Quote: Originally Posted by EBFoxbat
Does anyone know of a place that will (or can do themself) some custom metal work for me?
There are no local shops that will do a little order for me.
I need some plates made. They are about 7" x 2" and can be thin (they are mostly decorative. One needs a large square cut out, the others need some holes.
There is nothing complicated or fancy here. But I can't do it. Can anyone gelp me?
Hey,
There are two things I'd try if I were you:
1) I'm not sure why you're not able to do it. If the pieces are fairly simple, you can use a nibbler (available at RadioShack for $12.99) and it's REALLY easy. You just drill a 3/18" hole (IIRC that's the size) and start nibbling. Buy the metal sheet from Lowe's or Home Depot
2) Use eMachineShop (
www.emachineshop.com)
Jason
