimatter's Avatar
antimatter is on a distinguished road
Keep us posted on your progress.
antimatter is offline   Reply With Quote
Old 03-17-2005, 01:59 PM   #36
Raw Wave
EsKALad's Avatar
EsKALad is on a distinguished road
lets seee some pictures of how yours turned out..im sure alot of us are curious to how it looks before we begin!
EsKALad is offline   Reply With Quote
Old 03-17-2005, 05:08 PM   #37
coachreed's Avatar
I need to go hit the hardware store to get some bits for my dremel... I'll need to smooth out a few areas, and then build things up in a couple others... I'll try to get some work done tonight and maybe get some pictures posted up tonight or over the weekend... I'll check back in a bit... later!
Randy
Old 03-17-2005, 05:24 PM   #38
coachreed's Avatar
I meant to reply to your comment... just for the record, the final product will look no different whether you use the old bondo and glass method or do the plastic... the difference is that most likely if not definitely, the glass and bondo will crack... the plastic won't... as long as your prep work is meticulous... anyway, once I'm done with the sanding and stuff... the paint (if I do it) may not be GREAT as I suck (or at least HATE) painting... lol
Later!
Randy
Old 03-17-2005, 05:25 PM   #39
Stank Cheese
n8scstm's Avatar
n8scstm is on a distinguished road
This is where I have purchased all my acrylic stuff. http://www.ipscorp.com/ind_html/indprdcts.html
I have used the solvent and it is very strong. Some people will take acrylic chips and the solvent and mix them to make a cement, or you can purchase it in a tube. The problem with this is that the dash and the monitor case are not acrylic. So they may stick but they will not bond. I believe it's more like PP (polypropylene) or PE (ABS/polyethylene), which can actually be welded with heat, but can not be bonded my disolving the material then letting it harden again. You can glue it with some high strength epoxy though. So for the dissimilar materials I think structurally fixing the pieces with epoxy then finishing in either fiberglass (for high fill areas) or bondo (for low fill areas) would be the best method.
Another good source of info on this plastic stuff is http://www.eng-tips.com/threadforum.cfm?lev3=80
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
8" Lilliput touch screen
IGuidance
dual optimas
battery isolator
15" screen
My Truck
n8scstm is offline   Reply With Quote
Old 03-17-2005, 05:30 PM   #40
Stank Cheese
n8scstm's Avatar
They do make abs pipe. As said, it is the black pipe (not the iron black pipe LOL) at home depot. The difference is that abs (PE or polyethylene) is a thermoplastic meaning it can be melted and therefore, welded to itself. PVC is a thermoset. It can not be melted and used for anything useful except a big stinking glob of melted, burnt dog **** and maybe to get high.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
Old 03-17-2005, 05:47 PM   #41
Pestilence is on a distinguished road
ABS and PE are two very different plastics also - ABS a lot like PVC with regard to solvents. I keep my dissolved ABS in a PE container. I don't know about your dash, but I'm pretty close to 100% sure my F-150 has an ABS dash.
Pestilence is offline   Reply With Quote
Old 03-17-2005, 05:57 PM   #42
Stank Cheese
n8scstm's Avatar
Very differnet but both are thermoplastics. I read on a site that they were the same but thought it was odd that they said that. Thanks for the correction. The dashes are abs, but what about the cases? I'm not so sure about those. It's not the easiest material to vacuum form. But now that I think about it they probably injection molded them so its possible that they are abs too.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
Old 03-17-2005, 06:44 PM   #43
DeltaFX's Avatar
DeltaFX is on a distinguished road
Acetone can be used to glue ABS parts that fit tight. Use a toothpick and pour a small drop of acetone. It is more soldering than gluing
DeltaFX is offline   Reply With Quote
Old 03-17-2005, 09:40 PM   #44
coachreed's Avatar
I thought I'd try something new... so I thinned my ABS glue down a bit, squirted it on... and then I used a rubber spatula to spread it around a bit... at this point, including chopping up ABS material to mix my sludge, mixing it and waiting for to dissolve, prepping the parts to glue together, making my first application, sanding, making my second application... my total time spent working in this, I bet I don't have more than an hour or so... more time thinking about it than anything... I think as thin as I applied this layer, I can probably do some sanding tomorrow and be nearly done... I might make one more small, thin application, sand, prime and paint... honestly, this has been easier than any other work I've done... and I've been installing car-audio since '90... here are a couple pictures...
TTYL!
Coach
Old 03-17-2005, 10:46 PM   #45
galpd320's Avatar
galpd320 is on a distinguished road
Any ideas on making large dash panels using this meathod or would it only be useful for peices that fit closely already.
I am looking to make a large panel to mount the LCD flush into the top of my dash, but I don't like the idea of the fiberglass potentially cracking.
My Mazda 3s Carputer Project
(--------------------) 0% complete
Research & Development Stage
galpd320 is offline   Reply With Quote
Need help! Motorized in-dash LCD enclosure semester project. RPI Geek Fabrication 29 12-14-2006 10:19 AM
People with tuners who work with radiator NATIVELY. nappyjim General Hardware Discussion 4 02-18-2005 10:24 PM
stupid people ,aking me get a lawyer wizardPC Off Topic 3 02-09-2005 09:14 PM
Ok, people asked, i finally have pics of the "behind the scenes" install Urinemachine General Hardware Discussion 15 07-24-2004 12:20 AM
The bad news is PEOPLE ARE STUPID!! cproaudio General MP3Car Discussion 4 08-07-2003 01:25 AM
