The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Thread Tools Display Modes
Old 04-26-2005, 12:21 PM   #1
My Photos: (0)
Honda Odyssey 01 8" lilliput TS indash
I installed the LCD in my Odyssey minivan.
this is what it looked when I tried everything out... the computer is VIA EPIA-m10k and I initially wanted to mount it in the double din opening then mount the LCD on it, but I've found the depth of the opening is not big enough to clear the cables.
ming is offline   Reply With Quote
Sponsored Links
Old 04-26-2005, 12:25 PM   #2
My Photos: (0)
I took off the dash piece, and opened up the LCD and I found the LCD module itself would fit the dash piece exactly, with a little modification. I had to do some cutting, but no need to move the AC buttons.
so I cut the double din opening bigger, used a piece of MDF to make a mount for the LCD, and glued two pieces of plywood to "squeeze" and hold the LCD in place. the controller was then mounted to back of LCD with four screws.
Old 04-26-2005, 12:31 PM   #3
My Photos: (0)
I used bondo to smooth out the gaps, but I didn't have any experience with bondo or any fabrication thing... I felt it's quite hard to work with bondo and I finally lost patience after several sanding... so I ended up with something not very nice, but it still works
the computer is now mounted in the cup holder slot right below the LCD... not the silver laptop on floor. DVD/CDRW is together with the computer. HDD and ITPS is in back of the LCD.
I will solder some wire for the VGA connection and others, so the connectors would not stick out of the dash board, then I'll find something to cover up the computer.
Old 04-26-2005, 12:34 PM   #4
Banned
xdjxklusivex's Avatar
Vehicle: 1995 Suzuki GSX-R 750 / 2006 Honda Accord / 2002 Saturn S / 1997 Ford Crown Vic
My Photos: (0)
that looks cool just keep on working on fabricating it and making it look OEM are u sure the din connector on the lilliput will clear the dash opening and be flush?
xdjxklusivex is offline   Reply With Quote
Old 04-26-2005, 12:41 PM   #5
My Photos: (0)
the screen is recessed a little bit, about half inch... the connector is not a problem, although it's a little harder than before to put the dash back.
also, I didn't paint the whole piece, just the part around the opening. you can see the edge of the paint if you look carefully
Old 04-26-2005, 01:02 PM   #6
phord's Avatar
My Photos: (0)
Nice! I didn't want to give up my HU or my cupholder (the Ody has so FEW cupholders!), but I didn't mind losing the CD holder.
http://www.philhord.com/gallery/carputer/P0011157
It was a tight fit, but not as tight as yours will be in the cupholder, I think! :-)
Good job on the double-din fabricating! Me likes!
Carputer-II: Infiniti Q45
Simple setup, NAV-only
Tablet PC :: FP :: iGuidance
Status: Ghetto, baby!
Carputer-I: '99 Honda Odyssey
Dual monitor, separate outputs: Finished
FP :: iGuidance :: WinDVD :: EPIA M-10000 :: Opus 150w :: In-dash/On-dash
phord is offline   Reply With Quote
Old 04-27-2005, 01:21 AM   #7
Jesus Freak
antimatter's CarPC Specs
antimatter's Avatar
Vehicle: 2006 Mazda Mazdaspeed 6 GT
My Photos: (0)
Post a better picture. It looks really good in the one you posted
antimatter is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
8" Lilliput question, extracting sound and screen rolls clean customs LCD/Display 5 06-30-2005 10:10 PM
Xenarc 800TSV 8" Vs. Lilliput 8" Trance LCD/Display 0 03-16-2005 06:43 AM
Lilliput 8" touchscreen problems with touchscreen kit Iggyg00 LCD/Display 1 01-31-2005 11:35 AM
indash housing and lilliput? LudeAtude General Hardware Discussion 2 02-07-2004 04:31 PM
Lilliput 8" Touchscreen Display Randomtask LCD/Display 6 02-06-2004 01:12 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
