Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 01-08-2006, 11:36 PM   #46
Raw Wave
EsKALad's Avatar
EsKALad is on a distinguished road
i want to use the case for a car pc im doing for someone else. so the cheaper the better lol.
i got dat ***** sittin on 22s! SUPERMAN EDITION!
EsKALad is offline   Reply With Quote
Old 01-08-2006, 11:44 PM   #47
Raw Wave
EsKALad's Avatar
payment sent for shipping costs thanks!
Old 01-08-2006, 11:49 PM   #48
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
Thanks EsKALad, Ill stop by UPS tomorrow and get it sent out. Should get it pretty quick as we are somewhat close in locale.
Also, ill send it with the MoBo standoff hardware so you know what size standoff i was using when i designed the case.
blk02si is offline   Reply With Quote
Old 01-09-2006, 12:30 AM   #49
Raw Wave
EsKALad's Avatar
i can easily make a new standoff in the correct spot right?
Old 01-09-2006, 12:46 AM   #50
High Voltage
blk02si's Avatar
It should not be too hard. I would enlarge the hole that is wrong then use some washers so the screw can be moved. Also a good way to set it up would be to put some 3/4" long screws up through the bottom put a nut on them, then a small spacer, then the mobo, then a rubber washer, then another nut. Worked good for me, also you could move the whole board back and redrill 4 holes. Then not use the I/O plate, just leave it open, then the cable connectors would be hidden also. Just Ideas but you will have to do some fab work but its nothing thats hard if you are good working with tools
Old 01-09-2006, 02:05 AM   #51
rdiggidy is on a distinguished road
Definately be interested if there's a group buy. Keep us posted.
2001 Toyota 4Runner
"They should put your mouth in a circus"
Cinderella Man
rdiggidy is offline   Reply With Quote
Old 01-09-2006, 10:11 PM   #52
High Voltage
blk02si's Avatar
Well, its looking promising for a batch of these to be made. What mobo's are you guys running? I need to know to set up the files for the I/O ports. Also i like the idea of a group buy, if I can get 10 people I believe I can do them for 100 each including all the hardware.
EsKAlad - I shipped out your case today, UPS ground.
Old 01-10-2006, 02:30 AM   #53
m1000 for my mobo
2001 Toyota 4Runner
Cinderella Man
Old 01-10-2006, 10:19 AM   #54
grimor2000's Avatar
grimor2000 is on a distinguished road
The only problem I would see with this case for me would be that my PCI riser isn't over the MoBo. So I'm out unless you'd be willing to make a few longer cases.
Causa latet vis est notissima
VIA SP13000
1GB DDR400
Slimline Slot-load DVD-RW
60GB 2.5 Inch SATA 5400RPM
Dual Active PCI riser
PCI TV/FM card
Logisys FP800
Thermaltake VFD Media Lab
M1-ATX
grimor2000 is offline   Reply With Quote
Old 01-10-2006, 02:58 PM   #55
MySQL Error
jcdillin's Avatar
jcdillin is on a distinguished road
my problem is I won't be using a M1, i'm going with the ITX Pentium board, so I would at least have to be able to fit a opus in the case.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 01-14-2006, 01:25 PM   #56
DOHCrazy is on a distinguished road
Im in for the group buy. Can we get an Official list started?
1. DOHCrazy - M1000
2.
3.
4.
5.
6.
7.
8.
9.
10.
DOHCrazy is offline   Reply With Quote
Old 01-14-2006, 01:41 PM   #57
Raw Wave
EsKALad's Avatar
thanks dude awesome case! very durable and not flimsy at all. not bad for a prototype
Old 01-14-2006, 01:51 PM   #58
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
1. DOHCrazy - M1000
2. Truckinmp3
3.
4.
5.
6.
7.
8.
9.
10.
i am in as well.
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 01-14-2006, 02:03 PM   #59
riddle14's Avatar
riddle14 is on a distinguished road
1. DOHCrazy - M1000
2. Truckinmp3
3. Riddle14 - MII-12000 w/pcmcia&CF
4.
5.
6.
7.
8.
9.
10.
This is a sweet case
"I'm going back to Cali(Iraq), Cali(Iraq), Cali(Iraq), I'm going back to Cali(Iraq), Cali(Iraq), Cali(Iraq), I know so!!!!" Now I'm here!!
By "ToneRiddle"
riddle14 is offline   Reply With Quote
Old 01-14-2006, 02:16 PM   #60
High Voltage
blk02si's Avatar
Im glad to hear you like the case! My main goal for this case was strength. SOmething that can take a hit and protect all my expensive componets inside. When it comes to automotive applications I don't like to mess around. The 2nd prototype that I bent wrong I let my drunk friend do some R&D testing on it with a claw hammer and it is confirmed: Your via will survive the impact of a full swing hammer hit. I hope to have some pics up real soon of the new laptop drive mounted and also im cutting a small square hole on the side of my case to add 2 high speed USB ports that are wired to the MB. But yeah this case really is perfectlysuited for an automotive enviroment and I will be happy to produce some more for you guys who are seeking the same thing I was and couldn't find it anywhere
Thank you for starting up the groupbuy list.
fv24 custom case site Noonyb General Hardware Discussion 6 03-20-2002 06:27 AM
Need A Custom Metal Case? brentp4 General Hardware Discussion 0 11-12-2001 10:19 PM
Making a custom case..............?? brandondere General MP3Car Discussion 15 01-11-2001 08:17 AM
some pictures of my car and custom case Awol][ General MP3Car Discussion 9 12-07-2000 09:04 AM
digital out on the soundblaster live card and makeing a custom case donalson General Hardware Discussion 4 11-27-2000 06:17 PM
