Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 11-20-2006, 04:31 PM   #166
mbkowns's Avatar
mbkowns is on a distinguished road
Quote: Originally Posted by blk02si View Post
Well I spent the greater half of my saturday off to get all the hardware updates done. HOLY crap the xenarc is way harder to mount and is in more pieces than the super. But it's worth it, the xenarc is way brighter, crisper, and the 5 wire touchscreen interface is much more responsive. I like this way better. The LCD itself is HITATCHI. I spent a good 10 hours on mounting the TS, LCD, all the controller boards, then wiring it. Also got the flash drive adapter mounted. It was like doing this whole project over again because I had to move everything, drill more holes, figure out what will/won't fit. But its done. Now starts my favorite part. SOFTWARE!!! Ill keep ya updated on that. Embedded OS, welcome to your new home:
Whats your hibernate resume speed with the flash drive?
2005 Ford Mustang GT <- - - UPDATED PICTURES
2003 KAWASAKI Z1000 - CUSTOM MODZ
MBK (AIM = IllMBKllI)
mbkowns is offline   Reply With Quote
Old 11-20-2006, 04:48 PM   #167
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
Im actually still working on getting the flash drive to work. As of yet I could not get her to boot. Ive got some more time this week im going to try a different card and config. The OS image itself is perfect and runs hella fast on a normal harddrive. I don't plan on hibernation, I just do cold boots.
blk02si is offline   Reply With Quote
Old 11-20-2006, 11:15 PM   #168
High Voltage
blk02si's Avatar
It WORKS! I figured out the problem. My cheapie CF disk got nuked in my initial attempts of an embedded install. Anyway I got good in DOS bought the sandisk and BAM! first try got my XPE image up under flash. EWF running good. This is hella fast and stable. Thanks to Sfiorito for the helpful info. So yes car PC 1 is back together and better than ever. Im running freeway with the roadfuse skin now. I also have IG3 and all the maps on my solid state drive. Works PERFECT! Damn im happy. Should have the stang back together by tomorrow.
Im wondering with the EWF running can I just to a hard shutdown now? I mean nothing gets written to disk so i don't see why not. . .
Old 11-21-2006, 06:52 PM   #169
mbkowns's Avatar
are you still selling the enclosures?
Old 11-21-2006, 07:46 PM   #170
High Voltage
blk02si's Avatar
Yes sir, 65 shipped
Old 11-21-2006, 07:53 PM   #171
Megalomaniac's Avatar
Megalomaniac is on a distinguished road
which enclosures are we talking about? the double din one or the VIA etched one?
Megalomaniac is offline   Reply With Quote
Old 11-21-2006, 08:03 PM   #172
NiSlo's Avatar
NiSlo is an unknown quantity at this point
Are you going to be providing your OS image to those people interested and amazed at a 12 second cold boot !?!
I installed my carpc into my pet Kangaroo, mate.
NiSlo is offline   Reply With Quote
Old 11-21-2006, 09:09 PM   #173
High Voltage
blk02si's Avatar
Double Din. I also do custom enclosures but these cost some $$.
Old 11-21-2006, 09:10 PM   #174
High Voltage
blk02si's Avatar
I could share my ISO i guess but its optimized for a via m10000, 7" touch, and MS USB GPS. Unless you have this exact hardware the image won't boot that fast.
Old 11-21-2006, 09:26 PM   #175
do you have a pic of what would be shipped and a list of what can fit
I have M10000, m2atx, ocz ram ddr, & 2.5i. hdd also a laptop dvd drive. and various usb stuff.
Old 11-21-2006, 09:41 PM   #176
NiSlo's Avatar
I've got the m10000, 7TS and a bu-353 gps. I think there would be alot of people with _very_ similar setups to what you are using. Even if they have to add a driver or two for more peripherals, I think that it would still be a great base that alot of people would benefit from. It may not quite be a 12 second cold boot, but I bet it would be a hell of a lot better than what alot of people are getting at the moment
Old 11-21-2006, 09:45 PM   #177
High Voltage
blk02si's Avatar
The part i sell is the white .063" aluminum chassis + lid and harddrive mount. You will need to drill & tap your own holes where you want to add hardware. The chassis I sell is a starting point to the fabrication. Its by no means a turnkey solution for all your hardware, rather a solid chassis to mount all your hardware as necessary for your build. If you are ok using a drill and basic hand tools you will be fine. Either way aluminum is pretty easy to work with. I use 6/32 machine screws on my entire chassis so I only had to buy one tap.
Old 11-21-2006, 09:49 PM   #178
High Voltage
blk02si's Avatar
I will share the ISO if you are interested. I know this is kind of a but if someone has the space ill FTP upload it.
Old 11-21-2006, 09:55 PM   #179
so this case is a double din u said. so its possible to bolt in dash? do u have a picture so I can get happy?
Old 11-21-2006, 10:03 PM   #180
High Voltage
blk02si's Avatar
Read the whole thread and look at the pictures. There must be over 20 pics of the chassis in this thread, some pics of the actual production model and various autocad pics of the unit that have dimensions. Also look at sonic v8's thread, he purchased a chassis from me and has pictures of his build. Link is also in this thread. This chassis is designed to bolt up to OEM aftermarket trim kits like the metra series.
indash touchscreen vga rca inputs mike86ttype Classified Archive 25 01-30-2005 10:30 PM
FS: Indash Unit from tm-701L BoraXP Classified Archive 9 01-15-2005 03:48 PM
Cheap indash monitor darkhavoq LCD/Display 11 11-21-2004 03:01 PM
FS: Complete Mini-ITX CarPC w/Xenarc Monitor + More DLe Classified Archive 23 10-19-2004 09:15 PM
Nissan Sentra 1996 GXE Complete Project. 14'' Screen criterzzz Show off your project 19 08-01-2004 01:07 AM
