Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 12-11-2006, 01:27 AM   #196
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
Well everything is running good so far. I switched back to RoadRunner for the frontend. I am going to get some pics of this amazingly clear xenarc running very soon. The gamma control works so awesome at night. I like to dim the gauges and the screen at night. Less distraction. I am also at the final stages for the design of my OEM fit button arrary that im replacing some dead buttons with. I also implemented the hard off power scheme. I kill ignition relay and power just gets cut. The m2ATX is set to act in dumb mode. Its nice that every component in the setup shuts off instant. Very OEM approach. I get away with this due to the EWF operating system. The drive never gets written to so it will never get corrupt. Even if you just kill the power. The cold boot to start back up is at 25 secongs into RR. Im lovin it right now. The xenarc was a really good upgrade that im glad i spent the money to do.
blk02si is offline   Reply With Quote
Old 12-13-2006, 08:52 AM   #197
deepsky is on a distinguished road
Very nice work. I'm just getting ready to start my project, and I'll probably get one of your cases. Just a question, though, is there room inside for a PCI card? 5-1/8” x 7/8” x 5-3/8” are the dimensions of the card. Thanks a bunch!
deepsky is offline   Reply With Quote
Old 12-13-2006, 03:54 PM   #198
High Voltage
blk02si's Avatar
Yes Sir a PCI card will fit. Check out the pix in the first two posts there is one with a wifi card installed. If you want to order one you can paypal me $65. What vehicle is this going into?
Old 12-13-2006, 08:14 PM   #199
deadbolt is on a distinguished road
Excellent leading edge work. Your system looks OEM. Wish I had a double-din. Am I mistaken thinking without that bezel an 8" screen might fit? Hard to tell from the pictures.
Any thoughts on having the flash easily accessible so you can do updates from your desktop ?
On this semi-embedded OS, what happens if you plug in a new USB device the system has never used before. I guess what I am asking is how is the plug-and-play affected with the write filtering ?
deadbolt is offline   Reply With Quote
Old 12-14-2006, 02:32 AM   #200
I'm going to put it into a 92 Toyota Celica AllTrac Turbo. Thanks, I'm finalizing hardware now, and will order one when that's done.
Old 12-14-2006, 09:16 AM   #201
High Voltage
blk02si's Avatar
Thank you for the compliments! I don't think the 8" screen will work. The flash module is easily removable if I pull the PC. It only takes 15 minutes and 10 screws to pull the whole unit out.
The OS is a true embedded setup. Im not sure what you mean by semi-embedded. It will still detect USB devices like flash drives, keyboards, input devices, etc. If I want to make changes to the volume I can turn off the EWF (enhanced write filter) and commit all changes ive made to the OS by command prompting:
ewfmgr -commitanddisable -live
When I am happy with what I did then I run:
ewfmgr -enable
and it turns the write filter back on next boot.
The USB plug and Play has nothing to to with EWF. This is an OS module than can be removed but I kept it intact in my OS image.
Old 12-18-2006, 07:58 AM   #202
High Voltage
blk02si's Avatar
Thank you for your chassis order deepsky! Looked at my paypal this morning. I will have this complete and shipped out this week.
Old 12-18-2006, 11:33 AM   #203
Sid3ways S13 is on a distinguished road
So you are selling these now? What exactly comes for 65 bucks?
Nogaro 2000 Audi S4 (Stage 3)
Black 2000 Audi S4 (Stage 1)
Sid3ways S13 is offline   Reply With Quote
Old 12-19-2006, 12:02 PM   #204
High Voltage
blk02si's Avatar
The white aluminum chassis part of my build including the top plate. It is for Double Din and is not ford specific. Any after market trim kit for Double Din can use this chassis. I will try to post up a pic later on tonight of the unit that im making right now for deepsky.
Old 12-21-2006, 04:20 PM   #205
mangina24's Avatar
mangina24 is on a distinguished road
Looks great, good job.
mangina24 is offline   Reply With Quote
Old 12-24-2006, 12:51 PM   #206
High Voltage
blk02si's Avatar
Here is your chassis deepsky. Still need to drill and tap some holes for the top plate. Hope everyone has a great Xmas filled with carPC presents.
Old 12-24-2006, 03:17 PM   #207
Oh man that is NICE. So what would you charge to install an LCD if I brought you one? There is no chance I have the means to take one apart and put it in there nice as you did.
Old 12-29-2006, 02:59 PM   #208
High Voltage
blk02si's Avatar
Deepsky i shipped your chassis out. Emailed you the tracking #.
I could make the chassis, disassemble and mount the screen into a trim kit and assemble the whole shot, ready for bolt in for $150 (you provide the 7" screen)
Old 12-29-2006, 04:40 PM   #209
Frigor's Avatar
Frigor is on a distinguished road
ewfmgr -enable
U said that u have limited writing on the system disk because too much writing from the OS will nuke the flash card... what about suspension? u have 512Mb RAM.. when u suspend your system XP will wrtite at least 400MB of stuff on your disk, isn't it?
BMW E36 Project [ =======§== ]
Hardware:
Lilliput 7" Touchscreen - Epia M-10000 - HQCT 1.0 FM Radio - 2.5" 80Gb - USB GPS
Software:
FrodoPlayer 1.10 & MapMonkey with FriBruMet Skins by Frigor.
Frigor is offline   Reply With Quote
Old 12-29-2006, 04:42 PM   #210
Frigor's Avatar
Quote: Originally Posted by NiSlo View Post
I've got the m10000, 7TS and a bu-353 gps. I think there would be alot of people with _very_ similar setups to what you are using. Even if they have to add a driver or two for more peripherals, I think that it would still be a great base that alot of people would benefit from. It may not quite be a 12 second cold boot, but I bet it would be a hell of a lot better than what alot of people are getting at the moment
i have exactly your hardware... can u share the iso so i can try it? I think my license will go with this one aswell... mine too is an XP pro...
Hardware:
Software:
indash touchscreen vga rca inputs mike86ttype Classified Archive 25 01-30-2005 10:30 PM
FS: Indash Unit from tm-701L BoraXP Classified Archive 9 01-15-2005 03:48 PM
Cheap indash monitor darkhavoq LCD/Display 11 11-21-2004 03:01 PM
FS: Complete Mini-ITX CarPC w/Xenarc Monitor + More DLe Classified Archive 23 10-19-2004 09:15 PM
Nissan Sentra 1996 GXE Complete Project. 14'' Screen criterzzz Show off your project 19 08-01-2004 01:07 AM
