Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 01-14-2006, 02:13 PM   #1
Raw Wave
EsKALad's Avatar
EsKALad is on a distinguished road
Kals Custom Escalade Dash Process
ok guys i realize i have never done a step by step fab of what i do and how i do it. well heres a few pics of my dash. this is the original dash i cut the a.c controls bezel out and moved it down than put my 8 inch lilliput bezel in there. epoxied it in with plastic weld and some abs cement and bits. i think im gonna finish it with bondo since i like working with it better and its less messy than the abs ****. lol heres some pics of the dash now you can see what i did so far.
i got dat ***** sittin on 22s! SUPERMAN EDITION!
EsKALad is offline   Reply With Quote
Old 01-14-2006, 02:25 PM   #2
DOHCrazy is on a distinguished road
Wow, exact same dash, exact same screen.
Cant wait to see how it turns out, esspecially since Im doing the EXACT same thing, ha.
Where did you put your AC controls? Im gonna put mine down in a center console with my headunit. How hard was it to lengthen the wires, if you did.
EDIT: Just realized you put the AC where the pocket was. Im thinking about trying to keep my pocket, but it may be too much work to lengthen the wires so I might do what you did.
Second Edit: How are you gonna mount the AC controls low inside the dash to they line up with the new plate?
Subscribed to this thread.
DOHCrazy is offline   Reply With Quote
Old 01-14-2006, 10:37 PM   #3
Raw Wave
EsKALad's Avatar
lol i actually my dash now i had to move the ac controls down and extended the wires down to the armrest its hidden in that cubby now. im going to put it back to original and cut the dash behind to fit the ac controls lower. no biggie. no one will see the dash cut lol.
Old 01-14-2006, 11:20 PM   #4
That was horrible english, but from what I tryed to read I got.
1. Your AC controls are down in the center console right now.
How hard was it to lengthen the wires?
2. You plan on moving the AC controls back to the dash.
Old 01-14-2006, 11:22 PM   #5
Raw Wave
EsKALad's Avatar
my english isnt horrible. im just too lazy to type clearly lol. and yes you're right on both accounts. let me ask what type of vehicle do you have and what color?
Old 01-15-2006, 12:28 PM   #6
I have a 95 Tahoe. Same dash as you. Interior is grey, dash insert is black like yours. Exterior is green.
Old 01-15-2006, 01:07 PM   #7
Raw Wave
EsKALad's Avatar
not hard at all. but i extended each group alone. there should be 3 groups. 1 group for rear defrost. one group for the actuall on off switching, and one group for the long grey pin wire that controls where the air is directed. each group has a few of the same color wires as the other group, so number the wires or something so you dont get confused and extend them wrong. and use some good thick gauge wire because mine got extremely hot when i used thinner wire. i actually have my dash now for sale if your interested. or send me your dash and ill do it for you.
Old 01-15-2006, 01:26 PM   #8
Im fine on doing it, plus I already have 4040, 4058 and some Rage Gold. How come your not finishing yours?
Are there like 100 wires back there, or is it just a few per control?
I planned on using 18 gauge, how thick did you use?
Old 01-15-2006, 02:00 PM   #9
Raw Wave
EsKALad's Avatar
i think i used 14 and it still gets a little hot. but than again i extended mine about 6 feet. i think theres a total of 19 or 20 wires if i remember. some thicker than others. if i were you honestly id do it the way i have above. the pocket wont do **** for you just cut out the sides behind the dash to make room for the ac controls. and im not finishing mine right now cuz i got alot of hw to do today. when im done ill start epoxying and bondoing.
Old 01-15-2006, 02:04 PM   #10
I just like to put my phone in the pocket, but it sounds as if its gonna be too much to work to extend it.
Ill get used to not using the pocket.
Have you already done any work on the inside of the dash to mount the AC controls? If so, have any pictures??
I have to build my center console first so I have a place to put my headunit and my computer, so I wont be able to start until after that.
Old 01-15-2006, 02:17 PM   #11
Raw Wave
EsKALad's Avatar
honestly i used to use a headunit but no longer do. i use a 4 channel alpine amp with the signal running str8 off the onboard sound and it sounds really good!
i will take pictures of where i need to cut the dash so you know.
also if you have the 2wd 4wd option and the button is blank i reccomend throwing in a usb there for when you need it. thats what im going to do.
Old 01-15-2006, 02:21 PM   #12
All 5 of my tabs are blank because its a 2wd Tahoe LT. I was gonna do the USB thing also. Man, we have some similar thinking!
Dont worry aobut the pictures if you haven't done anything to it, I know what the factory one looks like.
Old 01-15-2006, 08:19 PM   #13
Raw Wave
EsKALad's Avatar
got some bondo on there today to fill it up. pics later
Old 01-16-2006, 01:10 AM   #14
JackMan's Avatar
JackMan is on a distinguished road
I can't wait to see them That's going to be sweet EsKALad!
JackMan is offline   Reply With Quote
Old 01-16-2006, 02:19 AM   #15
Raw Wave
EsKALad's Avatar
thanks for the words of encouragement jackman.
2003 BMW M3 Custom Dash / Overhead Console gork Show off your project 373 01-01-2008 08:52 PM
2003 G35 Sedan Custom Dash And Computer Izik Show off your project 57 08-22-2004 01:45 AM
custom dash? Jamez_Warner General Hardware Discussion 1 06-14-2003 06:53 PM
custom dash making.... ifnh573 General MP3Car Discussion 1 10-13-2001 01:39 AM
Plastic moldings for custom dash mykolJay General Hardware Discussion 1 06-26-2000 01:06 AM
