Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 11-16-2005, 12:49 PM   #1
elgenyo is on a distinguished road
PROJECT: 2004 Xterra Carputer
Looking back, I should have taken more pictures. I suppose we got a bit carried away with the process and skipped documentation on a few steps. If anyone has any questions as to how we got from here to there, feel free to post or PM.
This is a shot of the dash with the factory radio in it before we started.
We took the front bezel off the Lilliput screen and ABS'd it to the Nissan dash.
We wanted a laptop dvd-rw and a center channel speaker up front so a cage was made from Luan. Hot glue was used to temporarily hold the two cages in place until liquid ABS could be poured in to fill the gaps. Styrofoam sheets were cut and placed in between to give the liquid ABS support while it dried.
Closeup
Here's the miraculous jump. We decided that USB and Firewire ports would be nice up front as well, so we took a Belkin hub apart and integrated it into the dash we were making. After the ABS plastic dried, an angle grinder was used to smooth it out. Then I used Evercoat polyester glazing putty to fill in the craters and smooth out the dash to the look we wanted. This is where I wish I had taken more pics. I suppose the smell was getting to my head.
Finished primer.
Closeup
Really bad lighting and ****ty camera phone.
Hard to make out the center channel here but it sticks out 1/4". We used the Clarion SRK-5.
With the dash piece made and the components installed, we've been busy encoding mp3's and playing with all of the frontends to find out which one is best. All of the audio equipment came in today so we will be working on building the rest of the system. Our goal is to have this project complete by Spring Break Nationals in Daytona 2006. Here is a system diagram.
elgenyo is offline   Reply With Quote
Old 11-16-2005, 12:54 PM   #2
Para Laura
thanatos106's Avatar
thanatos106 is on a distinguished road
Nice fabrication pice.
Thanatos.
RexBruMet Skin for FrodoPlayer
Nissan Aux-in MOD
Quote: Originally Posted by bgoodman
We're an international forum, post in whatever langauge you like.
thanatos106 is offline   Reply With Quote
Old 11-16-2005, 07:02 PM   #3
blacklancer's Avatar
blacklancer is on a distinguished road
nice job. i like the usb and firewire up front.
blacklancer is offline   Reply With Quote
Old 11-16-2005, 07:20 PM   #4
replicant is on a distinguished road
awesome fabrication work, i'm looking to redo my maxima's dash and i sooo much wish i had all that space that the xterra has .. too bad not all nissan vehicles share the same layouts/spacing in the dash.
once again, great job.
replicant
Audi A4 (flickr pics)
replicant is offline   Reply With Quote
Old 11-16-2005, 07:41 PM   #5
Subwoofer87's Avatar
Subwoofer87 is on a distinguished road
very nice
2004 Mazda3s
Subwoofer87 is offline   Reply With Quote
Old 11-16-2005, 08:49 PM   #6
lifeboat's Avatar
lifeboat
Nice work, good to see some Xterra stuff showing up! Where did you mount the PC?
IEI PSB-4710, 1.5Ghz P4, 1GB RAM, 120GB HDD, Lilliput 8" TS, M2-ATX, BU-353,
Ikey SL75 keyboard, BT Mini Keyboard, WLAN, EVDO, IC-PCR100 (AM/FM/VHF), HQCT, Centrafuse 1.6...
lifeboat is offline   Reply With Quote
Old 11-16-2005, 11:50 PM   #7
mounting pc
planning on mounting pc under the fron seat. Thanks for the replies!
Old 11-17-2005, 02:13 AM   #8
Para Laura
Yup just like I did.
Good luck.
Thanatos.
Nissan Aux-in MOD
Old 12-14-2005, 11:08 PM   #9
Miles is on a distinguished road
A little behind on this post.. but really nice work. It's interesting to me how different factors (ie. convenience of use, stock appearance, space, power constraints, etc) really influence the install.
For example, I have sweet dick-all room in my install, otherwise I might consider the USB/firewire route as above.
Anyway, really nice work
1997 Mustang GTS "Jenna"
VIA SP13000, 7" Xenarc TSV, 200GB, 'modified' M2-ATX, 1GB DDR400/3200, BU-353. RoadRunner + LSXVoid
Miles is offline   Reply With Quote
Old 06-01-2007, 04:23 PM   #10
This system is for sale. My brother wanted something easier to use like an off the shelf dvd player so needless to say I have the computer, dvd-rw, center channel with amp, Lilliput touchscreen all for sale. Unfortunately, and I say this becuase I put alot of work into it, all the gear has about 1 month of actual use. I can install whatever you would like as far as OS's go and I have just about every "usable" frontend on disc. I'm asking $1000 for everything which I believe is fair considering the fab time I put into it plus all the equipment.
Lilliput touchscreen $299
Clarion center channel $199
Panasonic DVD-RW $149
VIA EPIA M10000 Mini-ITX Mainboard $149
Hitachi 80gb Hard drive $140
1984 Austin Mini Carputer Project bobjimwilly Worklogs 9 11-12-2007 08:07 AM
2004 Toyota Corolla S Project! PaulDePimp Show off your project 17 04-13-2007 07:31 PM
'03 Jetta Wolfie Carputer Project ilmickeyli Worklogs 37 06-25-2005 11:36 AM
starting my first carputer project, have some questions ssa_whiskey General Hardware Discussion 0 02-24-2004 03:43 PM
New CarPuter Project: Need Input! Tremek General Hardware Discussion 12 01-31-2002 03:07 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
