Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 05-02-2005, 08:50 PM   #16
DashCommand is on a distinguished road
Here is an example for you to see. It's done with wood, not plastic, but you can see the possibilities. This was a gift I made for my wife a while back...yes cheesy, but it scored some good points! All work was done with the laser...including the construction of the box. As you can see, it has interlocking sides that were cut to a tooth style edge. Also, the actual puzzle's message was burnt on with the laser, and the puzzle was cut afterwards with the laser.
As for the question - "What is the minimum thickness to the holes?"
Well, the laser beam is I think 0.0025", so technically the smallest hole you could make is 0.0025" diameter...realisitcally anything bigger that 1/64" of an inch would work just fine. Also, that isn't really a thickness issue...
DashCommand is offline   Reply With Quote
Old 05-02-2005, 09:56 PM   #17
lastberserker's Avatar
lastberserker is on a distinguished road
This is a very sweet present and a great way to justify 11k piece of hardware
Asus K8S-MX ~ Athlon 64 2800+ ~ Kingmax MPXD42D-2K 1Gb ~ Seagate ST960822A 60Gb ~ PSK-3100 PS/2 kbd ~ MR-350 GPS ~ Hawking HSB1AP ~ Buffalo WLI-USB-G54 ~ 8" Dynamix TS LCD ~ DSATX ~ XCard ~ TVedia ~ some LCD TV ~ Vista ~ MapPoint 2006 ~ iGuidance 2.*
lastberserker is offline   Reply With Quote
Old 05-14-2005, 04:30 PM   #18
Trunk_Monkey is on a distinguished road
Thats amazing DashCommand
Trunk_Monkey is offline   Reply With Quote
Old 05-14-2005, 10:43 PM   #19
SickVette's Avatar
SickVette is on a distinguished road
Dashcommand......very nice work. Just so you know the "tooth style edge" is called a dovetail. Very common and strong joint used in woodworking. Very nice work. There is a place close to me that has about a dozen laser CNC machines for production work. They do piece work for me. I did not know a machine like yours was available. I am going to have to look into one.
SickVette is offline   Reply With Quote
Old 05-14-2005, 10:53 PM   #20
Hello SickVette,
Thanks... I wouldn't consider the joint a did a dovetail since the joints do not actually interlock like a real dovetail joint does (Or at least I am under the assumption that a real dovetail interlocks so that it cannot come apart when pulling from one particular direction). At any rate, yes they do exist, however are expensive enough to have to justify the expense with some potential money making ideas (At least I did)...
Old 05-15-2005, 09:44 AM   #21
SickVette's Avatar
DashCommand.....I looked up your machine last night. I am going to call the company tomorrow and check into one of their machines. Proably one that is bit more powerful because I would like to be able to use it on alumnium. Have you tried etching/engraving on ABS plastic with the laser? Does it work?
Old 05-15-2005, 10:02 AM   #22
SickVette,
ABS plastic is the same as acrylic, it can go through it like butter. Aluminium on the other hand -- Wow, you must be looking to spend some serious cash. To cut aluminum about 1/8" thick you would need a 1500 Watt CO2 laser at the minimum which would run you anywhere from $30,000 to $50,000+ for a new machine. You would be best off to buy a VERY NICE CNC router for 10-15k that could cut plastic, wood, aluminium, and possibly some mild steel.
Old 05-15-2005, 11:52 AM   #23
GRUNT's Avatar
GRUNT
DashCommand,
What is the max size you can cut?
Would you be happy to ship to the UK?
Thanks.
GRUNT is offline   Reply With Quote
Old 05-15-2005, 02:02 PM   #24
HHdesign's Avatar
HHdesign is a jewel in the roughHHdesign is a jewel in the roughHHdesign is a jewel in the rough
Dash, I've been working with some 1/8" thick Plexiglass, and 1/4" thick plexiglass for some cool lighting effects. Recently I tried to engrave some logo of companies (alpine, kenwood, MTX, JL) into the plexi, but my work (with a dremmel) is really un even and, even at its best, looks mediocre. The human hand is only so steady.
Do you think you could some some etching in 1/8" thick plexi, not cutting it, but making a design in the plexiglass? Here's what I'm talking about doing, excuse my unstedy hand
My lines aren't as straight as I'd like them to be, so you see where a laser would come in handy, think you could manage something along these lines?
Jeep Grand Cherokee Laredo
Kenwood X790 x/ iP500 Ipod Interface
Elemental Designs 13Kv.2 D2
CDT ES-620 (omg yayay!!!1)
NINe.2X, NINe.2
HHdesign is offline   Reply With Quote
Old 05-15-2005, 02:29 PM   #25
Para Laura
thanatos106's Avatar
thanatos106 is on a distinguished road
nice job dashcommand
thanatos106 is offline   Reply With Quote
Old 05-15-2005, 03:50 PM   #26
I've seen it done on case modding sites - they cut holes in plexi's protective cover and sandblast the exposed surface. As much as I enjoy my new Dremel, I imagine that would give much better result
Old 05-15-2005, 04:26 PM   #27
SickVette's Avatar
I machined the 1" plexi glass with a half lap joint to fit on the 1" aluminum. Once I finished the plexi glass I had a local laser place etch in the Stinger logos (Stinger is one of my sponsors). The best thing about the logos is they light up blue. I recessed blue LED's into the aluminum mount. They shine through the edge of the plexi and light up the logos. I will see if I can get a good night shot of it.
Dashcommand.....you are proably right and I should look into a CNC router. But I like the size and cleanliness of the laser. I have Bridgeport knee mill now that I am thinking of converting into CNC. I am really not sure which route to take. My biggest problem is I am running out of space. I have too much tooling and not enough space. Do you know much about CNC machines? Is there one out there that runs on Corel like yours? That is another issue I am going to have is programming. I need something that is as simple as possible.
Old 05-15-2005, 04:34 PM   #28
GRUNT,
I can cut/engrave a maximum of 12x16 inches...and acrylic/plastic max thickness is around 1/2"...although I have never tried anything that thick. Yes, I would ship to the UK.
HHdesign,
I have done things very similar to that! Etching with the laser is no problem whatsoever, and looks great. You simply set the power to a lower setting, and instead of going right through the plastic, it simply 'etches' it. You can also do it to glass (etching that is).
SickVette,
CNC Machines...I am currently building one that has a 36x36" table, and has about 4 inches of z travel, however I am not extremely familiar with what would be the best ready-built cnc machine for you. You could check out www.cnczone.com. Great website with lots of info and a very good forum. Most cnc routers are based off of G-Code, which you may be able to find converters that would convert Corel files into G-Code. There is a learning curve of course, but it's not that bad.
Old 05-17-2005, 12:02 PM   #29
tonkadawg is on a distinguished road
DashCommand, that is really cool! I have one question - when using the laser to cut acrylic, how does the cut edge turn out? I know when I cut acrylic with a saw, it is really rough and needs to be polished to get it looking good. If this laser can cut clean with a finished edge, that would save a ton of time!
tonkadawg is offline   Reply With Quote
Old 05-17-2005, 12:06 PM   #30
Depending on the thickness, there may be some clouding, however it is not a rough edge. The only two possibilities are either a nice clean edge that is clear, or a clean edge that looks a little cloudy and needs a little polishing if you care for a clear shine. To get all of your cuts very clear and non cloudy, you need a gas assist attachment which I have not invested in. Havn't had the need.
About to take on a crazy interior overhaul for my custom bmw showcar. Some ?’s & pics BEHMER General Hardware Discussion 35 07-11-2006 07:07 PM
custom case fabrications dim-8 General Hardware Discussion 6 10-10-2004 04:43 AM
Audi A6 custom install carpc with fingerprint recognition ejdeleon Show off your project 26 07-07-2004 04:25 PM
PC Based Radar Detector? chut General Hardware Discussion 40 08-13-2003 05:22 AM
Trouble setting custom resolutions.... SinnerG LCD/Display 10 06-18-2003 08:15 AM
