Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 04-14-2005, 03:02 PM   #1
Bezel fabrication
Word... heh, my last dashboard sucks so i'm making a new one.
I'm just curious about what you guys all use to make custom bezels... i'm working with a Datalux LMV10 screen that's been gutted, so i've got a 10.4" open frame LCD with a touchscreen on it.
I was thinking of making the bezel out of ABS so i can try the solvent slurry method rather than the glass/bondo/paint route, but i'm wondering, what's the best way to make an accurate, clean square opening in a sheet of ABS?
greenwire is offline   Reply With Quote
Old 04-14-2005, 05:14 PM   #2
Meatballman's Avatar
For a piece that's not flat (ie, a dash bezel):
Tape off the edges so you have straight lines. Then score the plastic along the edge of the tape with an X-acto knife. Next take a dremel tool with a cutoff wheel and cut along your lines (the scoring will help keep your cuts straight.) Next get some flat files and use them to straighten, shape and smooth your cuts. They work much better than a sanding block or anything like that.
After some patience and TLC with the files, you can have very nice straight cuts.
Meatballman is offline   Reply With Quote
Old 04-15-2005, 12:06 AM   #3
naah, i'm talking about a sheet of ABS, a flat, square sheet
but i need the opening to be accurate for my touchscreen overlay, the bezel has a habit of interfering with the sensors.
Old 04-15-2005, 11:31 AM   #4
I'd probably just use a square and a straight edge and some clamps to form a guide and use a router to make the cuts. Routers and router bits can get expensive though.
Old 04-15-2005, 01:25 PM   #5
Altimat's Avatar
Score the opening well, drill the center, cut the diagonals with a scroll saw, Dremel, jigsaw and backing, whatever - then fold and snap off the 4 triangles on the score lines.
2002 Nissan Altima 3.5 5 Speed Bose FM/6CD ED E12A P4 2.26 512 Ram Ti4600 CDRW DVD Lilliput 200mW 802.11b Trackman AutoTap GPS Opus 150 Carnetix 1260
2005 Nissan Titan SE Dell GX-150 P3 1.0 512 Ram 20G GF4 MX4000 USB 2.0 DVD/RW Xenarc GPS Trackman
Altimat is offline   Reply With Quote
Old 04-15-2005, 04:58 PM   #6
Nevermind got CNC time in may
Old 04-18-2005, 04:13 PM   #7
Yeah...what he said...that's probably easier.
CNC machine is of course the best option.
HOWTO: Building a removable LCD screen bezel and mount gork Fabrication 57 01-14-2007 04:11 PM
How to: Duplicating a radio bezel. Giuliano Fabrication 129 02-21-2006 10:14 PM
My Camaro Radio Bezel Fabrication Picture Diary (56k warning) meissenation Fabrication 35 01-12-2005 01:10 PM
Custom Secondary input using old radio bezel? anaxagoras Input Devices 2 11-03-2004 09:54 PM
WTB: lilliput bezel hanzacra Classified Archive 0 03-25-2004 04:44 PM
