Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 08-09-2005, 04:54 PM   #16
Matrix_24's Avatar
Matrix_24 is on a distinguished road
Quote: Originally Posted by MatrixPC
Did you test the Lilliput before you rip open it?
How hard it is to rip the fab out? I can imagine mine is hard cuz it seem very solid when I flex the whole piece a little.
I did some tests and hit in spots to see how strong it was, the only way I could get it loose was with a flat head screwdriver.
Of couse I tested it. After 1 setback I needed to make sure this would be the one!!!!
Matrix_24 is offline   Reply With Quote
Old 08-11-2005, 11:39 PM   #17
Matrix_24's Avatar
Well after redoing all my work here is the almost finished product. I get to do the real test on the way to work tomorrow.
Old 08-16-2005, 12:55 AM   #18
dexy's Avatar
dexy is on a distinguished road
nice looking, it will come out really nice. too bad you had to rip out the old one. it came out even nicer with the rectangular edge of the new screen. good luck, let me know when u finally paint and mount.
dexy is offline   Reply With Quote
Old 08-16-2005, 09:17 AM   #19
Matrix_24's Avatar
I decided there was way too much gold in the pewter (being partially color blind sux), so I put some silver on top of it to lighten it up. It looks a lot closer to the factory color but still not there.
Here are a few before adding the silver:
And here is with the silver added to it, it probably does not look very different in the pics, but in the car it is a lot better.
Old 08-16-2005, 10:05 PM   #20
uncrase is on a distinguished road
Next in line...
Okay, MatrixPC, first you convinced me that this is the only way
to go with a PC-in-Matrix, and now after reading Matrix_24's story
I think I finally got the courage to order the pieces and jump in the
deep end.
Would you guys mind sharing some tips regarding the mounting, sanding
etc of the lilliput screen in the dash? What kind of material did you use for
filler, glue, what kind of paint etc?
Also any tips of the mounting of the radio / HU in the spot below
the original place?
One of my problems is also to find a replacement cover (bezel, front,
whatever you want to call it). I called the dealer to see if I could order
a spare one (I'd like to sell the car in it's original state one day), and
he says that that silver cover costs about US$120 !!! That's just crazy.
Any tips are appreciated...it might make my jump into the deep end a
bit more bearable.
uncrase is offline   Reply With Quote
Old 08-17-2005, 12:13 PM   #21
Matrix_24's Avatar
First off, good luck finding a used bezel, I have not seen one on Ebay or any of the vibe or matrix forums. I gave up hope and just hacked up the one in my car.
For putting it together I used 10 min epoxy from the hobby store and balsa wood. I only used bondo as the filler and a little over the back side of the monitor for some reinforcement.
Just take your time sanding and prepare to sand and resand after putting the primer down. It may look and feel smooth, but the primer will show all the high or low spots. I used everything from 220 all the way to 600 grit sandpaper.
The radio mounts really snug in the area above the shifter. I cannot get it out without pushing from behind. You will barely have room, my sony has about a 1/2 inch behind it before hitting what appears to be an air duct.
Old 08-17-2005, 12:19 PM   #22
sdashiki's Avatar
sdashiki is on a distinguished road
If you are still under warranty, remove the bezel, drive to the dealer, tell them it cracked. If they ask how, just skirt around the issue cuz in reality they shouldnt care. if they want it back, say you tossed it.
Then say you want a replacement one. Just say YOU WANT A REPLACEMENT, and dont take no for an answer. They should say yes, its warranty. I drilled a hole into the "placeholder" button underneath the recirculating air button, cuz I wanted to put my AMP bass control there. I changed my mind, and did just what I described, and got a new one.
(----) 0.0%
No more loot for the carpute.
Trying to fit my 20" iMac into the dash... RF 600.5 amp, two 10" JLW0, 8 Infinity Components
sdashiki is offline   Reply With Quote
Old 08-17-2005, 04:43 PM   #23
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
I posted a WTB on matrixowners forum. The guy sell for 25 shipped. I was lucky that the guy got his radio stollen which scratch the left side by the AC button. He order a new one and thus selling this scratch one. I have been watching fleebay without any success. Junk yard is out. Dealers want 100 bucks.
As far as fab the LCD, mine method is the same as Matrix_24. Check my installation in my sign where there is a link to the fab process.
As a general rule, sand the radio bezel and the LCD well all around to get a good bond between the 2. The most difficult part is finding a perfect color match for the stock silver.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 08-17-2005, 05:18 PM   #24
Matrix_24's Avatar
Which in my opinion is impossible without paying to have the color mixed.
Old 08-17-2005, 06:15 PM   #25
I'm considering junk yard, but you're right, those guys know what it costs and want
the big bucks for it. I called one and he said he has a 2003 matrix but I have to come
over and look for it myself. When I asked how much, he said "depends on the condition".
Great, it's a 40 minute drive to the yard.. I'll go over there and bluff my way through it
to see if he can let it go for less.
A friend of mine has a bodyshop, and he told me there isn't much choice... there is no
aftermarket for things like that. And the yard owners know...but at the same time, if
they don't sell it to you, what are the chances someone else will buy it from them :-)
Old 08-17-2005, 06:58 PM   #26
Matrix_24's Avatar
Well I am done with the monitor, all I have is some work to do on the PC case once my new fans come in. Since I am using just the main board from a laptop. I bought a base with 2 fans powered by USB that I will attach it to and put a lid on it.
Old 08-17-2005, 09:06 PM   #27
Shelbrain is on a distinguished road
I have to say that the detail of the dash piece is in impressive. In looking at the whole dash however I am envisioning that you should bring the a/c controls out to line up with the rest of the bezel and radio which stick out a little farther. Nonetheless, looks good.
2005 Black Chevy Impala
Shelbrain is offline   Reply With Quote
Old 08-17-2005, 09:45 PM   #28
Matrix_24's Avatar
I do agree that the dials do look too recessed with the new additions. Not sure what I will do about that yet.
Here are a few night shots:
Old 08-17-2005, 10:19 PM   #29
Jahntassa's Avatar
Jahntassa is on a distinguished road
I think gmpartsdirect.com has the bezel for around $26 or something..but I can't remember what the part number is.
I went the opposite way with my Vibe, and mounted the screen behind the existing bezel, as I didn't trust my fabrication skillz.
Jahntassa is offline   Reply With Quote
Old 08-17-2005, 10:49 PM   #30
jon102034050 is on a distinguished road
dang, nice job.... i only wish i had those kinda skills, except with a bowstaff....
jon102034050 is offline   Reply With Quote
2002 Montero Limited Install... Squid Show off your project 35 10-06-2009 04:41 PM
2003 "SVT" Ranger Carputer Install SVTRanger Worklogs 17 10-29-2006 02:55 PM
94 Jeep Grand Cherokee Install jamiewhittingha Show off your project 10 08-02-2006 02:02 PM
2003 Custom In-Dash 7" Touchscreen Install nirvanades Fabrication 11 04-06-2005 05:33 PM
Where does ground loop isolator install? grandamp3 General Hardware Discussion 6 09-14-2000 09:10 AM
